Tikit vs Brompton price comparison - is the difference worth it?
Bikes: Dahon Mu P24, Trek 7300
for chain longevity and gear train reliability. I also read reports about the chain falling off.
You don't need a suspension.
and big bumps. They are to soak up "vibrations" from cracks, rougher pavement (chip seal), and other smaller irregularities.
Ask your spine if it prefers a suspension on small-wheel bikes. If you're not sure how to ask, you can ask a chiropractor.
(Sure, on smooth cycle paths -wherever they exist - a suspension wouldn't be needed.)
Get the nylon travel bag for the tikit and pad it with foam; the bag costs $70
is not as neat and clean, some parts could get damaged during transit.
for another, the tikit comes with "V" brakes, which are better than the standard brompton brakes.
first winter. I test-rode a Brommie, and the brakes seemed just fine (though it was a short test ride).
(Assuming you've ruled out a 20" folder like the NWT).
The Metropolis, UK
Because it seems in the higher gears the chain is really forced to the side a lot. That cannot be good
On what authority do you say that? The Brommie's suspension or a Thudbuster are not there to smooth out potholes
I have a bag that can comofortably hold my 20" Dahon. My concern is that because the Tikit's fold
The standard V-brakes on Tikit are cheap. They came standard on my Dahon and the front one seized 3/4 through the
Buying two folders, one 16-inch for commuting and one 20-inch for touring, is out of the question, until I win the lottery
Useful review here:
https://www.pacific-cycles.com/upload...%20review2.pdf
You just need a better saddle and Ergon or Biologic grips.
See my thread & pics:
https://www.bikeforums.net/showthread...cific-Reach-IF
I'm glad you appreciate the Brompton. Despite it's critics, it is a fine bike and very dependable.
Bikes: 2012 Masi Speciale CX : 2013 Ghost 29er EBS
There seemed to be a lot confusion about what suspension does for a bike and I think it requires some clarification.
There seemed to be a thought that mechanical suspension can dampen high frequency vibrations (chip sealed, cracks etc and minor imperfections) and while they may help, fat and wide tires will do a better job at this. To combat high frequency vibrations, you need big fat tires that "SWALLOW" these imperfections as you travel at high speeds. Mechanical suspension is only effective at low frequency jolts (bumps and potholes etc..). Both the Brompton and the Tikit can not take the 16" version of the Big Apple as far as I know. Only 406 20" wheels can. The key is low pressure without getting into pinch flats and the Big Apple balloon tires can do that and the difference is noticeable. But the Big Apple has limitations as it provides a limited amount of compression travel at the minimum recommended tire pressure. To supplement that, you need mechanical suspension like a Thudbuster at the rear or a Pantour at the front. They work best in "conjunction" with wide fat tires.
The MOST COMMON mistakes a lot of newbie off-road riders do when they take their bikes on trails is still to maintain their high pressure tires at the max thinking that will make them ride faster and that their suspension will help. I've seen so many sad and frustrated faces on the Kettle Valley trail where riders were basically jack hammered to death due to poor trail conditions and running their tire pressures at like 70 psi when their tires can be lowered down to like 40 or 35psi to provide better comfort and better control on rough gravel plus good flotation on mud and dirt.
Know the benefits of running at lower pressure.
Secondly, I don't know if the OP realizes but in some parts of the Yukon and the outlying remote towns, roads are not as well super maintained and well super up kept like roads in the cities! These places get snowed in the winter and usually don't get plowed. If so, they are heavily salted. The temperature differentials meant that come spring, you'll see more cracks, bulges and potholes appearing once the snowplows come to clear for car and truck traffic. I just like to convey some ideas to the OP that you need to take the conditions of these remote roads into account when choosing the right bike for the job. Don't compare them to city roads as they get first priority, whereas remote roads don't -- less people complain you know.
My thoughts is this. Are you going to be flying up north all the time, like once a week or once a month? If that's the case, I can see why you need a Brompton or a Tikit. But a Tikit folded is no smaller than a 20" Dahon; infact slightly bigger than my Dahon Mu Sl with all the nice upgrades to combat rougher terrain of the north that the stock Tikit nor the Brompton even have nor can be equipped to.
I'm worried that all you're focusing is just the fold and the convenience, but how much time and inconvenience that this is going to set you back when you'll be riding say 20 to 30km on rougher roads that you need to endure being jack hammered for hours on end. Don't get too fixated on just the convenience!
Part-time epistemologist
From Brompton's website about the 6-speed gear train: 33 - 100 gear-inches (non-reduced gearing) = 67 gear-inches spread
From BF website:
Alfine 11 Tikit: 21 - 86 gear-inches = 65 gear-inches spread
Nexus 8 Tikit : 23 - 71 gear-inches = 48 gear-inches spread
Standard 8-speed derailleur Tikit: 30 - 77 gear-inches = 47 gear-inches spread
From BF website:
EDIT:
If we think about more reasonable figures like giving the Alfine 11 a 25 GI bottom, the top of the range will be a bit more than 100 GIs ... roughly 75 GIs. Roughly speaking, a 6 sp Brompton will typically give the range of the 8 speed IGH or an 11/34 cassette ... although you'll have to do that 1/2-step-like shifting to get reasonable jumps of the 8 speed IGH and the uber wide cassette should use a medium cage MTB derailer for good shifting. The Alfine 11 will typically give a wider range than those alternatives.
A narrative on bicycle driving.
I think that this is a non-issue for such small wheels which are much much much stronger than 26" or 700c wheels with an equal number of spokes.
I've never been to Yukon. I'm reasonably aware of the limitations of small wheels (my folder is 20"), so I wound't try to ride on too remote roads. The map shows enough of main roads that perhaps could be no worse than many of our roads in Toronto (many of our roads here are quite bad).
The folder I will buy has to handle commuting duties, as well. That includes multi-modal commuting, especially in winter. I'd love to buy a Pocket Llama or a NWT, but they would be very difficult to handle/carry folded.
It's an irony that my Dahon is the best compromise in this respect - a jack of all trades (though master of none).
Unfortunately, my trust in its service evaporated when the steerer tube broke during a ride and sent me sniffing
grass in a ditch (fortunately at a very low speed so nothing happened).
Bikes: Brompton, Dahon Vitesse D5
Quoted: 55 Post(s)
In my experience both the Thudbuster and Brompton suspension do work well in terms of vibration dampening. Sometimes with the thudbuster you can feel the vibrations through the pedals but the rear end is isolated.
Brompton's high gear with the 6 speed is a combination
of the overdrive gear in the hub,
and the 13t (&15t) external cog..
Dual Drive hub in the Tikit will also offer that gear combination.
Sturmey has a Dual drive as well as Sram. IGH + cassette..
Indicator pull chain Vs klick box, with plastic case.
Thanks, Pacificcyclist, for the interesting info. I can clearly understand this applying to suspension shocks on MTBs, but not as clearly when talking about a block of elastomer doing the work. Jiggling a dense plump of jello should soak up even higher frequency vibrations better than big gas shocks, no? They use some kind of rubber (or whatever) blocks on submarines to dampen vibrations from machinery (that would be high frequency?) and other sources. Well, I'm no engineer.
Part of the downside with Big Apples is that they are heavy tires, so they accelerate slower. But once you get them up to speed, I have no problems keeping up with the roadies.
Downtown Yukon and the outlying areas are no problems with both the Tikit and the Brompton or your Dahon. I'm sorry to hear that your have a problem with the steering post. Must be freaky when it happened?!? Ouch!!!
Why don't you do this. You've got a Dahon which you can convert into a dirt bike with a Thudbuster and a pair of Big Apples and use that to explore the remote areas on the weekends. The Dahon can be folded and be taken into transit albeit not as convenient as a Brompton. Tikit is still bigger size wise when folded compared to a Brompton. Use the Brompton when you have to go to work during the week in the middle of the nasty winter. I use the Mu SL basically for weekend excursions, tours and light off-road duties. The Dahon Speed Duo is used for week duties including inter-modal travel because it is not as messy when folded as the Mu and I don't need the gears or the suspension. The roads in Vancouver are pretty bad, but manageable with the Dahon Rotolos.
I would vote for the Brompton and then add a Thudbuster if it is at all possible. You can a consider a sprung saddle from Brooks. But if you prefer a racing saddle, then Thudbuster helps.
What about a Birdy Inter 8? You get a relatively small size, some suspension and most importantly better tire selection. Schwalbe Kojak, Big Apple, or Black Jack depending what you are doing at the time.
Quoted: 55 Post(s)
Btw you can just about squeeze 1.5" tyres on a brompton, the only one available being a greenspeed scorcher. Mudguard clearance is a bit tight but it works.
Bikes: Brompton M6R, Salsa Mukluk II, Trek 7500, Raliegh fixie, 3 SS cruisers, JC Higgins Color Flow, Junker Flying Jet, KHS F20-A, Worksman trike
If you're going to user the Brompton for touring you should also budget for the one of their granny gear options, otherwise the 1st gear is going to be too high for many of the hills you encounter. The gearing is the only thing I don't like about my Brommie, I never use the 5th or 6th gear, and the lower gears don't have the right ratio for most hills.
One advantage the Tikit may have for touring is that the rear rack looks higher and further away from the pedals than the Brompton. That would make finding rear panniers easier, because the rear rack on the Brompton is very close to the pedals on the back swing, especially if you have big feet like me.
Hill Climbing? I Run a Schlumpf mountain drive with my BSR/AW3,
2 gear ranges in the crank reduction planetaria .
3 low gears take up where the top 3 leave off.. bottom is 17.6"
people use Carradice saddle bags, and the seatpost beam racks
On Brompton to put more stuff on the back..
or Herr Stuke's technique of standing a backpack up on the rear rack.
I Don't like the Tikit pannier front rack (goes double for the single sided one)..
as well as the travel 20" wheel bike.. removable EZ pack.
on my P. Llama..
But I do like the big single bag on the front of the frame of the Brompton.
on my P. Llama..
Quoted: 19 Post(s)
What I meant was: compared to the tikit, I found the B to be a bit *harsher* ride despite having an elastomer built-in. This was mostly down to tires. So saying that you had to put a Thudbuster on a tikit to get it up to the B's elastomer suspension standards was nonsense.
To the OP... for what it's worth, it seems that you want - even demand - the flexibility and customization available from a Bike Friday or even a Dahon/Tern. The Brompton is a great bike - I've ridden in a lot of different places and the fold is amazing - but there are limitations and vibration/suspension is going to be one of them.
It sounded from your original post that you wanted the BF more - I'd save up and get it. After all, the "poor man/woman" buys twice. Once you get the Brompton, you'll be thinking about "the other bike" all the time!
OK, more seriously, as I mentioned before, I don't trust this bike any more. This wasn't the only issue with it,
though it was the most critical. This bike is going into a garbage container asa I get the replacement bike.
Actually, I think that Brompton can carry more stuff than a Tikit-without-the-trailer, when used the way pathlesspedaled
uses it; the T-bag can carry probably more stuff than two front panniers, and a backpack sitting on the rear rack can
carry at least as much as two panniers.
have been using Brompton for lots of touring successfully, and so have other people, so the bike can handle it. Obviously,
a 16-inch-wheel bike is going to be the most compromised bike of them all; the only thing going for it is the fold. But if you cannot get it to the destination and back, then the bike's greatness doesn't matter.
If you're going to user the Brompton for touring you should also budget for the one of their granny gear options, otherwise the 1st gear is going to be too high for many of the hills you encounter. The gearing is the only thing I don't like about my Brommie, I never use the 5th or 6th gear, and the lower gears don't have the right ratio for most hills..
If folding and travel are your biggest concerns, then the Brompton does rule. If you do, get the B&W case. Not cheap, but since you're in Toronto, for your info, I've packed and checked the Brompton in the case and flown into and out of Edmonton, Toronto, Windsor, Montreal, and Charlottetown. No issues with either Air Canada or Porter. I do suggest additional padding however if you pack it to prevent it from moving. Get a portable scale - you'll come close to the 23 kg/50 lb limit.
As for buying the Brompton itself, I think another poster in Toronto has been waiting 13 weeks now for his to come in! I got mine in about 10 days. What I did is phone every Brompton dealer in Canada and see what they had in stock, and I compromised a bit on what I wanted for the original colour. I still got a great colour (sage green) that almost everybody comments on. All I had to pay extra was shipping (hey, HST is pretty much the same everywhere), and it only took about 4 or 5 days at most from BC, where I got my bike. I've had good luck with Fairfield Bicycles in Victoria and Dumoulin Bicyclettes in Montreal. In fact, if you make it out to Montreal, Dumoulin has a great selection of bikes and accessories (I stopped by on a conference once). I don't know how many bikes Curbside keeps in stock in Toronto.
Good luck!
