Handlebar stem dimension help needed.
Old 08-17-12 | 08:32 PM
I'm stripping a damaged 1994 Trek 2200 frame and adapting the components to a 2001 Giant TCR ONCE frame. I'm old school and anything other than quill type bar stems is new to me.
The Giant steering tube is 1" diameter and the bars I intend to use are 26mm. Being I'm not prone to opting for the most glamerous parts I've found a stem for that combo from Bike Nashbar and even a shim on eBay to fit my 26.2mm seat post to the 31.6 tube.
Anyway my questions: Is there basically a standard/recommended stem length for a properly fitted 53 c-c top tube (horrizontal center of seat post to center of steering tube is 55cm). On my mid 80's bikes w/ 53 top tubes I used a 90mm stem, but I'm thinking 80mm on this frame, what say you? Next question, I assume the stems have a standardized steering tube clamp height, is that correct, if so how much space does it cover? Last question, where can I find a headset cap for the 1" steering tube?
Thanks in advance, SKeown
SKeown is offline
Reply
Old 08-18-12 | 01:25 AM
Bikes: 8
threaded? is that 1" ID or OD , makes a difference in the stem, 1" OD the stem is 7/8"
stem is 1" when the fork is 9/8"
bodies of riders are not standardized.. cant type my way to fitting you from here.
fietsbob is offline
Reply
Old 08-18-12 | 02:46 AM
Originally Posted by fietsbob
threaded? is that 1" ID or OD , makes a difference in the stem, 1" OD the stem is 7/8" stem is 1" when the fork is 9/8".
It's 1" OD threadless tube.
SKeown is offline
Reply
Old 08-18-12 | 03:06 AM
zukahn1's Avatar
Titanium Club Membership
10 Anniversary
The stock stem length for most early 90's road bikes with a 53cm is 100mm but you should be able to run a a stem 10mm shorter or longer just fine. Early 90's or newer bikes tend to run slightly longer stems than the old school tuff.
zukahn1 is offline
Reply
Blythe Ryder
Bicycle Mechanics
12
05-15-15 03:08 PM
webike4fun
Classic & Vintage
20
02-22-13 06:24 AM
ejapplegate
Classic & Vintage
17
12-13-12 12:10 PM
chico1st
Bicycle Mechanics
17
07-22-10 10:58 AM
williaty
Bicycle Mechanics
5
07-04-10 10:33 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
