Swapping chainrings
Swapping chainrings
I'm looking to get a specific set of chainring sizes: 24-36-48. I can only find one crankset that comes that way for something like $160.
Looking around the internet it seems you can buy individual sprockets that have a standard BCD, more or less. So how do I assemble a crankset with the chainring sizes I want? Can I start with a triple that has a 48T and replace the other two to be 24 and 36? Is there a standard BCD for the middle and inner sprockets, on those cranks you can replace them on? I'm rather mechanically inclined, and it seems like it should be an easy job. I just don't know what the standards are.
I'm not even sure if it's more expensive this way - I just need 24-36-48 at 170mm on square taper as cheap as I can.
Quoted: 3375 Post(s)
Liked 5,513 Times
This is close: https://www.universalcycles.com/shopp...ls.php?id=9824
I put one of these on the ex-GF's bike (before the "ex" part).
I was very impressed with it.
BTW I don't know why they list these as compatible with 6/7/8 speed chains.
I put it on a 9s system where it worked like a charm.
Really Old Senior Member
Typical triples in that range will have 110MM BCD for the 2 larger rings and a 74MM BCD for the granny.
You might try looking for a crank that only requires the large ring to be changed. It "MIGHT" save a few $??
Shim that's funny you post that, because the expensive one I want is the Sugino XD500.
In any case, I found this Alivio M430:
https://www.universalcycles.com/shopp...62&category=62
Which should accept this 24T granny:
https://www.universalcycles.com/shopp...06&category=50
Right? If so, after shopping around that could be less than half the price of the Sugino.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Older MTBs can make good donors, the better ones had some pretty decent components. Now the cheap ones with riveted and stamped cranks are junk.
Please don't confuse ebay "asking" prices with "selling" prices. Many sellers never get their ask price. some are far from it. Value is determined once an item actually SELLS. Its easy enough to check SOLD prices.
One other thing you need to consider is your front derailleur. Many have limitations with respect to the gap between the gears. For example, the derailleur on my MTB could not handle the gearing you want to use, as it is 2 teeth beyond what it was designed for (it could handle 26/38/48 but not 24/38/48).
On my 2 bikes I replaced the large ring on 22-32-44 cranks with a 36 & 38.
Shifting isn't "immaculate", but totally serviceable.
The gap between the large ring & FDER does look awful though.
https://www.masherz.com/products/shimano/fdm773.htm
So do these things sound compatible? The Alivio M430 and a replacement 24T granny as noted above, plus some 48T derailleur that has a 22 or 24 tooth capacity?
I will be switching to friction by the way, if that makes any difference. I don't have to worry about indexing and shifter issues between companies. It also means I can put most any components on the bike.
I would vouch for those Sugino cranks. I had a Sugino XD-350 (cheaper version), and it was great. If you are on a budget, I would suggest getting that over the XD-600. It is actually more durable with 2 steel chainrings instead of 1 or none. I got it for a pretty good price here: https://www.benscycle.net/index.php?m...oducts_id=8654
There is also a 170mm version for the same price. I loved the crankset before my bike got stolen a few weeks later
I would personally stay within the manufacturer's spec, but that's just me.
honcho
Bicycle Mechanics
9
08-20-18 09:17 PM
marcpro
Classic & Vintage
4
02-23-12 08:54 PM
