Duct tape the inside of my tires?
Old 01-18-05, 08:24 PM
little5guy's Avatar
Bikes: 95 GT Force, 95 Gary Fisher Hookooekoo, 75 Takara fixie
First, I have a never ending quest to find more uses for duct tape (which clearly represents the apex of human thought). Second, I am cheap. Third, I am frustrated at having gotten two flats in as many rides.
My query:
Would it be folly to apply thin strips of duct tape to the inside of the tire? One or two strips would not be too thick to mess anything up I would think. The benefit, of course, would be that those little stones, and pieces of glass and metal would have more trouble poking into my tube.
Has anyone ever tried this? Has no one ever tried because they are smart enough to realize it is one of the more bone headed, useless acts one can do? After all, Amradillos are awesome, but they cost $30 bones a tire. That ain't cheap.
For the uninitiated, Armadillos are tires have extra thick tread and are about as close as one can get to puncture proof.
Any thoughts are appreciated, as always.
Thanks!
little5guy is offline
Old 01-18-05, 08:33 PM
SuperstitiousHyperrealist
jinx_removing's Avatar
Bikes: unknown road conversion, half built Benotto track
Duct tape isn't really puncture resistant so I would say that this isn't going to do a thing for you.
Edit: there are liners that you can purchase for this. I don't know anything about them but I know FixedFiend uses them.
jinx_removing is offline
Old 01-18-05, 09:00 PM
old codger
icithecat's Avatar
Well. If you used enough duct tape, you could replace the tube altogether. I wouldn't try it though.
icithecat is offline
Old 01-18-05, 09:46 PM
Retrogrouch in Training
bostontrevor's Avatar
Ask yourself this: do you really think duct tape is tougher than the tread and skin wall of your tire? I don't.
Personally I love Armadillos. If you're cool with the fact that they're a heavy slow tire, they're awesome. Yeah $60 to get you rolling ain't cheap, but then not having to fix a flat at 7pm and 11 degrees is pretty excellent too.
bostontrevor is offline
Likes For bostontrevor:
Old 01-18-05, 11:27 PM
Bikes: Univega - fixed conversion
Yeah. Get the liners. Also, make sure you have plenty of pressure in your tubes. I used to get flats all the time until I figured out that 80% of them were so-called pinch flats or "snake bites" which are due to a less than adequately inflated tube getting pinched when you hit a rock/pot hole/curb.
Slartibartfast is offline
Likes For Slartibartfast:
Old 01-19-05, 04:46 AM
Perineal Pressurized
dobber's Avatar
I use an retired inner tube as a liner. Slit it lengthwise (around the inside) and place your working tube inside, like a dog in a bun.
Don't have any hard and fast scientific evidence to validate its usage. But my streak of annoyance flats ended after I deployed it on two different rides.
dobber is offline
Likes For dobber:
Old 01-19-05, 04:57 AM
Just riding
andygates's Avatar
Bikes: Cannondale Bad Boy / Mercian track / BOB trailer / Moulton recumbent project
Duct tape is easy to pierce and it's heavy. And the glue goes to crap when it gets hotwet. Save it for holding the Universe together, and get liners or some decent tyres.
andygates is offline
Old 01-19-05, 07:44 AM
Rebel Thousandaire
Ya Tu Sabes's Avatar
Bikes: Public D8, Yuba Mundo (cargo), Novara Buzz (1-speed, soon to be 2-speed w/ a kickback hub), Xootr 1-speed folder
I agree that liners are the way to go - they're not that spendy - but I think the duct tape could work. A single strip wouldn't do much, but maybe two or three strips, or a regular-width strip folded over on itself. I'm just figuring you could pretty much make a Mr. Tuffy out of duct tape. It is true that it wouldn't work as well as a Mr. Tuffy and certainly not as well as Armadilloes, but, you know, it would be wicked cheap.
Ya Tu Sabes is offline
Old 01-19-05, 07:51 AM
Aluminum.
justin79's Avatar
I used Spin Skinz for a little while which worked pretty well, but they were a pain to install and they're expensive enough that it's not really worth using them instead of springing for Armadillos. Are you getting flats up front? You could probably get away with a cheaper tire for the front and pay the extra money for a nice one in the back.
justin79 is offline
Old 01-19-05, 09:46 AM
Spawn of Satan
The palce where the you get the most gain from saving weight is the outer edge of rim. So if you spend a little money to use light weight liners, I think it is worth it. The extra miles per hour you get over the long run vs. money spent is a no brainer.
If you use three layers of duct tape you will add a lot of weight right where you do not want it. You will be noticably busting a$$ more and getting to where you want to get in the same amount of time.
captsven is offline
Old 01-19-05, 09:54 AM
Listen to me
powers2b's Avatar
[QUOTE=little5guy]First, Would it be folly to apply thin strips of duct tape to the inside of the tire? One or two strips would not be too thick to mess anything up I would think. The benefit, of course, would be that those little stones, and pieces of glass and metal would have more trouble poking into my tube.[QUOTE]
Bad idea on many levels.
Your tube is coated with talc powder to allow it to slide around inside the tire. DT will stop that.
The inside of the tire should be smooth, dry and easy to inspect for debris. DT will prevent that.
When you get another flat you will have a fun time removing the tube from the tire and an even greater time trying to patch a tube that is covered with DT glue.
Enjoy
powers2b is offline
Old 01-19-05, 12:33 PM
NoGoSlow
HelluvaStella's Avatar
Bikes: Stella fixy conversion, Trek 2300, Specialized Rock Hopper, Schwinn Collegiate 3, Mz Skorpion
OK, so much to address. I say agreed on the fact that stickiness inside the tire is bad. If you're having frequent flat problems, do two things (both cost $, sorry):
If you don't already, get a good floor pump with a pressure dial. I fill my slicks to 115 to 120 psi, and check the pressure (top off really) every day, or every other day.
If the problem is glass and whatnot, look for a pair of tire scrapers. I got them from Via Bikes in Philly https://www.bikeville.com/ for about $5. They are essentially wire curves, attached at the drilled brake hole (if you have) that follow the cross section profile of your tire without touching. If a piece of glass is embedded in your tire, it gets kicked out before one full rotation. The glass flats aren't one shot deals, the glass gradually works its way in with successive rotations. I'll get some pics going when the camera comes back from the infirmary. I'm not the only one who's heard of these, am I?
HelluvaStella is offline
Likes For HelluvaStella:
Old 01-19-05, 12:44 PM
oh..so...crusty..
crustedfish's Avatar
Bikes: bianchi pista
no, your just the only one who uses them.
crustedfish is offline
Old 01-19-05, 12:57 PM
Listen to me
powers2b's Avatar
A gloved hand or the bottom of your shoe can be used to remove glass from the tires.
The KEY is to avoid riding in road crud by staying in the tire-path part of the road whenever possible/practical.
Enjoy
powers2b is offline
Old 01-19-05, 07:54 PM
Good Afternoon!
SamHouston's Avatar
Bikes: Various by application
Yah if you're getting too many flats take a look at what you are doing on the road. If it's pinch flats be a bit more considerate of the rough bits if it's glass and wire don't go though the ugly stuff if you can avoid it.
Always remember that flats are part of the game too, no need to take too much effort with gear or line to avoid them they'll come anyway. I only get about one a month but occasionally lady luck takes me out behind the shed and I get 3 in a day. Nuttin to be done for it if you're city riding and can't pick your destinations.
SamHouston is offline
Old 01-19-05, 07:58 PM
NoGoSlow
Yes, I may be. But "your" the one with poor grammatical skills. And a sh*tty attitude, if I may say so.
Old 01-19-05, 10:10 PM
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times in 169 Posts
Yes it would be folly.
Spinskins or Armadillos or both, or any good quality Kevlar belted tire (and there are many), are the best answers. If you really don't care about speed or effort and money is a big issue. And if you have old tires like the ones on the bike or smaller. You can cut the beads off the old tires and put them inside the good tires. You will lose about 1 mph on flat ground, but you can ride over most glass, small animals, and medium size dogs....
2manybikes is offline
Old 01-19-05, 11:30 PM
Total Hack
labratmatt's Avatar
How about raccoons? Fawns? Cubs?
labratmatt is offline
Old 01-20-05, 09:55 AM
Bikes: 2 many
I guess it depends your wheel build, type of fork, and skill level.
You have heard of a "Bunny Hop" haven't you?
Likes For 2manybikes:
Old 07-06-17, 03:59 PM
Gorilla tape
I have used gorilla tape on the inside of the tire. It has worked for me so.
Danyboy95 is offline
Old 07-06-17, 04:10 PM
Calamari Marionette Ph.D
SquidPuppet's Avatar
Bikes: 3 Chinese Gas Pipe Nerdcycles and 2 Chicago Electroforged Boat Anchors
Quoted: 2358 Post(s)
Liked 33 Times in 26 Posts
12 years. Almost the record. Close but no cigar.
SquidPuppet is offline
Likes For SquidPuppet:
Old 07-06-17, 05:31 PM
johnnytheboy's Avatar
Quoted: 443 Post(s)
Liked 12 Times in 7 Posts
30 dollars per tire IS cheap.
johnnytheboy is offline
Old 07-06-17, 06:09 PM
Talking to zombies again?
Old 07-06-17, 09:23 PM
drlogik's Avatar
Bikes: '87-ish Pinarello Montello; '89 Nishiki Ariel; '85 Raleigh Wyoming, '16 Wabi Special, '16 Wabi Classic, '14 Kona Cinder Cone
Quoted: 699 Post(s)
Liked 407 Times in 253 Posts
If you were bike treking across China and miles from civilization it might work to get you a few more miles from a set of bald tires if you wrapped it on the outside. On the inside? I agree with the above statements. The glue alone will turn to jelly and it can puncture easier than the tube.
drlogik is offline
Old 07-06-17, 09:54 PM
Tokwan's Avatar
Bikes: Giant/HARO/ Exitway
Quoted: 82 Post(s)
I have done this before. Had a flat in the remote part of the trail. While going about hastily fixing the flats, I accidentally broke the liner. The liner itself was already in bad shape( I don't make enough ..) so I used the good old Duct Tape. Forgot about it and only realized a few months later. No problems.
This was for MTB.
Tokwan is offline
