Bullhorns on Origin8 Quill Stem?
The stem just has a single bolt for the clamp, no faceplate, and not much give.
https://www.origin-8.com/?page_id=91&...Stem&cl1=STEMS
I've got risers on there now, and wondering, because of there is a trick to, or if it's even possible to thread the bull horns through.
Your cog is slipping.
Screw it.
Seriously, are you saying that the bend in the bars won't make the turn? I have had that problem with really tight road bars, in which case I do whatever I need to do to pry the stem open. I usually end up using a number of screw drivers, washers, and whatever else I can reach with my free hand. Things go flying across the garage, sometimes I get poked in the eye. It's really not a big deal if you use the proper safety attire; which I do not.
Fresh Garbage
The narrower cut-out part of the stem clamp goes along the inside of the bends or else the stem will just get stuck against the bar. No one understands your question because drop bars have been used with quill stems for a very long time and bullhorns arent that different
I appreciate the feedback.
Cat Enthusiast
Bikes: All City Nature Boy
