Bending Bullhorns Inward
www.hellonurse.com
I saw a messenger in NYC today who had bent his Profile Airwing bullhorns inward, making the total bar shape more triangular than rectangular. I want to do this to my Profile Airwings because they are quite wide and I'm afraid of snagging in tight traffice.
I asked the guy about the process for bending the bars. Basically he said he used a torch to heat them up, but not too hot since the metal is aluminum. Then he pressed them on the ground to bend to the correct angle.
Has anyone else bent their bullhorns inward? Any tips for tools to use, problems to watch out for, etc?
hello
I always wondered why bullhorns aren't designed in that fashion. It seems like a much more natural position for your hands to be in. I posed this exact same question about a year ago here, about bending bars.... Got a lot of negative responses.
I have one-piece mtb bars (w/bar ends) that are shaped in that exact way....but of course, these bars are way too wide.
Listen to me
The bars will then have the physical properties of a beer can.
Never, never, never heat any aluminum part on your bike with a torch, and never, never, never shake a baby.
Enjoy
Frankly, Mr. Shankly
The airwings on my bike have one side bent slightly inward. This happened when the bike dropped on the same side two or three times. So maybe you could just drop your bike on the horns a few times or get something to slowly apply pressure to them. Granted it wouldn't be much and you might compromise the strength and integrity of the aluminum...
Listen to me
Originally Posted by wunder
Edit:
powers2b answered my question.
I Voted for the Green M&M
Bikes: Fixie
I would put one side in a vice, hold on to the other side and lean back with your weight. Repeat for the other side.
If they break or you fall, I'm so not responsible. Good luck.
Well at least I'm housebroken.
Shiftless bum
Originally Posted by powers2b
The aluminum is heat treated. Heating the bars with a torch will anneal the metal.
Enjoy
Enjoy
Originally Posted by operator
truneo that tuned park internal nipple wrench work ??
Chronic Tai Shan
Bikes: Pake Single Speed
If you do heat it up, you could always re-heat treat it to its original T6 condition.
Listen to me
[QUOTE=ofofhy] I have no idea how brittle the heat treated Al is.
Very
Very
Listen to me
Bow$$
Bikes: Surly Instigator '02, Schwinn Traveler fixed conversion, '02 Fuji Track
not likely without special equipement $$$$
Listen to me
Originally Posted by dustinlikewhat
all you need is a zippo, a hammer, and a bottle of scotch.
Bow$$
for making stylish ingrown hairs, duh!
Chronic Tai Shan
If you know someone in industry ot research with that type of furnace you can do it.
Listen to me
There is a pet crematorium down the street.
So I asked if I could throw in a couple bars with the next run of stray cats.
The guy says 'sure'.
Well when I opened the box there weren't any cats in it but there was a 60 foot sea monster from the paleozoic era...it was the loch ness monster...I said 'g**da** monster, what do you want?'...well you know what he said??
He said "I need about tree fiddy"
Chronic Tai Shan
There's your problem, crematoriums run at over 2000 F!
That Loch Ness thing almost sounds like the lyrics to an RL Burnside song.
www.hellonurse.com
All of this advice says that it can't be done. I've seen a number of bar modifications like this before. Hopefully someone out there has advice not involving funeral homes.
Maybe I should just eat some spinach and bend them by hand.
Retrogrouch in Training
Bad scene, dude.
Do it with heat and you anneal as mentioned. On the other hand, alu is prone to snapping. It can't be cold set the way steel or ti can.
And they're not this shape to begin with because it puts the arms across the chest which constricts your breathing. Not what you want in a TT or pursuit.
Chronic Tai Shan
Tree fiddy
Traffic shark
Bikes: 2 fixies, 1 road, 29er in the works.
You can go to your local metal supply place and get some AL welded. I have had things such as this done for the Jeep. AL is hard to weld, so you'll have to pay out the nose ring.
Or you could get some lightweight tubing and have that bent and all.
Total Hack
My cheapo chuck's bullhorns are bent inwards. I always found it a little tacky looking. I guess it's functional though.
Chronic Tai Shan
Traffic shark
I'll disagree, welded AL if done right, can be decent. But very few will even try.
