Can i put drops on a Schwinn High Plains?
Touring Enthusiast
Bikes: 23" Schwinn High Plains, 20" Trek 830 Antelope
Quoted: 22 Post(s)
Hi gang -
I've acquired a Schwinn High Plains (Cro-Mo frame!!!!), but i'd really like to have drop handle bars on it......
I know the brake grips would need to be changed, but is there a way to do this without having to switch out shifters?
Thanks!
Thanks!
Lover of Old Chrome Moly
Quoted: 143 Post(s)
Liked 23 Times
Not really. MTB shifters don't generally fit drop bars so your options are to get brifters, stem or downtube shifters. The GMC Denali had a mickey-rigged setup for its grip shift on a drop bar, but that's Denali.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Yeah, unless you want to cut and reweld your handlebars , consider using Shimano A050 shifters. They'll mount to road bars and play nicely with the 7-speed rear you have on your Schwinn.
Quoted: 111 Post(s)
Liked 213 Times
You might want to peek at Thrifty Bill's thread on mtb drop bar conversions:
https://www.bikeforums.net/showthread...ar+conversions
Touring Enthusiast
Quoted: 22 Post(s)
So, i'm seeing that if i'm committed to this conversion, then i'd better plan on;
1) buying a drop-handle bar
2) buying bar-end shifters (and necessary cabling)
3) buying new brake calipers (and necessary cabling)
4) some sweet handle bar wrap
Is this it?
Any suggestions on the following (less expensive is, at this stage, better!!!!);
1) a drop-handle bar?
2) bar-end shifters (and necessary cabling)?
3) new brake calipers (and necessary cabling)?
4) handle bar wrap?
Again, thanks sooooo much!!!!
Location: England, currently dividing my time between university in Guildford and home just outside Reading
Bikes: Too many to list here!
There won't be any need to replace the brakes, since you'll be buying new levers either way, you can get drop-bar brake levers that are compatible with conventional cantilever brakes or with V-brakes depending on what your bike has. Either way, Dia-Compe make some good ones that won't break the bank.
As for shift levers, you'll almost certainly want Shimano ones, since they seem to be the only ones commonly available. If you get the 8-speed ones, they should index with a 7-speed or 8-speed Shimano cassette with a Shimano MTB derailleur, unless Shimano has messed with its indexing standards again...
Liked 2,568 Times
I'll throw in another plug for the A050 shifters and be on my way. They're nice for keeping the shifting at the top of the bars.
Quoted: 1074 Post(s)
Liked 295 Times
If all you want is a more aero position to tuck into occasionally, consider drop bar ends. Shifters and brakes stay where they are, drop bar ends bolt on like regular bar ends. A bit of bar tape and you're all set.
Adding a couple of aero brake levers would be a modestly challenging task, probably involving some shimming.
And do look into "travel agents". They allow regular road brake levers to be used together with v-brakes. Depending on where you do your shopping, it might be a cheaper course than buying v-brake compatible drop bar levers.
I somewhat doubt they'll be cheaper, when these v-brake levers are available for the same price as the Travel Agent.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Again, if you are anywhere near a co-op, start there first!
Many of my parts come in the form of a complete bike, one that might have a trashed out frame, or some other defect, but with a really low price. I'll strip it and repurpose the parts, or just donate them to the co-op. Either way, they end up putting bikes back on the road.
Please don't confuse ebay "asking" prices with "selling" prices. Many sellers never get their ask price. some are far from it. Value is determined once an item actually SELLS. Its easy enough to check SOLD prices.
You gonna eat that?
For the bar-end shifters, I recommend picking up a pair of Suntour Barcons. They are not indexed so they can be used with any derailleur/cassette setup. They have a ratcheting feature when you pull the cable to get a bit of overtravel for shifting, then settling down into a good spot. For relaxing the cable, they are pure friction. I've got them on two bikes and they work fine. You have to pick them up used; they haven't been made for years. I would check the Classic & Vintage For Sale listings and eBay. Expect to pay $30-60 for a pair of shifters.
EBay listings.
EBay listings.
I stop for people / whose right of way I honor / but not for no one.
Touring Enthusiast
Quoted: 22 Post(s)
So much great info!!! Thanks everyone. I'll be checking into these solutions and hopefully find something that i can manage for my old 'steelie' High Plains.
Did you use the A050 shifters shifters?
My shifters are shot and I need new ones. I also need new brake controllers. Did you replace your OEM ones or can anyone suggest replacements for a High Plains.
I am building it into a touring bike.
Touring Enthusiast
Quoted: 22 Post(s)
As you can see in my Signature, I'm also planning on metamorphosizing my High Plain into a touring bikes as well.
Mechanic/Tourist
Wow - I'm not in favor of something that puts one's hands so far from the brakes at any point, especially if it encourages remaining there. It's the same problem as was present with stem shifters. There is no position that gives one less steering control and grip on the bars. I'd want to at least put them further out.
Bikes: Schwinn Continental, Schwinn Paramount, Schwinn High Plains, Schwinn World Sport, Trek 420, Trek 930,Trek 660, Novara X-R, Giant Iguana. Fuji Sagres mixte.
Quoted: 35 Post(s)
Liked 22 Times
I put drop bars on my High Plains:
P4170270 by galoot_loves_tools, on Flickr
P4170263 by galoot_loves_tools, on Flickr
More detail here:
https://www.bikeforums.net/classic-vi...l#post15522956
More detail here:
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Thats an *awesome* thread - thanks leftthread!
Is this it?
4) handle bar wrap?
Is this it?
4) handle bar wrap?
More detail here:
More detail here:
what exact stem and handlebars you are running. Also was the stem an exact fit to the HP fork?
Quoted: 35 Post(s)
Liked 22 Times
Handlebars are 42 cm Nitto randonneur bars. The stem is a Dimension 35 degree rise 90mm threadless stem on a Velo Orange quill-to-threadless stem converter. I got the handlebars for the incredible price of $5 at a bike swap. The bar end shifters are Suntour friction barcons.
Liked 2,568 Times
We can't hold everyone's hands forever.
Try something like this.
Amazon.com: Origin 8 Bicycle Drop Bar Ends, Black: Sports & Outdoors
They're not real drop bars but at least they look the part. I don't know how they feel in use though.
retro-rider/mech
Bikes: 1983 Zullo road bike, 1994 Trek mtb, late 90's Trek road bike, 1977 Schwinn LeTour III, and my latest project, a 70's something "Suncrest" road bike
High Plains
More detail here:
More detail here:
Back in the early 80's Cannondale did the same to one of their touring model I remember right it was the T1000 .
Quoted: 35 Post(s)
Liked 22 Times
