freewheel hub conversion
Old 08-27-12 | 11:59 PM
lem0ndrider's Avatar
I am upgrading the group on my Lemond and I was wondering if anyone can help me. I have ordered a set of shifters which are 10 speed as well as the rear & front derailleur. I have discovered my cassette is a 8speed Sora free hub (I think) and cant find a 10 speed replacement. Reading the forums I get the impression that I will have to replace the rear hub to be able to put on a 10 speed cassette, is there any other way or will I have to bite the bullet?
Thanks
lem0ndrider is offline
Reply
Old 08-28-12 | 01:15 AM
dddd's Avatar
Ride, Wrench, Swap, Race
15 Anniversary
No, you don't need a new hub!
A 10-speed cassette will fit your hub just fine. There is a thin spacer in the cassette package, so look for the directions as to whether it should be used.
Even one of the 11t cassette sprockets will fit your hub, hyperglide-C compatible! Not that you would want an 11t necessarily.
dddd is offline
Reply
Old 08-28-12 | 04:17 AM
Kimmo's Avatar
Never mind the directions, just see if it's necessary by trying the cassette on without it. If you can tighten the lockring without clamping down on the cogs, you need the spacer.
Kimmo is offline
Reply
Old 08-28-12 | 07:04 AM
You certainly don't need a new hub as any 8-speed Shimano freehub will also accept a Shimano 10-speed cassette. AFAIK, all Shimano 8/9/10-speed freehubs require the 1 mm spacer behind a 10-speed cassette. Only the rare 10-speed only hubs can do without the spacer.
HillRider is offline
Reply
Old 08-28-12 | 07:31 AM
himespau's Avatar
Titanium Club Membership
15 Anniversary
Community Builder
Well, unless it's one of the first generation dura ace 10 speed cassettes, right? Or am I remembering those wrongly? Still, the odds of someone upgrading from 8 to 10 just now having one of those laying around is probably rather small.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?), 1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
himespau is offline
Reply
Old 08-28-12 | 07:36 AM
The odds of it being a 10-speed only Dura Ace (7800) hub are zero since the OP said it was a Sora 8-speed hub.
Reply
Old 08-28-12 | 07:40 AM
himespau's Avatar
15 Anniversary
Community Builder
Oh, it was the hub that was weird not the cassette? I thought the cassettes were also odd and that there might be some of those cassettes still floating around. Still not likely though.
himespau is offline
Reply
Old 08-28-12 | 08:19 AM
I took the cassette off and noticed there isn't a free hub on my wheel. I have included some photos if someone could identify it for me and tell me what to order.
Thanks again
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Reply
Old 08-28-12 | 09:09 AM
CACycling's Avatar
Bikes: 2009 Fuji Roubaix RC; 2011 Fuji Cross 2.0; '92 Diamond Back Ascent EX
You removed the freehub with the cassette. Put it all back together and remove just the cassette lock ring (will take a lock ring tool and a chain whip).
CACycling is offline
Reply
Old 08-28-12 | 09:57 AM
Thanks, I was a bit worried there
Reply
Old 08-28-12 | 10:35 AM
That doesn't look like any Shimano freehub body I've ever seen. I guess Trek (LeMond) used a proprietary hub, probably labeled "Bontrager". The cassette is indeed a Shimano but the hub isn't
Reply
Trentkln27
Bicycle Mechanics
6
08-22-16 09:23 AM
ghostm42
Bicycle Mechanics
5
06-27-16 10:46 AM
Oil_LOL
Bicycle Mechanics
3
05-22-11 04:53 PM
Dstreelm
Bicycle Mechanics
7
03-23-11 02:36 PM
jfinkly
Bicycle Mechanics
3
12-05-09 09:45 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
