Drop the stem or leave space (New 735 Build)
Old 08-29-12, 08:14 PM
Hey all,
So I'm slowly building up my new 735 as parts flow in and today I got my cups in. I left the fork uncut because I wasn't sure How much to cut and what for. I wanted to ask what are the benefits if any for running the stem flush or with 2 spacer or say maybe 1 1/2. Does it make you more aero dynamic by putting you lower in the bars? Take a look at the pics and let me know your thoughts.
File Type: jpg
File Type: jpg
Blackguyrides is offline
Old 08-29-12, 08:18 PM
seau grateau's Avatar
Quoted: 1332 Post(s)
Liked 398 Times in 194 Posts
Leave yourself at least an inch under the stem to play around with fit.
seau grateau is offline
Old 08-29-12, 08:20 PM
Your cog is slipping.
Scrodzilla's Avatar
Quoted: 640 Post(s)
Liked 100 Times in 58 Posts
You can't dial in your fit based on looks.
Cut your steerer so you can assemble it with about 40mm of spacers beneath the stem (the maximum for a carbon steer tube) and 5mm on top, ride your bike, dial in the stem height, then cut your steerer again if necessary.
Scrodzilla is offline
Old 08-29-12, 08:40 PM
Yea I know... I'm not concerned about the look I'm just curious about the stack height. Is it mainly because of comfort, aerodynamics? I'm going to throw some wheels on it at the shop, ride around and see how it feels tomorrow.
Old 08-29-12, 08:50 PM
Bat56's Avatar
Quoted: 47 Post(s)
Liked 4 Times in 3 Posts
RULE #45// SLAM YOUR STEM.
A maximum stack height of 2cm is allowed below the stem and a single 5mm spacer must always – always – be stacked above. A “slammed down” stack height is preferable; meaning that the stem is positioned directly on the top race of the headset.
Bat56 is offline
Old 08-29-12, 09:09 PM
It's about fit and riding position.
Old 08-30-12, 10:05 AM
Bikes: Schwinn Madison, Windsor Dover
Sorry for not knowing but I have to ask - why is this?
bfloyd6969 is offline
Old 08-30-12, 10:24 AM
Scrodzilla's Avatar
Quoted: 640 Post(s)
Having nothing to do with those stupid "rules", it keeps your stem making full contact with the steerer. This is especially important on a full carbon fork.
Old 08-30-12, 11:40 AM
THE STUFFED
Leukybear's Avatar
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times in 17 Posts
Don't do it. Completely illogical to eliminate one entire axis of fit adjustment especially when you've not even had the bike between your legs. Even then so, you're kind of cornering yourself by doing this.
Leukybear is offline
Old 08-30-12, 11:49 AM
Robofunc's Avatar
Bikes: Schwinn, Bottecchia, Miyata, projects
More stack height is more comfortable / less aerodynamic. There's a point at which being aero isn't as valuable as being able to endure the ride. You've got to find what you're comfortable with. Do long rides to dial in the fit--you find out more about your position when you're forced to maintain it for longer periods.
Robofunc is offline
Old 08-30-12, 12:39 PM
Fresh Garbage
hairnet's Avatar
Bikes: N+1
Quoted: 352 Post(s)
Liked 26 Times in 18 Posts
+1
slam dat stem
hairnet is offline
Old 08-30-12, 02:51 PM
I understand - and that makes good sense, thanks.
Old 08-30-12, 03:35 PM
Bat56's Avatar
Quoted: 47 Post(s)
I have warned you before. You are going to be punished in the afterlife for your blasphemy.
Bat56 is offline
Old 08-30-12, 03:53 PM
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
carleton is offline
biciklanto
Road Cycling
22
06-29-14 04:40 PM
casjr2171
Bicycle Mechanics
4
07-16-13 10:01 AM
miker2012
Road Cycling
32
05-04-12 05:12 PM
cyclekolo
Bicycle Mechanics
9
03-18-10 07:27 PM
Chandne
Road Cycling
15
01-25-10 09:08 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
