Taking corners quickly and tire sizes: questions
Quoted: 5 Post(s)
Hi, I'm a bicycle newbie, and wanting to get some advice from the seasoned vets. For various reasons, I frequently need to take a corner quickly, which involves leaning to the side to not crash (I've wiped out a couple times on gravel, that was no fun). My question is, for more lean and quicker, sharper curves, which is better: knobby tread on a 2" wheel, or knobby tread on a 700cc wheel? I always just assumed 2" tires would corner better since they have more traction, but now I've started to wonder if my assumptins were wrong all along.
Thanks much!
Thanks much!
Pro level handling skills and they go down mountains on 1 inch wide tires.
knobbys only on the dirt..
sticky tread compounds are low milage wearing.. so there is that trade off..
Bikes: 2000-something 3 speed commuter, 1990-something Raleigh Scorpion
You're not comparing the same thing- 2" is a tyre width, 700C is a nominal wheel diameter. Tyres for 700C wheels come in a range of sizes, just as they do for 26" wheels (or any other diameter.)
Quoted: 551 Post(s)
Liked 277 Times
Taking corners with knobby tires on what type of surface?
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Contact patch is what's important. If you're on the road, then the smoothest tire for a given size will have the best traction.
Taking fast corners on a gravel surface? You might try praying a lot.
Quick turns on gravel is like riding on ball bearings. I don't think any tread design is good for that.
They use steel sole shoes as a ski, on the inside leg, foot down,
cornering fast on Dirt races on tracks on Motorbikes ..
the boot becomes a ski
and as an indirect thing ..
at least the leg is not trapped under the bike ,
when the traction goes.
Speedway MC, i dont think even have a peg on the left side.
Quoted: 67 Post(s)
Liked 83 Times
To the OP, on pavement, slicks always have more traction than knobbies.
Quoted: 5 Post(s)
Sorry, my OP was unintentionally unclear (grin). I ride 90% of the time on pavement. But there's times where a bike trail will have gravel on it, or I'm forced to go up on a narrow sidewalk or have to swerve into dirt. I always just assumed that knobby treads were the better choice. But now you guys are saying slicks give more traction? Wow. I've been riding ignorant then.
My other question is, do narrow or wide tires corner better?
Thanks again, really happy to hear your advice!
How about you slow down instead? A 1/2 mi stretch of my commute is perpetually covered in leaves and nuts, it slows me down a lot. Leaves, nuts, and gravel lubricate the surface and that stuff is especially bad when wet. Wet leaves are downright dangerous even if they're not hiding a big hole underneath.
Bianchi Goddess
Quoted: 2925 Post(s)
Liked 2,921 Times
Thanks much!
Thanks much!
Knobbies + highspeed + fast sudden turns = crash or at the very least poor handling. If your riding a mountain style bike on the road get some slick tires.
Sugar "Kane" Kowalczyk
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,201 Times
Most people haven't developed the skills necessary to handle this kind of situation and probably will crash when you get to the end of the knobs. I'll go further and say that most people don't have the skills necessary to handle any kind of sideways slide of the rear tire and only a very, very, very few are going to be able to handle a sideways slide of the front tire. Mountain biking on dirt goes a long ways towards learning how to handle a bike in all kinds of situations.
There are too many factors to say that a wide or narrow tire corners better. The road surface, debris, water, ice, sand, lean angle, pedal loading, etc all contribute to whether or not a tire is going to get you around a corner. Tire width is way down the list and almost unimportant. Knobs give better traction in some situations...dirt and snow...while slicks give better traction in others. Most people choose slick tires for efficiency rather than because of traction issues.
Cornering technique plays as large a role as does the type of tires you use. Bikes don't turn corners like a car does. A bike banks a corner like a plane does (the Wright brothers were cyclists first). Because you bank the corner, you need to treat it a little differently. A bike is also a lightweight vehicle with a high center of gravity which is just about the middle of your chest which also means that you treat it differently from a heavier motorcycle. First, as you enter a corner, you need to push down hard on the outside pedal and the outside handle bar. This puts the most pressure on the inner edge of the tire and keeps it pressed down into the surface.
Next you want to lean into the corner but you can't lean over at the exaggerated angle that motorcyclists can. You don't have a huge weight...aka the engine...keeping the center of gravity low. You'll find that you can lean the bike way over but you have to keep your body more perpendicular. Pressing on the outside pedal helps. Scooting back on the saddle puts more weight on the rear wheel and keeps it from sliding out from under you.
The very best thing you can do for learning how to handle a bike is to use your mountain bike like it was intended. Ride it off-road. First it's fun. Next it will teach you more about how to handle the bike in an hour than you'll learn in years of road biking.
Stuart Black
Stuart Black
Quoted: 67 Post(s)
Liked 83 Times
Every day a winding road
Agreed. I was on a group ride where a man died because he tried to take a corner to quickly. He could have easily passed the turn and circled back to get on the ride route but he chose to make the turn at a high rate of speed. He did not make the turn, crossed through a parking lot, hit some kind of obstruction and flipped over his handlebars, crushing his skull. He was wearing a helmet.
There is no need to take corners "quickly" for any average cyclist and especially a newbie cyclist. Racers will take corners at a high rate of speed but sometimes they pay the price too.
Quoted: 67 Post(s)
Liked 83 Times
Cornering quickly may not be necessary, but it sure does feel good. Also the skills to corner quickly are similar to the skills needed to swerve to avoid something, so it serves us well to practice em.
Liked 4,201 Times
I don't buy your story that the guy crashed because he was cornering too fast. It sounds to me like he was doing something else thing wrong if he had enough speed to cross a parking lot and hit an obstruction and flip over his handlebars and crush his skull. Was he going 80 mph? His brakes weren't working? He fell asleep? Reading War and Peace? You make it sound like he traveled a good long distance before meeting his untimely end with plenty of time to do something.
Stuart Black
Stuart Black
How not quickly do your think someone should corner? 5 mph? 1 mph? 15 mph? I have roads in my area where I can easily hit 50 mph and it's not straight. Do you suggest that we all slow down to 5 mph to go around every corner on this road? I agree that there are times to be prudent about speed and cornering. But you don't need to corner slowly all the time
Normal bends in a road is not a corner in my book. A T intersection is a corner. Taking intersection corner at 50 MPH is insane. I'm not going to suggest a speed just to say to take the corner at a prudent speed. There is no reason to push the limit.
He tried to take the corner too fast. That was what the ride organizers reported as the cause of the accident.
It would not be possible for him not to be paying attention. If he did then he would have gone straight and not made the turn.
Liked 4,201 Times
Everyone would be better served by knowing at least a little about cornering and how to go around a corner at a high(er) rate of speed so that they can do it if they find themselves in a situation where they are going faster than they normally would. It happens and is far better to know how to handle the situation than not.
You weren't there. I was. Are you suggesting I am lying?
I also know from my own experience, that the usual result of a missed turn at a high rate of speed involves a whole lot of bike and rider sliding on the pavement because the bike tends to slide out from under the rider. Being upright and losing control of a bike are usually mutually exclusive.
On the other hand, if he "missed" the turn but could have gone straight and not made the turn, what was all this business with wondering around the parking lot? If he'd gone straight, wouldn't he have ended up in the same parking lot?
If you are relying on ride organizers as to the cause of the accident, people make mistakes and report things that just can't be all the time. If you actually witnessed the accident, just how fast was the guy going?
Stuart Black
Stuart Black
I was not more than an hour behind the accident. The ambulance went by me.
There was an intersection. He tried but couldn't make the turn to the right. He is now dead because he thought he could make it. If someone got in his way, skidding on gravel, oil, lost concentration at the last second or whatever the reason doesn't matter. What he actually hit doesn't matter. He is dead all for a casual ride. Had he slowed before the corner or passed the intersection most likely he would be alive today.
Had he gone straight he could have simply slowed, he probably had a mile or two of straight road so there was way more than enough road on which to stop safely.
Those are the facts.
Too many "Lance wanabees" on a casual ride with people of all ages and abilities is one of the reasons I no longer do that ride.
I am actually surprised more children have not been hurt on that ride at the speed some riders ride, close passes and the number of pelotons. I guess one advantage of them being fast is they get out in front of the kids. Plus the kids are riding the shorter course could be another reason no one has been hurt by a rider,
Cycle Year Round
Tire pressure and skill are big factors in cornering.
For the skill part
https://www.seanbujold.com/coaching/Cornering.pdf
For the skill part
Land of the Free, Because of the Brave.
Liked 4,201 Times
Sorry but which facts are those. They seem to be shifting.
So you are going by what someone else told you.
Stuff happens. People make mistakes. People fall in bath tubs and die. People fall off ladders and die. People crash on bikes and die. People crash in cars and die. People handle venomous snakes and die. The frequency of each one of those events is rather small compared to the number of people climbing ladders, taking baths, riding bicycles or driving a car. (If you are going to handle venomous snakes, you're just asking for it.) Should we all just sit home and hope that nothing happens? Don't take baths or climb ladders if you do so. Whatever you do, don't get in your car!
There are other alternatives. There's your method of not using ladders, bath tubs and riding your bike at nothing above walking speed. Or you could learn how to use a ladder properly, make the tub less slippery and learn how to control your bike. I put the guy's death down to a mistake and/or a lack of ability. If you make a mistake, do your best to survive it and if you have a limited ability, learn more about how to ride.
Or just sit at home and wait. Death will find you there too.
Stuart Black
Stuart Black
Liked 4,201 Times
I was thinking more about spinnaker and my dragging of the thread off the topic and, as soon as I clarify something, I'll apologize and get the thread back on track.
I think spinnaker is misinterpreting the accident in the classic "Eats. Shoots. And leaves." manner. I suspect that the incident report on the accident went something like the rider failed to notice the turn and overshot. He then crossed a parking lot to get back on the course and hit an obstacle in the parking lot where he was thrown from the bike. Basically he did what spinnaker suggested and went straight, slowed down, crossed the parking lot and failed to notice something...likely a curbstone...and crashed. Tragic, yes. But unrelated to the corner or to riding around a corner.
I'm sorry to have drug this thread off the tracks and would like to get it back on them. cosbike1, if you are still out there, one of the best things you can do to improve your cornering is to look where you are going. Many people think this is obvious but they don't do it. Most people...whether they are in a car or on their bike...look just in front of the vehicle. By which I mean a few feet. Get in the habit of looking further down the road. Think of bicycling as a giant chess game where you are planning your moves 10 moves in advance. Look down the road...I usually look down the road about 200 yards...and see where the corners are coming up. Recognize what gravel looks like and plan your turn accordingly.
In mountain biking, we have a trick to not look at what we are trying to avoid. If you see a rock in the middle of the trail that you need to go around, you are likely to hit it if you stare right at it. If you look further down the trail and plan your line, you'll more likely avoid the rock because you are aiming at something else. It works in road biking also. However, if you have skills that have been honed on loose surfaces like mountain bike trails, if you do hit a patch of loose stuff, you'll know how to handle it. A mountain bike sliding sideways is just part of the fun.
Stuart Black
Stuart Black
Quoted: 5 Post(s)
Thanks for the tips, Cyccommute. Also, these stories are scaring me just a bit. I'd rather be cautious than end up breaking something. I think I'm still a little confused on the relationship between tire traction and the leaning aspect. I think wiping out on the gravel made me think about the physics all wrong. But thanks to you guys, I've decided to change from commuting on knobbies to investing in a quality pair of road slicks with traction!
Liked 4,201 Times
Stuart Black
Stuart Black
[QUOTE=cyccommute;14767954
[/QUOTE]
You're wrong. That is no where near what happened I saw the intersection and where he landed. Had he gone straight and not tried to make the turn he would have been able to slow and barring any other future accidents or health issues he would be alive today. Why can't you just accept that?
[/QUOTE]
