identifying creaky noises?
I think it is my seat on the rails making noise
im right at 290lbs and every time i pedal i get a creaking noise from the bottom bracket/seat area
i can't really tell where---sometimes it seems as if it is coming from the fork as well
how to tell where it is actually coming from
how to tell if it is something that is going to eventually fail--to correct it?
suggestions?
ideas?
suggestions?
ideas?
I had a creaky noise too. I stood up and pedaled and the noise went away. It was my seat.
Sheldon on diagnosing noises: https://sheldonbrown.com/creaks.html
2nd Amendment Cyclist
Bikes: Schwinn 2010 World Street, Handsome Speedy w/ SRAM Apex
I had a creaking noise;
the noise went away
it was my saddle (in my case, I had to tighten the tension on my well-worn Brooks).
Check out Sheldon Brown's Guidelines.
Quoted: 18320 Post(s)
Liked 15,299 Times
Yeah. Start with taking off your saddle, cleaning out any corrosion, putting it back on tightening everything up properly.
got the climbing bug
Bikes: one for everything
Quoted: 632 Post(s)
Liked 908 Times
light grease the following, inside seat post clamp, saddle rails, front and rear wheel drop outs
Rule #10 // It never gets easier, you just go faster.
Quoted: 5219 Post(s)
Liked 3,564 Times
my creaking is always my BB. over the years I have replaced the BB on 3 bikes and I have 1 more that is gonna need it if I ever ride it again. after you rule out everything else, do not fear the BB replacement! :-)
