KHS aero geometry?
ready for the freakout
Bikes: Spicer track
KHS aero geometry?
anybody know where i can find the specs for the old sloped-top-tube KHS aero? and no, they're not on the website. i'd like to know how the geometry changes with a 700c wheel as opposed to a 650c. those of you who own one, get your rulers out!
Bikes: GT Pulse Track, 93 Bridgestone XO-1 & 93 RB-1, Ritchey Swiss Cross, Ritchey Road Logic, Yoshi Konno/3Rensho Specialized Allez, Cannondale Slate, Cannondale SuperSix EVO/Disc and Cannondale Hooligan
Quoted: 39 Post(s)
Liked 143 Times
Is there a variety of 650C tires to choose from?
Would, could, you utilize a high flange hub?
* https://www.epinions.com/bike-Bicycle...ay_~full_specs
switching to guns
Bikes: allez fuji tracku nishiki TT GT KHS arrow Miner 29'er CIOCC Corsair and now a f*cking awesome waterford skeet velo
is there not enough clearance for the 700? I've got a similar frame and was tryna get the pros/cons of various wheels sizes.
(dont feel like running the Terry wheel atm)
Quoted: 39 Post(s)
Liked 143 Times
My real concern is getting the appropriate rake in regards to frame size. Hence, the original request/need for geometry.
what year is yours because mine is an '01 and I think that the angle is a little less aggressive than the ones from the 90's.
Quoted: 39 Post(s)
Liked 143 Times
This (bellow) is the response I received from genec@khsbicycles.com.
KHS aero flite 100 geometry
**Date:
1/25/2005 1:43:01 PM Eastern Standard Time
"Gene Cliatt" <genec@khsbicycles.com>
**To:
<F1apex@aol.com>
**Reply-To:
Thank you for your email. After searching everywhere I could think of, all I
could come up with is: head and seat tube angles are both 74º, 22 mm fork
offset, 425 mm chainstay length, 981 mm wheelbase. I wish I could be of more
help but that is all I could find.
Best regards,
Gene
**Date:
**To:
<F1apex@aol.com>
**Reply-To:
Best regards,
Gene
Bikes: Spicer track
**Date:
**To:
<F1apex@aol.com>
**Reply-To:
Best regards,
Gene
**Date:
**To:
<F1apex@aol.com>
**Reply-To:
Best regards,
Gene
perfect. thanks.
I have KHS aero track with sloping top tube. I can't give you numbers, but I can tell that when a 650 cc wheel is put on; angle get steep, very steep. I put one on to get rid of the pedal overlap, but the drop was way too much. Anyways that wheel is for sale....so if you do decide to switch, let me know. It's used once...24 spoke, radail laced A-class 650cc w/ tire and skewers. Hope that helps.
asleep at the wheel
Bikes: Custom Richie Ditta Track Bike, Eddie Merckx Corsa, Marioni Custom Pista, Dolan Cyclocross
Larger SF LBS seem to have one or two tires at most, though most have tubes. Most of the large online retailers have them.
Oh and stay away from Kenda tires, sounds like they're not the highest quality. Mention this as theres a 650c version of this tire.
https://roadbikereview.com/wheels/tir...4_2489crx.aspx
switching to guns
nashbar also sells a 650-sized 1" straight fork too iirc
