Origani bikes - How good are they?
Hi folks:
Im considering an Origami bike for purchase. The model that draw my attention is the Mantis. Has anyone here had any experience with this bike? How upgradable are they? Is the quality of the components that come with the bike good?
Thanks in advance for your comments.
You should read this thread:
https://www.bikeforums.net/showthread...Origami-Mantis
The OP discusses his Origami Mantis.
This is the spec sheet for all of the Origami models to include the Mantis:
https://www.origamibicycles.com/specs.php
The only components listed by brand are the tires, (rear) derailleur and shifter.
Bikes: Origami Gazelle, Origami Crane 8, Origami Cricket 7
Quoted: 452 Post(s)
Liked 405 Times
What components do you a question about?
Paul Pinigis
Owner of Origami Bicycle Company
Paul Pinigis
Quoted: 151 Post(s)
Liked 10 Times
i haven't seen it mentioned here yet, but i think the origami fox is probably the best bike they make. it would be even better if they offered it with premium components. i would buy one for sure.
Bikes: Too many....................
Quoted: 11 Post(s)
Liked 11 Times
You can always upgrade the Fox to your liking.
Speed Uno
Dawes Kingpin 2speed
Speed Uno
I was holding off to give the OP first dibs on this question, but it doesn't look like he/she is going for it, so I'll chime in. I'll start by saying that I like the Origami line and look forward to seeing the company's evolution. So I make the following recommendations b/c I genuinely think they would be beneficial, not to be offensive:
1) I would split the current specs page into two tables; one for weights & dimensions, and a second one for the actual component specs
2) Try to give each component listed at least some detail beyond construction material. For example, the tire listing is great b/c it gives the brand and measurements, but the hub section just says "aluminum".
Speaking of the hubs, is the front one normal (100mm) width or the narrow "Dahon style" 74mm?
Quoted: 452 Post(s)
Liked 405 Times
[QUOTE=
Speaking of the hubs, is the front one normal (100mm) width or the narrow "Dahon style" 74mm?[/QUOTE]
The hubs are standard 100mm.
Paul Pinigis
Paul Pinigis
jasonjeremiah
General Cycling Discussion
11
01-01-10 08:25 AM
