Hey all! Keep snaping axles
Bikes: 2007 Trek 3700, 2007 DK General Lee
First post, site looks awesome.
Well, I have a 2006 Trek 3700. I keep snapping/bending the rear quick release axles. I ride dirtbikes quite often, so I enjoy rough trails HOWEVER my trek's cheapness is killing me. Is there a more rugged bike out there that I could get on a budget that has solid axles that can take more of a beating? Craigslist special? Or... can I replace my axles with solid ones? I know my bike is all show no go, cheap parts bottom of the line but there has to be another option or something I can do... local bike shop recommended a $2200 freestyle/downhill hybrid. SCAM.
Riding style: I do dirt road riding, very little tar ridding, lots of woods, single track, a few jumps here and there nothing serious.
Thanks!
Thanks!
Really Old Senior Member
Dol you have a Free Wheel or free Hub?
If Free Wheel, you'll either bend or break them without much effort.
https://sheldonbrown.com/free-k7.html
I suspect freewheel hub..
Freehubs have wide axle support.. if you are breaking those, you have problems beyond the scope of talk, here..
get to a Bike Shop.
Freewheel? rebuild around a Freewheel hub From California made
Phil Wood, in San Jose.or Pauls in Chico,, both sealed bearing hubs have very strong
axles..
I used a Phil FW hub on my Touring bike on many Bike tours with full camp load.
though on the cheap budget interim a solid axle and nuts are made matching the thread of QR ones
cant ride with you to know how hard you are on stuff.
you may be OK or trash those too..
get to a Bike Shop.
axles..
Bikes: Kuota Ksano. Litespeed T5 gravel - brilliant!
Thanks!
Thanks!
You could end up breaking rear axles on a full suspension bike for all I know.
Quoted: 19 Post(s)
Liked 7 Times
Do the Formula hubs have a freehub with the axle fully supported by bearings at each end?
Some cartridge bearing hubs place the driveside bearing inboard of the freehub, leaving a lot of axle hanging out unsupported, ready to bend and break.
All Shimano hubs have a fully supported axle with bearings close to the ends. They solved the issue of bent axles for tourists in the 1980s. I don't think you need to go all the way to a Phil Woods hub, any low end Shimano (eg Altus FH-RM30) will be fine.
Old fart
Quoted: 3582 Post(s)
Liked 3,394 Times
Afrothunderkat, Welcome to the forum.
Your 3700 is spec'd like my sister's Trek Skye. A really good and proven frame, but down market components that aren't really up to the task of rough mountain biking. You can have your rear wheel built with a Shimano LX or XT hub or look on the internet for a replacement wheel.
Learning how to "ride light" is also important, basically use your legs as shock absorbers when you land. What is your weight?
Brad
Brad
Quoted: 2026 Post(s)
Liked 1,095 Times
Quoted: 513 Post(s)
Liked 445 Times
The 3700 is a fine bike for commuting and light off-road use. That is, cinder paths, fire roads, and maybe some slow and easy singletrack.
Bikes: Specialized Sequoia Elite/Motobecane Fantom Cross Team Ti/'85 Trek 520
That bike is NOT a mountain bike in the sense that you are using it. Like others have said, it is designed for light offroad use like smooth gravel, pavement, streets that might not be paved all that smooth, that kind of thing. If you are doing jumps and rock climbs or downhill runs or anything remotely like that, you will kill the bike.
I also suspect that it has a freewheel and freewheels can hardly handle the stress of an abused bike that is being used for tasks far above its abilities. Freewheel wheels are fine for light duty use or smooth commuting but not for hard core mountain biking, otherwise you WILL break/bend axles.
Thank you all for the responses, seems like I need a new bike as I purchased the 3700 when I didn't know much about quality components.
What would be a good budget bike? Common bike that I can find on craigslist?
The problem is that the riding you are doing/describing doesn't bode well with cheap bikes. HOwever if you want to go the CL way, I would look for an older high end rigid/hardtail mountain bike from the '90s. Something like a Specialized Rockhopper/Stumpjumper. Those were pretty good strong mountain bikes that have nice sturdy chromoly steel frames and should have fairly decent components. If you wanted to buy new, for the riding you are describing, you would not want to spend much less than 1000-1500. Anything less costly but new will probably not be up to the task of jumping, rough off roading, etc. You mentioned your riding and said "nothing serious" but your riding does sound pretty serious.
Bikes: Click on the #YOLO
Quoted: 26 Post(s)
Liked 12 Times
I really get a kick out of looking at craigslists across the country.
The online retailers sometimes have entry level wheelsets with Shimano freehubs and decent rims for a good price. I got a set from Performance for $119 with 525 hubs and Rhynolite rims.
If the 3700 has a freewheel hub you might need to upgrade your rear shifter to an 8 or 9 speed and buy a cassette and new chain.
Or, you could just find the chrome moly steel solid axles that Niagara has and use one of those. It would still need periodic replacement. I personally feel a slight preload on the cone adjustment helps them last but some others seem to disagree.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
I would just try to find a used 7-speed cassette MTB rear wheel. If that's the only part that's breaking, you don't need a whole new bike. At least yet.
RUSA #7498
Originally Posted by noglider
Guest
Bikes: I never learned to ride a bike. It is my deepest shame.
Liked 6 Times
+1. A new replacement wheel with an 8 speed cassette body (will need a spacer to make a 7 speed cassette fit) can cost less than $100. Since the OP has only indicated that he has problems with the rear axle, and not snapping forks and handlebars and seatposts, I would think the rear axle is the only part of the bike that is truly insufficient for his use.
Guest
Liked 6 Times
Bike is from 2006. Very very unlikely to be 126mm spacing in that frame. Probably 135 mm.
good bike will be starting, new at $500 at your Trek dealer,
since you have one that sold what you have.
Dual suspension, double that $..
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12736 Post(s)
Liked 7,647 Times
I'm with thermionic and gsgt, just get yourself a nice wheel, or even wheelset +1 spacer + 7-speed1 cassette. Rim brake wheels continue to get rarer but are still around. I bend/snap solid or QR axles on 7-spd FW setups all the time, the rest of my almost-as-lowend Trek 4000 was up to the task, tho.
Having friction shifting and a newer cassette wheel
the 8th cog instead of the spacer filling in the width is another option..
sort it out when you take the bike in to the Bike Shop to have the dropout alignment checked.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
I agree with the above; your cheapest option is to spend maybe $100-200 on a rear wheel and 7-speed cassette (or 8-speed cassette, replacing one cog with a spacer, or just leave it on and know that one of your cogs never gets used!) Others at this forum are better qualified than me to talk about 7/8-speed cassette/derailleur spacing/compatibility.
For a CL option I would take a look at mountain bikes on your local CL for $200 and up. You'll want to aim in maybe the $400-600 range, or you can probably even do well in the $200-400 ballpark, but looking at the wider range will help you get familiar with what is better or worse than your target. Post some proposed CL links here, somebody will drop in, take a peek, and give you an opinion.
But I totally agree, $2200 for a brand new downhill bike? If you have $2200 to throw away, fine. But there are so many ads on CL that start with "I bought this really awesome bike and thought I was going to ride it a lot, but...". Don't be that guy, take advantage of that guy. Don't pay retail for a new bike from a store, pay half or less for a "new" bike off CL.
