Converting LX 8 speed Triple from bar ends to Brifters/Road Brakes-shifters
Bikes: 05 Specialized Hardrock Pro, 2000 Bianchi Axis, 2015 All City Nature Boy
I have a 2000 Bianchi Axis. I originally set it up with 8 speed Deore LX trip front and LX 8 speed rear with Shimano Bar End Shifters. Finding that I did not like shifting my hands from breaks to shifters, I converted it to flat bars with Mt bile breaks and Tiagra shifters. Now I want to switch back to drops. Problem What model Shimano road brake-shifter units will work with an 8 speed set up and a triple top pull front derailleur. Thanks for the help!
Easiest to find (and cheapest) approach at this point might be Campagnolo Veloce 10 speed brifters.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
For a more detailed explanation of what I posted above:
https://beta.ctc.org.uk/cyclists-library/components/transmission-gears/derailleur-gears/shimergo
Edit: Hmm, not sure the new powershift left shifters play nicely with mtb FDs.
Are you suggesting getting a bottom pull? If so, now we are talking routing problems. I'd like to avoid using a pulley to redirect.
That article seems to suggest that the veloce shifter will work with your current FD, but I've also heard people say that the newer Campy left shifters have fewer clicks and don't work as well with this as they used to. Haven't tried it yet myself, so I can't say for sure. Might be worth a try. You can usually get veloce shifters from the uk sites (like ribble) for less than $100 with cables included.
I think a number of people over in the classic and vintage forums have tried a shimergo setup, so if you ask for advice there with shimergo in the title you might get people with actual first person experience instead of my hypothetical what I've read theories.
I'm using the 10S Veloce shifters on an otherwise Shimano 8-speed bike right now and I love it. FWIW I'm using an old XT front derailer (bottom pull) shifting a 42/53 Biopace double! It works perfect. Only reason I'm using the XT is because that's what I had laying around.
Collector of Useless Info
If you use Shimano-compatible front brifter, then the cable pull ratio will be wrong for the front derailleur- MTB and road groups are incompatible in the front. But, you can use an 8 or 9 speed brifter in the rear while keeping the same derailleur- but if you use the 9-speed brifter on an 8-speed cassette, you'll need to do the "alternate cable routing" trick.
Top pull or bottom pull- the cable pull ratio is the same in the Shimano MTB groups.
Google Retroshift. You can use your existing barcons and attach them these.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Or Kelly Take Off if you want an alternative.
But if, if you want brifters, Campy Veloce seems the way to go.
Bikes: 8
There is an 8 speed brifter still shipped on the Lower tier road bikes, new.
Example: "Shimano 2300 STI, 8 speed," (as I cut and pasted from Trek site)
Breaks are broken, Brakes, are what slows you down.
FordTrax
Bicycle Mechanics
7
02-16-19 08:28 PM
bobotech
Bicycle Mechanics
14
05-05-12 07:14 AM
