700cc to 26"??
700cc to 26"??
i found a nice cyclocross bike on ebay and was wondering if i could change the wheels to 26" if i ever had to change or replace them.
would there be a problem, besides the v-brakes? would it work if i switched to disk brakes?
thanks!
-g
thanks!
-g
WHY? N+1.. Don't like it as is?, sell it and Buy the Bike You want,
[ Or if this is another Pre worry, and you didn't win the Bid, stop ]
rather than do those changes .. it's a fool's mission.
The Recumbent Quant
Cheers,
Charles
Guest
Bikes: I never learned to ride a bike. It is my deepest shame.
Liked 6 Times
Changing the wheel size may be possible but it is likely to change the handling of the bike, and result in increased pedal strike from a too-low bottom bracket.
What is wrong with the 700C wheels? 700C is the standard size for CX, touring, road bikes, hybrids, and 29ers. You have practically unlimited tire choice (limited mainly by the clearance in the frame and forks), and the bike will work as it was designed.
What are you hoping to accomplish with this change?
Also, what model of CX bike is it and does it have mounts on the frame and fork for disk brakes?
Guest
Liked 6 Times
I very much doubt you could use 20" wheels on a bike designed for 700C... 26 inch wheels would possibly work OK, 24" would likely put the pedals very very close to the ground, and 20" you would only be able to pedal 60 degress at a time to 'ratchet' the bike forward. Brakes are not the only consideration.
The Recumbent Quant
Cheers, Charles
Constant tinkerer
V-brakes? No. Disc brakes, it would work but what are you trying to accomplish? As stated a smaller overall tire height will change the handling and make the BB lower.
Bikes: Kuota Ksano. Litespeed T5 gravel - brilliant!
A 26" wheel sporting a 1.75" tire has an axle height of only ~.5" difference to a 700c wheel sporting a 28mm tire. These sort of difference aren't significant enough to impact handling. It's about the same as moving from a 23mm to a 35mm tire on a 700c wheel assuming you had the brake and frame clearances.
Bikes: Cannondale Supersix Hi-Mod / Scott Spark 930 / Scott Sportster 20 / Jamis Allegro 2.0
yea but that 559 -47 tire wont fit in a CX frame,
made for a 622-32 tire, particularly the fork.
fool's errand ..
go get a hundred yard spool of waterline while you are at it.
fool's errand ..
Location: England, currently dividing my time between university in Guildford and home just outside Reading
Bikes: Too many to list here!
Sections of an old rim - I mitred them to fit across the fork blades and seatstays in the same kind of way that kickstands do, drilled out a spoke hole on each one to admit the centre bolts on the brakes, then bolted them in place with the centre bolts. The brakes are BMX sidepulls, but the levers are absolutely massive, so I can pull them by the ends and the braking's OK. The bits of rim stick out a couple of centimetres each side, so I put duct tape on them to reduce the chance of them killing me if I ever crash the bike. I need to do something less bodged when I next get the chance, I might cut the canti bosses off and move them down to the right height if I can borrow a stick welder.
I don't feel too bad about cutting and welding on the frame, it's a BSO that was donated to the co-op, and it's severely rusted. It was in the "scrap pile" when I found it. The 20" conversion was mainly to see if I could. It works, and who the heck's gonna steal it?
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
The Recumbent Quant
Possibly the OPer doesn't want his reasons debated. I'm not sure I'd want that either.
The Recumbent Quant
Cheers,
Charles
The angle doesn't change if you're lowering the rear and the front equal amounts. Maybe I misunderstood what you said?
Pretty sure OP wanted to know about potential problems and in order to answer that the reasons for the modification, or purpose of the modification is needed.
harpon
Living Car Free
3
02-22-13 11:00 AM
