Bike pump for arthritic hands?
Bikes: Jamis Trail X2
Looking for an air pump for my mom, she's unable to clamp/unclamp my old one, much less handle the up/down motion. Some mornings she can barely move her thumbs but she loves biking the streets and seeing her neighbors.
Does anyone here have a suggestion or three for an (automatic?) arthritis friendly pump that she can use to fill her tires. Would make an excellent Christmas present for her
Thanks in advance
JKLaud
Thanks in advance
JKLaud
Bikes: 2012 Trek DS 8.5 all weather hybrid, 2008 LeMond Poprad cyclocross, 1992 Cannondale R500 roadbike
I am thinking that one of the electric air compressor pumps -- used with a Schrader valve / adapter (Or however you spell it! -- You know! one of the big fat ones that you just stick the nossle on...) I only have the manual floor pumps -- but I would think Sears or an auto parts store would have some nice electric ones...
And, by the way, Good Job on choosing your parents! If you are part of the 50+ forum and have a mom who is still riding, you chose your genes well....
Humvee of bikes =Worksman
Quoted: 10 Post(s)
Liked 6 Times
From your post I'd guess that Mom is having difficulty getting the hose fastened to the tire valve which is really the hard part for injured or older hands. If this is the case I know of no easy solution to help Mom. Sorry...........
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
I use a CO2 inflator. I think they're great.
Dharma Dog
Bikes: Rodriguez Shiftless street fixie with S&S couplers, Kuwahara tandem, Trek carbon, Dolan track
I don't have an answer, but this is the kind of engineering question that needs to be asked! My own personal peeve: I think one of the big failings of most frame pumps these days is that the lever that locks the chuck onto the valve is usually so close to the pump shaft that it's impossible to lift it with thick winter gloves (or even wearing any full-finger glove!). I guess the designers never think of stuff like this.
I think that one of the great product designs in the past 10 or 15 years has been the "rabbit" style wine bottle opener. Just three motions uncorks the wine and drops the cork, and in far less time than using the sommelier's corkscrew.
Thinking of this corkscrew, a good pump chuck would not press on; it would clamp on and provide a total seal while you pumped, then release with the push of a button. I would imagine the clamp levers being long enough that you could push them in with two hands (so thumbs wouldn't be required).
As far as the pumping motion, I could see the chuck just being clamped to an air hose attached to a compressor or a pressurized tank. Or even to a foot-operated pump.
Luis
Luis
Edit - Thanks all for chewing this over, this has been bugging me for awhile now since I have to stop by twice a week just to check her tires
Liked 12 Times
Interesting solution, thanks - Any idea on the weight it would add? She can barely lift the front wheel up over her front porch step as it is and she's too stubborn to let me build her a ramp
If all she is riding is the neighborhood and to friends, they should do OK. If she is going to take longer rides - then I would not use them.
But, the 2 x's/wk checking her tires does give one a chance to say "hello!" I would think.
Bikes: Cannondale t1, Koga-Miyata World Traveller
That is the gift.
Not a silly pump.
All this stuff about tire pressure is hooey.
My 26 x 2 " tires stay hard enough to ride for several months.
The 700X38 tires on my other bike stay hard enough almost as long.
I assume your mom isn't doing any time trials, or competing in the senior games so you really don't need to pump her tires twice a week (If you really do, I'd put in some new quality tubes)
But continue to touch base with your mom twice a week. She will appreciate that far more than hard tires.
Not a silly pump.
That is the gift.
Not a silly pump.
Not a silly pump.
I don't have an issue with killing an extra 20minto check her tires but I'd like to know that if I'm NOT available on a day that she's low that she can pump it herself without it being an issue to/for her thumbs
Agreed - We make it a point to watch Grimm and American Horror every week and I swing by there to vacuum and mop her house simply because she's unable to. I have YET to understand her fascination with Fabuloso, stinky stuff IMO
Remember to take care of your mom -- you only get one and she's the one who changed your stinky, dirty diaper... The least you can do is pump up her tires now and again...
And, it is GREAT that she is still riding. It will help to keep her strong and fit so that you two can spend quality time together instead of that of care-giver and care-taker...
... I suspect that there are MANY mom's out there who wish that they had a son like you...
Bikes: Volagi, daVinci Joint Venture
Find the pump with the easiest check lever and provide a short pieces of PVC or conduit that fits over the lever.
Procrastinateur supreme
Since you're doing the vacuuming and mopping and whatnot, why not just install some new tubes - maybe ones with the goo stuff already in 'em. They should hold air a lot longer, and you can spend more time with your loved ones.
I'm starting to have a similar issue with my dual-head older style Joe Blow pump. Starting to get pretty hard to twist - lock it. Dang handle is too small to get a firm grip on it.
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
What about a CO2 inflator for her type of valve stem with the cartridge loaded and ready? She can use a simple guage if she needs to check the pressure. Just a suggestion from an addled mind.
Bill
Bill
Semper Fi, USMC, 1975-1977
PVC, I like it. A bit of polyurethane to cement it in place and she'd be all set with an electric pump from the LBS - Give me a large enough lever and I can move the world, (or something to that effect).
I'm aware that Slime tubes (reportedly) help seal punctures but she's not getting flats. This is just air dribbling out over time as normal, I'm thinking she'd have to deal with that regardless.
Thanks again for all the replies, much appreciated
Quoted: 960 Post(s)
Liked 1,627 Times
CricketUSA
General Cycling Discussion
35
08-24-19 10:53 PM
the sci guy
Bicycle Mechanics
23
08-05-13 05:11 PM
