Bought a Yuba Mundo
Cyclist
Quoted: 39 Post(s)
Liked 16 Times
Bought a Yuba Mundo
Well, I finally bought a Yuba Mundo. The owner's manual, seventeen pages joined with a staple, seems to consist mainly of warnings, with a few cautions thrown in, among which I thought the following particularly interesting:
"Never carry other riders or packages" !!!
"When braking always apply stronger braking pressure to the rear wheel . . . . If the front brake pressure . . . is applied too strongly or quickly, the bicycle may flip forward." I find it hard to believe that a bicycle as long and massive as the Mundo could flip.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
Generic manual? Cycling is extremely dangerous.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Bikes: Brompton M6R, Salsa Mukluk II, Trek 7500, Raliegh fixie, 3 SS cruisers, JC Higgins Color Flow, Junker Flying Jet, KHS F20-A, Worksman trike
In the situation described in your owner's manual, I don't think they were saying the Mundo would flip over your head if that is what you were thinking. But there is a good chance that it will flip to your left or right side in the right set of circumstances. In less extreme circumstances you will likely experience this as the bike doing a "shimmy" from side to side when you stop.
Bikes: 1998 Bontrager Road Lite, 2005 Trek 9.8, 2008 Santana Arriva Tandem w/ S&S Couplings, 2009 Electra Rat Rod, 2010 Bike Friday Pocket Rocket, 2010 Cannondale SuperSix, 2011 Cannondale CX, 2011 Cannondale Tandem, Xtracycle, Surly Pugsley Necromancer
No, it's simple physics. If you brake the front wheel more than the rear, the rear wheel moves faster than the front wheel and try to move around it, especially if there is more weight on the back. It's like a car braking on ice and then fishtailing, or a rear wheel drive car going up a hill on ice and stepping on the gas, which results in fishtailing. Trust me on this, I'm an engineer. If you know anyone who is a professional truck driver they will tell you basically the same thing. With the big trucks, they cannot even maintain the same speed going up a hill on ice because they will fishtail (although moving at the same speed, power is applied to the rear wheels going up a hill to maintain a constant speed, and the power that the rear wheels have but the front wheels don't have means that the rear wheels try to move in front of the front wheels). On ice, big trucks have to use the momentum of the downhill run to carry them up the next hill so they don't have to step on the gas. It's basically the same principle with stopping a cargo bike, in less dire circumstances of course. The rear wheel can't have more energy than the front wheel or it will find a way to move ahead of the front wheel, which isn't good.
By the way, later in the Mundo manual they do mention that braking too hard w/ the front brake could cause the rear wheel to lift off the ground so I think when they warn of flipping the bike they are referring to endo'ing.
Disclaimer: I too am an engineer (or enginerd depending on your perspective).
Quoted: 317 Post(s)
Quoted: 70 Post(s)
Liked 15 Times
Aaron
Quoted: 317 Post(s)
Ok, maybe I had a tendensy to drive on "not so studded tyres".
When I was young I used to go fast with my horse and a long low sledge behind it. Since it was lighthly loaded (me) it would fishtail a lot. Great times.
Quoted: 70 Post(s)
Liked 15 Times
First snow fall regardless of car I was always the first into the mall parking lot to have fun on the made to order skid pad.
Aaron
On a loaded longtail or a tandem, it is often possible to skid the front wheel (almost certain to cause a crash) before the rear wheel lifts. On a half-bike the rear brake is only a backup on pavement, but with a long wheelbase you need to use it to stop in minimum distance.
