Chainstay Cable-stop Routing Question
What is the correct way to route the cable through the chainstay cable stop in the picture below? I've seen a couple like this and its not really a stop.
The brazeon is narrower than the housing, but this obviously isn't right:
That type cable housing stop is requiring a stepped down ferrule that fits inside.
Cinelli Diving Helmet type . I have some I used for a frame I built in the Mid 70's.
if you want to use those housing sections seek some that are Big enough to fit
in the larger end.
those are what I used ..
got a favorite Boston bike shop to go and seek those out?
in the larger end.
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
... be considered corrected young squire.
back to OP, here is one type :
https://www.sjscycles.co.uk/stepped-c...of-4-prod5267/
Mechanic/Tourist
As in this case it depends on the diameter of the stop. If it's small enough you do need a step-down ferrule. In fact, by itself that's not really a stop, and it may be there for a double function, such that it could be used as a guide for full length cable housing.
Thanks fietsbob, I've seen those, I'll go call up my local shop.
What I meant by it not being a stop is that the front and rear of the brazeon are the same diameter, so there isn't anything to stop a normal ferrule or housing. The stepped down ferrule would do just that. And in general with SIS cable housing you should always use a ferrule. The cable guide on the BB is for cable w/o house, so not full length housing.
Liked 2,560 Times
Quoted: 5703 Post(s)
Liked 2,430 Times
This is a Campy cable stop.
Ideally it takes a specific stepped ferrule with a which provides a very tight fit and ensures perfect ferrule/housing alignment.
Less ideally, but still important you can use any stepped ferrule that fits, but it may not resist the tendency of the housing to sit at an angle to the cable line.
FB
Chain-L site
FB
Chain-L site
I use some of steel, stepped down ,
then the Typical brass housing ferrule sits within the larger end.
As to which C, Mine were made by Cinelli , as was the BB shell..
Have those on several bikes. Seems the SS cable housing without the vinyl coating fits perfectly. The old days of bar end shifters used this housing and I do believe that piece was designed to fit that type of housing.
Pikka Bird
Bicycle Mechanics
16
04-30-11 06:11 AM
