Old-School Gearing Question
Bikes: Diamondback Apex/GT fork (modded)
I just got finished paring back my 5-speed freewheel from 14-38 (Kansas City hills gearing) to 14-28 (high plains gearing). I had even considered 14-24. BTW, I used Mike Sherman's Bicycle Gear Calculator to decide on the exact gearing - it's fast, and informative of any gaps in the gearing - goodbye semi-log paper and gear charts.
My old PX-10 is set up with Huret Duopar rear and Huret front derailleurs. The Duopar did very well on the 14-38, actuated by a Suntour indexed barend shifter - it works! I also have a Sachs-Huret ECO S rear derailleur, and there is a 24 and 28 tooth position for the tension spring, so it should be good to go on the 14-28. My question concerns the chain-wrap capacity. The front TA crankset is 30-46-50, so does the ECO S have sufficient capacity for that? Maybe someone on this forum can tell me.
if not a long cage RD, get one . friction shift, no specifics,
just a long distance for pulley to pull back when extra slack.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Is it this guy? https://www.velobase.com/ViewComponen...108&AbsPos=179 There are other Ecos and DuoPars on Velobase under the Sachs and Huret names.
Yeah, thanks! I looked up the ECO S on the www, and it wraps 31 teeth max - not enough. The Duopar is a bit bent, sooooo, since I already have Suntour barends mounted, I'm going to try a Suntour on the rear. I've got these:
7-GT
XC Sport 7000
Accushift -4050
The biggest factor against them is that Suntour rear derailleurs are not at all compatible with Simplex dropout mounts. The PX-10 came with Suntour when I bought it second-hand, and it made wheel changes a challenge. I might try some sort of quick-release skewer...
7-GT
XC Sport 7000
Accushift -4050
Liked 2,563 Times
I can tell you that the a-4050 won't like a triple, either. I tried running mine with a 52/42/32 triple and 14-28T freewheel and it didn't have nearly enough capacity.
The 7-GT should get the job done, though! https://www.velobase.com/ViewComponen...108&AbsPos=393
Hey, I recall that to get more chain wrap out the Simplex L.J. Super I once had on the PX-10, I replaced the short alloy cage with a long steel cage from a Simplex Maxy. I wonder if I could make another Frankenrailleur out of the two Hurets? Crazy...
Quoted: 1572 Post(s)
Liked 643 Times
In real life you might not need as much slack take up capacity as the calculations suggest.
Do you use all of your freewheel gears in combination with your granny chainring? I certainly don't. The only time that I use my granny is on steep hills and only in combination with my biggest couple of rear cogs. If I never shift into the 30/14 combination, I don't need enough slack take up to handle that combination.
Quoted: 2026 Post(s)
Liked 1,095 Times
Location: western Massachusetts (greater Springfield area)
Bikes: Velosolex St. Tropez, LeMond Zurich (spine bike), Rotator swb recumbent
Quoted: 67 Post(s)
Liked 67 Times
I know where Retro Grouch and HillRider are coming from. I looked at the chart of my gearing, and realized that for practical purposes I had five speeds on the 46-tooth chainwheel, plus an overdrive on the 50x14 and an underdrive on the 30x28. That is how I intend to use it anyway.
MikeWMass suggests that I Dremel a place for the "B" screw of a Suntour derailleur, but I still have the problem of the Simplex mount lacking threads (and I think the hole is too big to tap anyway), and the threads of the Suntour are not long enough for a nut on the other side. I still see a quick release, perhaps a seatpost skewer as the answer if I go Suntour.
Sixty Fiver
Classic & Vintage
41
07-02-10 10:27 AM
