Old Campagnolo BB trashed. What are my options?
Come on, 5 more minutes..
Bikes: At last count... 31. 11-19-22.
Liked 13 Times
Doing some much needed maintenance on my old Trek 560 Pro.
BB started making noise this summer, and now I've got some time during off season to tear into it.
Here's what I found!
Looks like all pieces are shot.
Found a few options on E*Bay to replace it exactly as it is, with an identical Campagnolo 68-ss 114mm BB.
And will check with my LBS to see if hey've got some old stock laying around. You never know....
What other options do I have: Ultegra, DA, UN55, etc.?
It currently measures @ 114mm. I'm only finding 115.5mm to be the next closest available.
Will I encounter any problems going to a 115.5mm?
Thanks for the advice.
Quoted: 2026 Post(s)
Liked 1,095 Times
One problem, other than spindle length, is that Campy and Shimano don't use the exact same taper geometry. The taper is the same 4° included angle but the end dimensions vary slightly with Campy (ISO taper) being slightly smaller than Shimano (JIS taper). So, installing a Campy crank on a Shimano bb will not allow it to travel as far up the taper as the correct spindle. That said, many users have reported good results with this mix-and-match. The 1.5 mm length difference of the 115 mm bb should not be a problem. However, Shimano did make a 113 mm spindle length in their BB-UNXX cartridge style bottom brackets and this may work well too if you can find one.
Bianchi Goddess
Quoted: 2927 Post(s)
Liked 2,922 Times
Hello Grasscutter. What CampI crank is this? a Nuovo/Super Record type? Unfortunately your options are very limited. You need to use a CampI BB (esp the spindle) because the size/angle of the taper is different from the Japanese ones. Depending on what year your crank is from there is also a difference in the CampI spindle because the CSPC rules changes in '78.
If this is a daily rider I would recomend (and use myself) a Phil Wood BB. They can be pricy but are bullet proof and as you have seen not much pricier than a good old Campi BB.
Post a pic of the back of one of your arms showing all the markings and /or check the vintage trek site to determine the year of your crank.
Sugar "Kane" Kowalczyk
Quoted: 1854 Post(s)
Liked 663 Times
One issue is that with spindle replacement it's often true that matching length is not enough - the length of the drive side is important.
There are many threads on matching tapers or not matching, I'll let you look it up at Sheldon Brown, since I dont' believe in taking chances with high-end vintage parts.
But I can confirm what spindle you can use, and will offer you mine if you can use it.
Phil Wood BB's offer the same axle type square taper, 1 of their 3 axle types made..
I've used Phil BB's on older Campag cranks, for many years..
The others are JIS, (all the shimano brands you listed) and the current ISO.
the Phil will do the job perfectly.. interior mounting rings*
just need the different Spline fitting tools, they make, to install them.
*[add touch up paint on the BB shell ends]
Liked 13 Times
Yeah...
Just discovered the taper issue. Some say its negligible. Others disagree.
My Trek 560 Pro is a 1986.
Doubtful many of the components are original, as it came to me many years ago, quite mismatched.
Have made upgrades as parts wore out.
So, I'm OK, with upgrading cranks and gearing, if needed, while doing the BB service.
Here's what I'm working with so far:
Years ago, I swapped out 6 speed freewheel for a 7 speed, the original cluster and chain were toast.
Added low end Shimano 7 speed brifters.
Here's 2 pics of the crank that came with it:
Teeth look 'OK', is about it. With a chain replacement on my to-do list, maybe now is the time for sprocket upgrades too?
Ideally...I'd be stoked to do an even better upgrade to 8-9speed.... Although with 126mm rear spacing, I realize the limitations.
Get the Phil BB and restore , want modern klick shifter stuff, more 'speeds', go N+1 with a whole new bike.
Bikes: Gios Compact Pro 10 Chorus, Gios single speed, Pedal Force RS2 10 chorus, CAAD5 10 Centaur, Diamondback dirt bike, Fuji Fixed Gear.
Phil Wood is the best way to proceed
Bianchi Goddess
Liked 2,922 Times
OH You have a Mavic crank? that is a whole different story and may change your BB otions. Check this site https://velobase.com/ViewBrand.aspx?B...0aa8cef&From=T for information on what BB should be used with that crank.
I don't really like the look ofthe taper holes on that driveside arm. Can you post a better pic? maybe a straight on view? Let me see if I can scrounge up some old Mavic data around here.
I am with Bob if your dreaming of 8+ speeds with fancy click shifters a good "new to me" bike may be a better/cheaper option.
Retro Grouch
Bikes: Yes
Liked 13 Times
Here's a cpl more attempts to show detail on the square taper.
Backside looks nice and square. Front has areas where the fixing bolt threads rubbed on the spider.
Pics aren't the best, and not sure if this is still an issue.
<<<I looked up the Velobase description and all it says is an ISO 116mm spindle. Since there is no indication if that is a symmetrical spindle, which it most likely is not, the OP will need to measure the end to race and race to race to determine the size for his crank.>>>
Enlarge on this, please.
Liked 1,095 Times
Many bb spindles are assymetrical, that is the drive side projects father from the shell face than the non-drive side to allow more room for the spider and chainrings.
You need three measurements from your old spindle; 1)the over all length, end-to-end, 2) the distance from the drive side bearing track to the drive side end of the spindle and 3) from the non-drive side bearing track to the non-drive side end of the spindle. If 2) and 3) are the same, the spindle is symetrical, if they are different, it is not.
If you get a Phil BB, not only is it adjusted somewhat with the Lock rings, as neither shoulder
against the frame BB shell face.
But it, also, can be pressed sideways through the bearings ,
as the axles have no interior shoulders,
and rely on the precise matching of the bearing ID and the spindle OD.
by that fact you can change the offset ... I have done so, myself,
nothing more than the 2 mounting tools, a flat washer, [span the opening on the tool],
and the bolt that holds the crankarm on as a press.
an adjustable wrench to hold the square , and a crank bolt wrench to turn the bolt.
bolt pulls the spindle through the bearings.
Surely Omaha Has a Bike Shop to go to to get you the right parts..
If not Lincoln would, colleges have more bike Use.
Campag 68SS120 is 112 long, [ for 5 speeds] in the catalog #17
track is shorter, triple and Cross use a longer one.
... there is also the specifics of which one, as there are 2 cup types
and a co-reponding axle for each .. thicker cup has rifling spirals
to expel grit without a contact seal . bearing races in the axle are thus closer together.
bring what you have to the Bike shop and they will call Up Phil and Co.
or get thru one of the distributors they do business with.
problem solved. top shelf .
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
You could possibly go with smaller name BB, such as Gipiemme, Zeus, Omas or Ofmega
Bikes: '86 Cannondale SR400, '86 Pugeot PX10, '92 Bianchi Axis, '95 Bianchi Campione d'Italia, '00 Fondriest X-Status, '08 Specialized Roubaix, '13 Cannondale CAADX
I recall that Velo Orange has some bottom brackets, with quite a variety of lengths and spanning English, Italian, and a fe other configurations in ISO tapers. I just stuck one on my kid's old Nishiki.
bummer, the VO website seems to be taking the week off...
To restore to C&V status, The #610RD BB Mavic Made for those necessitated chamfer milling the frame, inside the BB Shell.
Retro Grouch
Bikes: Yes
Quoted: 443 Post(s)
Liked 27 Times
Why hasn't anybody mentioned that a Phil Wood BB will cost at least $150? That has always kept me from considering them.
Bikes: '07 Trek 520, '09 Gary Fisher Triton, '04 Trek 8000, '85 Trek 500, '84 Trek 610, '85 Trek 510, '88 Trek 660, '92 Trek 930, Trek Multitrack 700
Quoted: 19 Post(s)
"When I hear another express an opinion, which is not mine, I say to myself, He has a right to his opinion, as I to mine; why should I question it. His error does me no injury, and shall I become a Don Quixot to bring all men by force of argument, to one opinion? If a fact be misstated, it is probable he is gratified by a belief of it, and I have no right to deprive him of the gratification."
T. Jefferson
T. Jefferson
Quoted: 443 Post(s)
Liked 27 Times
Or you could buy three of these and use the change to buy the tool.
https://www.cycleclubsports.com/p-457...FSFyQgod-2oATA
Bianchi Goddess
Liked 2,922 Times
B-girl, the OP's state is really unchanged with the Mavic crank it, like most European cranks, use an ISO taper; that would explain the OP's bike having a Campy BB. I looked up the Velobase description and all it says is an ISO 116mm spindle. Since there is no indication if that is a symmetrical spindle, which it most likely is not, the RP will need to measure the end to race and race to race to determine the size for his crank.
I still think the Phil is the best option if this bike gets heavy miles, and I am even willing to lend my tools to him.
As for the cranks the holes seem to be nice and square it must have been the angle and slight bit of dirt and other stuff that made me think they might be askew.
Retro Grouch
Bikes: Yes
Liked 13 Times
OK. *whew*... lots of info here.
Today I searched e*bay and found this: https://www.ebay.com/itm/160945169962...84.m1423.l2649
Seems like its correct?
Would like to restore it to correct C&V, but not necessary @ this time. Plan is to do a correct restore within next couple years.
So...I'm not opposed to putting in a cartridge (temporarily). Giving me time to search for a better selection.
FWIW...and from what I find on vintage-trek, this bike originally came with Shimano 105. Then, when I bought it years ago, it was a mis-match @ best.
Maybe a cartridge is the best option for right now.
Hmm..
Anyways, here's some measurements I took today.
So, it seems the drive side is longer, correct?
Hmm..
There is a 115, here..https://www.philwood.com/products/bbpages/ssbb.php
