Bike Direct warranty service
Bikes: 2011 Surly Cross Check
Quoted: 18 Post(s)
Liked 6 Times
Based on several recommendations I saw on this forum, I purchased a Bikesdirect bike for my son for Christmas. Put it together yesterday while I was under the weather, and noticed the front derailleur was not looking so great. Upon further inspection today, it appears that the front derailleur shifter is not functioning properly. It won't stop on the middle chain ring, but skips from big to little. I now get to see how submitting a warranty claim goes with Bikesdirect.
Anyone have a similar experience?
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
That is a set up adjustment Not Warranty item.
Some buyers have a bike shop do the set up.
Fred "The Real Fred"
Quoted: 18 Post(s)
Liked 6 Times
Many thanks!!
As the others have mentioned I wouldn't be surprised if it's just an adjustment issue.
In the videos/articles rebel posted above, all will have you begin with the FD cable disconnected. When disconnected, before proceeding with the setup procedure, hold the cable fairly tight with one hand and activate the FD shifter with the other. You should feel the cable pulling and releasing to three distinct spots (assuming it's a triple like you alluded to). This will at least first establish that the shifter is indexing correctly.
The FD can be a little tricky but follow those procedures exactly and you should be fine.
Quoted: 18 Post(s)
Liked 6 Times
Ok, thanks all for straightening me out. I will give this another shot tomorrow when my son comes by.
Bikes: Vassago Moosknuckle Ti 29+ XTR, 90's Merckx Corsa-01 9sp Record, PROJECT: 1954 Frejus SuperCorsa
Quoted: 174 Post(s)
Liked 157 Times
I'd agree it sounds like adjustment, not warranty.
That's the tradeoff with BD - they offer excellent bang for the buck, but it helps to have some mechanical chops to do a set-up and tune. If you're not comfortable with that, a LBS should get your son's bike on the road.
The Rock Cycle
I got a Motobecane Fantom CXX bike from them last spring. The fork was defective, the dropouts were spaced nearly 2cm too narrow for the hub. Not something that can be bent back into the correct width. BD was speedy to pull a fork off another CXX bike and send it. When it didn't arrive after a while, maybe lost in the PO, they sent out a second fork. The first one finally did show up and the bike was built. When the second fork showed up they sent a call tag to send it back to them. I was happy with their customer service!
Gunnar Sport
Specialized Ruby
Salsa Vaya Ti
Novara Randonee x2
Jamis Dakar XCR
Gunnar Sport
Specialized Ruby
Salsa Vaya Ti
Novara Randonee x2
Jamis Dakar XCR
Randomhead
Liked 3,699 Times
is the derailleur damaged? That's what it sounds like from the first post. Ask them to pay for you to take it to a bike shop.
I would take any BD recommendation on forums with a grain of salt. You get what you pay for.
Quoted: 18 Post(s)
Liked 6 Times
The derailleur does not appear damaged. The shifter, at least as set up right now, will not shift from the big chain ring to the middle chain ring. It skips the middle one and goes to the small chain ring. Shifting from the small chain ring to the middle chain ring, and from the middle chain ring to the big chain ring work fine. That is why I think (thought?) the shifter is defective. I will get to take another crack at it tomorrow, and follow the posted procedures, to see if perhaps some sort of adjustment will fix it. Since the shifter itself does not have an adjustment I know of, not sure how this will work out, but I am game for taking another crack at it. It is good to know form the previous poster that if indeed the shifter is defective I will likely get another with little to no pain involved.
Quoted: 174 Post(s)
Liked 157 Times
Out of curiosity, what is the shifter? Is it a "brifter" (integrated brake/shift lever), or a trigger shifter (flat bar)?
Quoted: 174 Post(s)
Liked 157 Times
I can only base my recommendations for BD on personal experience, and in the 6-7 Bikes that I've either purchased (2) or have set up for friends (4-5), I've been impressed with the quality for the money from what I've seen firsthand.
Let's face it, Trek, Giant, and all of the other big bike companies do the majority of their fabrication in Taiwan and/or China these days, so all are susceptible to the same issues in fabrication, pre-assembly and shipping.
The distinction, of course, is the LBS factor (support, initial set up, etc) vs. ordering online and having to take any issues up with them via the webz. For many, the risk of any inconvenience is not a deterrent to saving alot of money on a bike - same applies for Nashbar and others out there. For those who are mechanically adept or do their own mechanical work, it is difficult to overlook the value that the online discount drop shippers are offering.
In this case, we'll see how it pans out. I've heard good things about BD's customer support, so if it comes to that, perhaps this case will be another "data point" for everyone's benefit.
Cheers
Quoted: 18 Post(s)
Liked 6 Times
Derailleurs Shimano Sora RD3400GS Triple rear, Shimano FD-2303 front
Shifters Shimano rapid fire 8 speed brake and shift lever
It is a flat bar bike, but the shifter and brake are integrated from what I remember, which seems to agree with the web site description. Of course the shifter in question is not a 8 position, but the 3 position one. Here is a picture of the handlebar setup:
https://www.bikesdirect.com/products/...laxy_tour_xii/
Quoted: 18 Post(s)
Liked 6 Times
Cheers
Cheers
I hope I am proved otherwise when I get a shot at it again tomorrow. Either way, I will let those interested know how it all pans out. All in all I was impressed at how easy the bike went together, and how little wheel truing and other adjustments were required right out of the box. Time will tell how high a quality the components are. For my son, I know he won't treat it right, so I did not want top end stuff anyway. I gave him the lecture about keeping it in shape, we will see if he changes his ways or not . . .
Quoted: 174 Post(s)
Liked 157 Times
All I can tell you about the setup is from the BD webpage:
It might be worth posting in the mechanic's sub-forum for some tips on troubleshooting, etc.
Quoted: 18 Post(s)
Liked 6 Times
I thought about posting there to begin with, but I did not expect the thread to become a repair thread, but more of a customer service thread. I find out more tomorrow on that one. Thanks for the feedback!!
Bikes: This list got too long: several ‘bents, an urban utility e-bike, and a dahon D7 that my daughter has absconded with.
Quoted: 363 Post(s)
Liked 66 Times
The closest thing they had was the Linus, essentially the same bike at, nearly, twice the price. However, when asked about set-up they said that they would un-box and assemble the bike for $50. I can even have it shipped to their shop (this is a useful thing because my daughter is living car free).
I am strongly considering asking them to put a front drum brake on it during set-up. This gives them an accessory sale (Where they make their money), leaves my daughter with a bike that has better brakes in the rain, and still costs less than the other options; it's a win for all.
Ask at your LBS about set-up even if you can not afford to buy the bike there.
Bikes: 85 Peugeot Canyon Express, 73? Torpado, 85 Trek 400
I had excellent results from BD for a bad shifter replacement so if it is a problem there shouldn't be any issues getting a replacement.
I no longer purchase bikes off the internet, not so much due to poor workmanship, but more about not being able to test ride a bike until one has paid for it and assembled it, a hit and miss operation at best.
Randomhead
Liked 3,699 Times
Just to clarify, I don't think you get less than you pay for either, at least from BD. It's just that they have to make their bikes cheaper than bike store bikes and they do it in ways that aren't obvious. And for many of their bikes, if they included competent assembly by a bike shop it wouldn't be any cheaper.
Sucks to be in your area in the way of not test riding, but my main concern is that one cannot even do a "hands on" test until one has already purchased and assembled their online bicycle, I'm sure that even the most stringent of LBS's will let a customer sit on one of their showroom models.
Quoted: 18 Post(s)
Liked 6 Times
My most recent purchase (not the bike I am talking about in this thread) I rode twice before I bought it. The first time for maybe 10 minutes, the second time. for nearly an hour. Had a friend test ride it also during that hour. Guess there are some advantages to living in liberal SoCal besides the weather.
Quoted: 174 Post(s)
Liked 157 Times
Since BD is really nothing more than a warehouse/freight forwarding operation, they do not share the same overhead costs that the LBS's have. Also, most LBS's are under strict rules for retail vs. discount operation (they can discount closeouts/prior year models), so they are a little hamstrung on how deep they can really go.
In the 80's I wrenched for a guy who started up a shop almost exclusively based on Trek closeouts. He'd buy up HUGE lots of prior year models well below normal wholesale pricing, and not constrained by retail agreements. He was able to price the bikes at 50%-70% or so of retail, and he made a killing doing this. His shop flourished and grew year to year, and he gradually added current year models as well as other brands, but his bread and butter remained with deeply discounting prior year closeouts. He had alot of out of state business, and bear in mind this was prior to the internet, so word got out.
Not many shops work on this basis, and typically stick with a retail (i.e. 100% markup on wholesale) model.
Quoted: 18 Post(s)
Liked 6 Times
The jury is in, operator error. Bike is riding sweet now, all is good. Thanks to those who pointed out the mis-adjustment possibility. I almost posted a very wise-crack type response to the first one, glad I did not. I learned, my son learned, and it all works before even hearing back from BD (suspect I will hear from them tomorrow).
Quoted: 174 Post(s)
Liked 157 Times
FWIW, it isn't a bad idea to verify that the cable housing ends are seated properly on both ends (for all cables - brake/derailleur) and that the housings are routed in a good way. This is easy to overlook when assembling a bike out of the box.
