How many balls are ideal?
Bikes: Giant Defy Comp 2, Specialized Rockhopper Hard Tail 29er
Sorry about the title. I'm really not trying to be funny.
I'm rebuilding a 1982 Trek 613. It has a Sugino bottom bracket with caged bearings. Each bearing has 9 balls.
I've heard, and it seems reasonable, that by replacing the caged bearings with 11 loose balls, it will be smoother and will last longer. There is no problem with the existing bearings, and there appears to be very little wear. This is just a routine servicing, but if I can gain any benefit at all by replacing the bearings, I'm all for it.
Also, is the Park Polylube a preferred lubrication for bottom brackets?
Thanks, everyone.
Thanks, everyone.
I always replace the bearing balls with new grade 25 balls. They are cheap and typically of better quality than what they replace.
Just about any quality waterproof grease is as good as another in a situation such as a bicycle bottom bracket. I use Park Polylube myself, but haves use marine grease from auto parts stores as well.
this is not intended to dissuade you from replacing your BB caged bearings with loose bearings, but reminiscing at a bit, i recall losing them in the chainstays
, down the seattube
and up the downtube
. i came the admire the cage after that...
they don't readily come out of the tubes with grease on them either.
to answer your question, i think i remember it being recommended to put in as many as you can and then remove one. in practice, i put in (when i was still doing this) only as many as patience allowed.
, down the seattube
and up the downtube
. i came the admire the cage after that...they don't readily come out of the tubes with grease on them either.
Ride, Wrench, Swap, Race
I always use as many as will fit. I've checked many headsets for example where there was a bit of running clearance even after fitting the full complement of balls.
Taking one out could lead to unstable bearing support and localized overloading in cases where the number of balls is small, such as in a hub or bb.
From: Rhode Island (an obscure suburb of Connecticut)
Bikes: one of each
[QUOTE=ColonelJLloyd;15169512]I always replace the bearing balls with new grade 25 balls. They are cheap and typically of better quality than what they replace. /QUOTE]
I got a bag of a hundred of these off Ebay to use on my keeper bikes. It wasn't expensive.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
I use phil grease, or marine grease from an tub. Put as many balls as will fit, if they are jammed tight take one out, if they are slack (about one ball space total) then you are good. I have had more than one cage break and make a mess, loose balls can be a PITA but I think they are better in the long run.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Thrifty Bill
11 per side, 1/4 inch bearings of course, + pick up a tub of marine grease at the local auto parts store.
Phil grease sucks, the oils seperate out and it dries out much quicker than almost any grease I've ever used.
I use red Mobile 1 synthetic in a tub for flip bikes and Dura Ace grease for my keepers. Dura Ace grease is the absolute best grease ever made for bicycle use.
Not really. I'm far more interested in the question about the bearing. The grease question was kinda' parenthetical. I was at the bike shop yesterday, and he was out of Phil's, so the question is really moot anyway. I'm sure a company like Park wouldn't put their name on a product if it wasn't at least very good.
Miamijim: I hadn't thought about the Mobil 1. I use it in my car, and I'm a true believer. That's a real possibility.
Oh......I'll be offline for a couple days. We're going to Las Vegas to celebrate our wedding anniversary, so let me thank all of you for your valuable opinions. They are all useful, even Captain Blight's.
Hopelessly addicted...
Bikes: 1949 Hercules Kestrel, 1950 Norman Rapide, 1970 Schwinn Collegiate, 1972 Peugeot UE-8, 1976 Raleigh Sports, 1977 Raleigh Sports, 1977 Jack Taylor Tandem, 1984 Davidson Tandem, 2010 Bilenky "BQ" 650B Constructeur Tandem, 2011 Linus Mixte
Curmudgeon
Bikes: (see https://wildavis.smugmug.com/Bikes) Bianchi Veloce (2005), Nishiki Cascade (1992), Schwinn Super Sport (1983)
I've always packed 'em until tight, and then removed just one, but in the light of recent news I'm thinking it might be an advantage to have two and lose one, especially if you're looking for sympathy and an excuse to be a rotten cheat!
Shame the bloody cheats! All of 'em!
- Wil (don't forget the Phil's Waterproof Green Gundge)
Bikes: Pinarello Veneto, Pinarello Montello, Bianchi Celeste
i take it something like this would be ok for replacements!?
https://www.ebay.com/itm/100-1-4-inch...item1e66bfe5e5
what does G25 mean, is that the hardness of the balls?
As I understand it, it has to do with the precision (roundness) of the ball. 25 is the best that is commonly available. In this case, 300 is not better, even though it sounds like it should be.
And the number of the counting shall be eleven, thou shall not count to ten and thou shall not count of twelve.
The grading number relates to how accurate bearings are in millionths of an inch so grade 25 is 25/1,000,000 which means they are very consistent... beyond this you get into ceramic which has no practical benefit on a bicycle but can be made to an even higher level of precision.
Really Old Senior Member
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Grade 25
Surface finish, sphericity (sp) etc.
You may find them cheaper at your local "power transmission shop" that sells hydraulic pumps, hoses, BEARINGS etc. when you factor in S&H. Else buy several 100 to amortize shipping.
My local "PTS" is a bit spendy on 1/4" size ($14?/100) and VERY inexpensive on the smaller sizes. You have to buy a "box" full. A box full of the smaller sizes contain a LOT of balls. IIRC, 3/16" size ($7/175?).
Bah.
Glenn
