Nishiki TT bike
Grease Monkey
Bikes: Schwinn LeTour, Giant TCR2, Fetish Cycles SAC Aero, Fixed gear Pursuit bike, Fixed gear Raleigh, Hoffman Momentum Flatland
Nishiki TT bike
hey guys, i just won this on ebay, literally about 10 minutes ago, what do you guys think of it? will it make a good fixed gear? was it a good price? https://cgi.ebay.com/ws/eBayISAPI.dll...tem=7133988184
Guest
S/F,
CEYA!
Better than you since 83!
Bikes: Fixed Gear 79 Schwinn Sprint
Originally Posted by Ceya
I think it is a decent frame. but finding tires for the front can be a problem. As a fixed gear, it can work.
S/F,
CEYA!
S/F,
CEYA!
Looks like a 6500c front, that shouldn't be too hard. Great deal, I'd say it's almost a steal.
Grease Monkey
edit: and i actually think its a 24" front, maybe not though
Guest
it looks like a 24'' wheel some are smaller than 650cc.
650cc looks more like this Yamamguchi bike. IMHO
S/F,
CEYA!
S/F,
CEYA!
S/F,
CEYA!
S/F,
CEYA!
Bikes: too many, all fixed
I have a nishiki funny bike that I fixed up. It was way small for me so I threw on a long stem and monkey bars. great bike for bar hoppin and skiddin. The 24'' tire is easy to find, Irc triathalon. Just find LBS that orders from Quality.
ya'll can't mush me
It's not necessarily the tire that's tough to find (you only need one or two to last a really long time), it's often decents rims/tubs/tubes readily available.
You won't have that problem much, though, given that it comes with a front wheel.
Stock up on tubes from Terry!
switching to guns
Bikes: allez fuji tracku nishiki TT GT KHS arrow Miner 29'er CIOCC Corsair and now a f*cking awesome waterford skeet velo
Matt,
Hell yea you got a pretty good deal. It's easy to run as a FG.
I've got the same one - definitely fun to ride once you get used to it..
Cornucopia of Awesomeness
I think I've found you a rim. Velocity aeroheads come in 24 x 1 1/8, black, clincher and 28-hole.
https://aebike.com/site/page.cfm?PageID=30&SKU=RM4450
Sun also makes the ME-14A in 28 hole, blackness
https://www.bikeroom.com/Itemdesc.asp?ic=RM1469 (note, canadian pricing)
Salsa and Quality make 24 x 1 1/8 tubes
though I haven't found a decent tire yet.
switching to guns
I got the black Sun ME-14A from Bikeworks. It's a good solid little wheel. Panaracer tire rolls ok, not crazy about the tan sidewall.
ya'll can't mush me
Originally Posted by baxtefer
hey, vomitron...
I recently got my front wheel stolen, and the pain of getting a new wheel has made me switch to 650c.
I built up a Velocity Deep V to a low-flange hub lying around my LBS. Threw on a carbon fork ($20. I'll probably swap it for something snazzier).
I still have NO pedal overlap (I'm about 4 inches away), and my new seat tube angle is 76.85 degrees, head tube is now about 72, and the trail is about 53mm. I'm thinking with a nice fork with less rake, I can get that number lower and have the twitchy handling I had before. Position is a little less aggressive (for longer rides), but still maintains all of the characteristics I liked about the 24" (I need to go on more rides to determine if I need a fork with less rake).
Also, I get to rock some smokin' looking tires. It even caused me to change the color scheme on my bike. Pictures soon to come!
Grease Monkey
alright, i talked to the previous owner, the wheel is definantly 24", any suggestions on a stem to use with this bike? it can't be to long, since the bike is already a little bigger than i am used to. also is there a certain kind of seat i should be using, or will the seat i am using now(a skinny selle racing seat) work fine? thanks!
edit: one more thing, are drop bars out of the question on this bike?
ya'll can't mush me
Any seat you have is fine. You might be tempted to tilt the nose down because it feels more comfortable at first, but realize that if you do that (to compensate for other things, like the saddle being too high, or your bars not being high enough), your hands are going to hurt on longer rides from supporting all of your weight.
Also, I would say drop bars are out of the question, unless you like things SERIOUSLY aero. Bikkhu rocks a pursuit bike with drop bars, but that's with a Look Ergostem, and 650c front.
Good luck!
Grease Monkey
so does anyone know where i could get some bullhorns/non drop bars for cheap? thanks
switching to guns
I use these, they work pretty good (25 bucks @ nashbar):
or vomitron can probably recommend a decent set of horns with a bit of drop like he's got..
or why not flip and cut down some old drops to start?
Grease Monkey
hey guys, bike(frame, and wheels that is) came in today and i couldnt wait to build it up, so i used a bunch of old parts in my garage to do so. i still need to convert it to fixed, but heres a picture if anyone cares
more pictures here
more pictures here
Grease Monkey
i couldnt get the picture to work in the other post, here it is hopefully!
switching to guns
nice!
is that a 56-ish frame?
Grease Monkey
Originally Posted by ch0mb0
nice!
