using lube for chain but not sure whats safe
I had a other post about wd40 and you guys were saying it doesn't really lubricate the chain so could I use Lucas upper cylinder lubricant its the only type of lube I have and I don't know if the chains I need a certain type of lube, this lube says its for engines but it also says cleans and lubricates (engine and car parts) someone please help
aka Phil Jungels
You would be better off with a can of 3 in 1 oil......
