Schwalbe presta nuts in schrader hole.. nut on inside or outside?
Chainstay Brake Mafia
Quoted: 16 Post(s)
Liked 11 Times
I've been doing some searching about using presta tubes in schrader drilled rims. One thing i read was that the nut on Schwalbe tubes can be used as an adapter for schrader valves. I just happen to have some Schwalbe tubes and see the nut is stepped so that it will center in a schrader hole.
So.. when using the nut as an adapter.. does it go inside the rim? or outside like normal?
Certified Bike Brat
Quoted: 5 Post(s)
Liked 6 Times
Outside. Of course its only suitable for threaded presta valve stems and lower profile rims with a flat top section - for those long unthreaded thingies used on higher profile aero rims you'll have to come up with a plastic or metal sleeve adaptor.
Quoted: 16 Post(s)
Liked 11 Times
thanks, i was planning on using the nut with the tube they came with wheels are some old mountain bike wheels, nothing crazy
Quoted: 3352 Post(s)
Liked 1,056 Times
Personall I would still use the small tubular adapter that fits in the schrader rim hole. They only cost a couple of bucks.
Really Old Senior Member
