Where is the Bionx sl350 6 volt accessory port?
Bikes: 3
I have the Bionx sl350 kit installed in my bike, there should be a 6 volt 2 amp output port available to power the accessories but I can't seem to find it. Please help
On my rear mount battery style setup, there's a wire comeing out of the modual that the battery slides into that goes nowhere. I would assume that's it on my set up as there is no mention of it in the manual... There's nothing on the battery.
Bikes: 3
Bikes: 3
I finally called up Bionx's technical department in Quebec, they told me it is located in the bottom of the battery mounting bracket, after locating where it is and I will soon test the voltage output.
