WTF is the deal wiith KMC chains?
Bikes: 2009 Cannondale CAAD9-6 2014 Trek Domaine 5.9
I broke the chain, and got it to length. Now the KMC quick link that came with it won't fit. Neither will the Sram link or a couple of other brands of links I have.. Is there some secret to making a KMC chain fit???
Location: take your time, enjoy the scenery, it will be there when you get to it
Bikes: 07 IRO BFGB fixed-gear, 07 Pedal Force RS
Never had this problem with KMC chains.
Throw the stick!!!!
I slid a very small screwdriver between the rollers on the master link and expanded them manually. All has been well since.
I may be fat but I'm slow enough to make up for it.
ka maté ka maté ka ora
Bikes: breezer venturi - red novo bosberg - red, pedal force cg1 - red, neuvation f-100 - da, devinci phantom - xt, miele piste - miche/campy, bianchi reparto corse sbx, concorde squadra tsx - da, miele team issue sl - ultegra
Quoted: 25 Post(s)
I use a small pair of needlenose pliers
Quoted: 50 Post(s)
I had this exact problem with 2 KMC links previously, and posted about one of them here - and got my rear end flamed to all end about how I was incompetent, didn't know how to read, etc. Like 3 pages of flames.
I read everything about it I could find online, and did all the correct mounting tricks - none worked. I ended up using serious extreme force (like equivalent of a 500watt push) to pop it on, and then had to jiggle it back and forth many times to loosen it up enough for use. Only after all this craziness did it become like a normal link - I popped it off (with the special tool) and after that initial crazy mount it was easy to put back on.
I think there are some manufacturer problems with the consistency of some missing links, as it happened to me twice with 2 different chains, and I was using the missing link that came with the chain, not a separately bought link.
It'll go on - but it can require some serious force if you get a stuck one like mine.
nice. I'd much rather ride my bike than wrench it.....
Quoted: 3374 Post(s)
Liked 5,508 Times
actually, I've had Sram and Dura Ace chains, but this is my first KMC chain. PITA.
Bikes: 2014 Cannondale SuperSix Evo Hi-Mod, 2013 Fuji Gran Fondo 2.1c
I went from a KMC to Dura-Ace. The KMC chain that came on my bike never seemd to wear out (4000 miles and still only at .75mm wear), so I replaced it anyway for fear that it may be damaging my cassette and/or chainrings. The Dura-Ace is lighter, but also will likely not last as long because of the hollow pins.
I just took off a Dura Ace chain. Got couple thousand miles on it. Great product.
Quoted: 6556 Post(s)
Liked 58 Times
No sure what you mean, OP, but I use the cranks to pop the link to the locked position. The trick is the link has to be on the top run of chain, not on the bottom. Just set the plates in position on the pins, hold the rear wheel and rotate the crank. Sometimes it takes two people. Occasionally you have to have one person hold the wheel while you stand on the forward pedal. Always works eventually. Best chain I have ever used.
Liked 5 Times
Unless you live right next door, It takes less time to do just about anything that needs to be done on a bike yourself than it does to take it to a shop and then have to spend even more time going to pick it up.
Never mind being without it for a however long it takes to do whatever needs to be done.
Wow. Every KMC chain I've ever used only took squeezing the rear brake and popping the pedal with the heel of my hand. Are you sure you have the two halves squeezed together all the way?
Quoted: 5 Post(s)
Quoted: 50 Post(s)
Both of those links I was dealing with came manufactured so tightly that I had to force the link onto the chain, and then do insane super stomps to get it to lock, which is very hard as most of the time that stomp simply knocks the chain/link loose. And yes, I know absolutely what I'm doing - after I got the initial mount (after like 30 failed stomps, seriously), and then some further bending and lubing, the link could be re-mounted easily with a minimal push on the cranks with my hand. There are definitely some links that come wayyyyy too tight, and I was lucky (unlucky) enough to get 2 in a row of them.
I since bought a 5-pack of KMC links separately from the chain, and the 3rd and 4th ones I've tried have been fine. But I know for absolute sure it wasn't user error on my part with the first 2 - I spent over an hour (!!) trying to get each of those links on, and that included watching/reading everything I could find online.
Took it to the lbs and they got it on. They also (both mechanics that is) said I made a poor choice of chains. They said I should stick with sram or shimano chains. Said the KMC will break under heavy watts. Actually he said wait til you're pedaling up that 22% grade to your house and it breaks, then you'll wish you had a better chain. anyone else have a KMC chain break while pedaling?
...actually, I like the chain. I got one of the gold ones, and it looks cool, and so far, rides great.
2 Fat 2 Furious
Bikes: 2009 Specialized Rockhopper Comp Disc, 2009 Specialized Tricross Sport RIP
"For a list of ways technology has failed to improve quality of life, press three"
Quoted: 50 Post(s)
Quoted: 1975 Post(s)
Liked 232 Times
Liked 5,508 Times
