Max heart rate and exercise performance
Bikes: 2 x 2012 GT Series 1, 2012 P2C
I always ASSumed that the greater one's MHR the more work capacity. This article states:
'"There is no association between maximum heart rate and exercise performance,” said Hirofumi Tanaka, the director of the Cardiovascular Aging Research Laboratory and an exercise physiologist at the University of Texas in Austin.'
https://www.nytimes.com/2008/04/10/he...on/10BEST.html
Does this jive with your experiences?
Should Be More Popular
Quoted: 22579 Post(s)
Liked 8,919 Times
Liked 8,919 Times
Liked 8,919 Times
1. What article?
2. Of course it's more complicated. But on a simplified level, your cardiac output is SV x HR. So if your HR is very high but you are not pumping much blood per stroke (for various reasons this happens), your max HR is not necessarily the key determinant to your cardiac output.
With conditioned athletes the stroke volume is very high, hence the slower HR for a given CO. It will take a lot more work to get Lance up to his maximum HR than for a person like me. Conversely with an extremely high HR there may be insufficient time for filling of the heart between beats hence the reduction in stroke volume and lowering of CO. But as datlas says, it really is as simple as CO=HRxSV.
Professional Fuss-Budget
Unless one of us is a sports physiologist who has studied dozens of athletes, what experience could we offer that would counter the current scientific conclusions?
This is not to say that the science is settled and perfect. Rather, that all we would have is anecdotal experience without any precision or protocols or standards. The subsequent data would be worthless for drawing a conclusion.
Quoted: 50 Post(s)
For endurance sports like cycling and running, it's actually an interplay between cardio and muscular sport-specific endurance, and more often than not, it's the muscular endurance (leg cycling endurance for cyclists) that will be the limiter, especially for efforts over 20 minutes (20 minutes is roughly one's ability to hold a true VO2 max hard aerobic effort for a trained athlete.)
So even if you have monster cardio with a VO2max in world-record range, unless your legs are adapted to match, you're not going to be a world-class cyclist, and likely not even close. This is very clear when you see world-class swimmers make the jump over the triathlon or run/cycling, and they start off not much better than average since they don't have the miles in their legs to match the cardio. And it's not just a matter of the legs feeling like they're burning when they go hard - without the training to build capillaries in the legs for blood flow, your HR might skyrocket even at fairly lower power efforts on untrained legs.
Quoted: 119 Post(s)
Being able to ride at a high percentage of maximum heart be it 175 bpm or 200 bpm is what matters; my 41, non scientific rationale.
Falls Downalot
Bikes: Now I Got Two
Quoted: 5 Post(s)
my HR maxes out over 190 on a real hot day on a steep enough climb...and I'm a 60 year old, 180+ pound lard ass never get above "b" category rider...so I'd say the hypotheses of no correlation is true based on my sample size of 1...
Coffin Dodger
Quoted: 794 Post(s)
Liked 292 Times
Pulmonary efficiency is more important than how fast the pump moves. This is my uneducated guess, flame away.
Pirk
Pirk
Bikes: "26" kona kula watt team carbon, "700c" colnago CLX, "700" colnago c59
My friend pass away last month, because hr 228 at age 44. Just curious is there formula for max hr for certain age?
pan y agua
Quoted: 1443 Post(s)
Liked 712 Times
Maximum HR is just about a useless measurement for training or predicting performance. If you're training by HR, you need to set your zones off your threshold HR, not maximum HR.
And having a higher maximum HR doesn't mean you're faster. I'm faster at 53 with a lower maximum HR, than I was at 25 with a higher maximum HR.
Back in the day when we trained by HR, my team mate's maximum HR was at least 20 beats below mine, and he routinely kicked my ass.
Maximum HR is at best bragging fodder.
You could get lost and die.
You could hit a tree and die.
pan y agua
Liked 712 Times
For example, I still see 190 occassionaly, and the formula says my max is 167, which is actually just a couple of beats above my LTHR.
