Square taper Bottom Brackets for Di2 internal cable routing
i intend to use square taper BB with Di2 internal routing. Those that should have enough clearance to run the wire in between the BB and the shell are -
1) https://www.whiteind.com/bottom-brackets.html
2) https://www.specialites-ta.com/gb/boitier-axix-rte.html
Can anyone suggest others that can be used?
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
Ok, I really want to know why you intend on this.
Still kicking.
May I suggest using the proper tool for the job...
Appreciate the old bikes more than the new.
Iconoclast
Bikes: Colnago Super, Fuji Opus III, Specialized Rockhopper, Specialized Sirrus (road)
I didn't know that anyone would debate it. The weight of that titanium Specialties TA is pretty impressive, though.
Iconoclast
Would this Centaur one work?
https://www.chainreactioncycles.com/M...?ModelID=26421
Here's a Record:
https://www.velodromeshop.net/index.php?p=product&id=258
Here's a Record:
Iconoclast
If those work, you might also be able to get away with an FSA Ultimax or Shimano UN91.
Throw the stick!!!!
My only suggestion is to use a good piece of duct tape and tape the wire to the frame to make sure that it doesn't come loose. It shouldn't be a big deal, just remove the bb from time to time to check to make sure the wire hasn't come loose.
I may be fat but I'm slow enough to make up for it.
Marcus_Ti
19
02-04-18 09:27 AM
