Better to have headlight on helmet, bars, or rack, front forks?
I am talking hi power headlights so I can both see and be seen.
I have seen mounts for helmets, bars, forks and front racks randonneur style.
Which makes you the most seen by motorists?
I would like to mount mine on the front forks, but will that make me pretty invisible to drivers who are turning onto the road with my light so low to the ground?
Certified Bike Brat
Quoted: 5 Post(s)
Liked 6 Times
I'm thinking that if your headlight doesn't light up enough ground to be visible from the side regardless of what height you mount it at - it probably won't do you much good as a light for you to see by either.
The most traffic friendly light mounting is LOW!! Truck lights are higher than automobile lights and can be very annoying in spite of having beam cutoffs. If you've ever had an 18-wheeler follow you - you've already been clued in.
I use lights mounted below the bars but above the fork. Ocassionally rack mounted. Regardless - unless your light has a wide beam and a cutoff - it probably won't cover enough area to be as effective as a helmet mount, which you can move around easily.
Cycle Year Round
For urban riding, I always want a good helmet mounted light. You can always add a $30 flashing light to the bars or fork for extra attention.
But some motorist will still just ignore your lights and try to pull out in front of you. If they do this, you can get them to stop before they cut you off by shining the helmet light at them. By the same token, the helmet light can be shined away from oncoming traffic as a courtesy to them, especially on country roads. But if the oncoming traffic is blinding you with high beams, putting your helmet light at them will solve such problems.
Land of the Free, Because of the Brave.
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
I have a headlight I put on the bars and one on the helmet.
Quoted: 19 Post(s)
Liked 7 Times
Most dynamo-powered lights are on the fork crown, this is the std mount supplied with quality lamps. Some people mount them on the fork legs on a special braze-on or an adapter bracket. Fork crown is the optimum location for protecting the lamp from everyday damage, the illumination pattern and bar-bag compatibility.
A blinking LED is not always better than solid, esp at lower frequencies. Drivers can look during the off phase and then turn away. It is much harder to judge distance with a blinking LED than a solid one.
Cycle Year Round
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
No! A headlight should not blink.
A taillight might blink, if you're cycling alone.
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
In Real Life
Bikes: Lots
Liked 596 Times
1. Don't depend on a helmet light as a headlight. However, a helmet light is a good backup light and good choice if you've got to follow a route sheet after dark.
2. Not on the handlebars, except maybe as an emergency backup (i.e. your main light fails, and you pull your LED flashlight out of your handlebar bag and strap it to the bars)
3. I don't use a front rack ... I tried once, and it gave me hand issues
4. Yeah, the forks will work, or fork crown, or somewhere in that vicinity.
Rowan
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
Permanently mounted to the fork or rack on my bikes.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
All of the Above.
xtrajack
Bikes: Kona fire mountain/xtracycle,Univega landrover fs,Nishiki custom sport Ross professional super gran tour Schwinn Mesa (future Xtracycle donor bike)
Having tried all the above, I prefer rack mounted w/another on the helmet. Never been impressed with handlebar mounted lights.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
A truly high-powered light on the helmet offers the opportunity of blinding a motorist just by looking at them.
Removable, the battery lights come assuming a Bar Mount. because the hardware is for a round tube.
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
A helmet light with no bar or fork light can be confusing to oncoming traffic, because it's unusually high off the ground. It's harder to judge the distance to the bike then.
Most rechargeable lights have bar mounts. A second light on the helmet is good, but I quit using one because I was always having to hold my head steady to aim the light.
One of the newer high lumen lights, maybe 600 lumens or more, will certainly be bright enough even if mounted on the fork. My bar mounted 1000 lumen Dinotte creates a very big bright spot on the road, even on urban streets. (I use 1000 lumens in the city, and usually dial it back to 500 lumens on dark country roads)
DancesWithSUVs
Quoted: 7 Post(s)
My $.02;head/helmet mounted high-power lights should be illegal except for dirt riding. I've been blinded too many times on local trails by idiots who don't realize that by mounting their lazar beemsz on their head,they blind on-coming cyclists. After about the third jerk doing this,I get the urge to see if I can still do a proper polo-check. Also not a good idea to blind on-coming cars,and blinding someone who's about to pull out on you is a bad idea;no guarantee they won't still pull out,and if they don't you now have a ticked off driver on your six.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
If it's truly dark, I use a solid beam. Less dark, I use a flashing beam. Sometimes I use both if it is dark.
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
I've got a moderately bright light on my bars, it flashes and does solid. i use solid when it's really dark, and flashing when it's more light and during the day.
i'm contemplating getting some of the small lights that strap to your front fork though and flash just for some extra visibility.
