Handlebar incompatible with brake?
Videre non videri
Bikes: 1 road bike (simple, light), 1 TT bike (could be more aero, could be lighter), 1 all-weather commuter and winter bike, 1 Monark 828E ergometer indoor bike
Late last year, I bought a bunch of stuff for my bike.
A week before I got the parts, I had a massive panic attack and a depression followed that.
I'm almost fully recovered now, but I didn't really have energy enough to get the parts on my bike and all that. I just took all the stuff and put it in a box. Just made sure they were all in working order and with no visible damage or defects.
So, here I am, four months later, and I've just dug the parts out.
Two of the items are a handlebar with drops and a pair of Avid Speed Dial 7 brake handles.
To my horror I now find that the brake handle clamp inner diameter is 22.5 mm, while the handlebar's is 24! They don't fit!!! Argh!
So, what's wrong here?
Are handlebars made in many different diameters or should I have ordered a specific size for the brake units? Not that any such info was available on the site I bought the things from...
Obviously, I have to do something about this.
Do the brake unit clamps come in different sizes so it's a simple matter of replacing the ones I have with another pair?
Or is the handlebar I have such a non-standard piece that I won't be able to find any brakes for it???
Here's the handlebar I have:
(Click the image to go to the info page for the product...)
cyclist/gearhead/cycli...
Bikes: Homebuilt tourer/commuter, modified-beyond-recognition 1990 Trek 1100, reasonably stock 2002-ish Gary Fisher Hoo Koo E Koo
Hmm... to be honest I have never heard of this particular problem. Have you tried loosening the brake lever clamp all the way until the screw nearly falls out? Will it still not fit around the bar?
If that doesn't work, the metal band in the brake lever should be a pretty interchangeable part. Maybe your LBS could scrounge in the parts bend and find some that fit for you.
Bikes: 8 bikes - one for each day of the week!
I was under the impression SD 7's were MTB levers for V brakes. Is this a cyclocross bike?
Videre non videri
This is an ordinary semi-cheap MTB that I'm slowly turning into a comfortable commuter/tourer.
Of course I've unscrewed it all the way.
And there's nothing replaceable there. The whole thing is a single solid, cast piece of aluminium. And it's far too stiff to bend in any way. It will just crack if I try.
I'll post a picture in a few minutes, and you'll see what I mean.
Videre non videri
Yes.
Videre non videri
But that's crazy!
The road brakes available are completely different...
Why would MTB handlebars be THINNER than road handlebars???
Argh, I hate non-standardised things.
There's simply no reason no to have one single size for all purposed!!!
The site I ordered from offered no indications that the bar was a different size...
The Rabbi
Quoted: 16 Post(s)
Mountain bikes are one size, road bikes are another. They ARE standardized. Those levers were never intended for use on a roadbike, or a drop bar for that matter.
Comfort does not = drop bars. Stick with your flat bar if it's a mountain bike.
Videre non videri
I need the brake cables to leave the top of the brake lever housing.
I won't be able to have them run along the surface of the bar itself.
Besides, I really wanted the nice features that the SD7 offer.
I've looked at the site I ordered from again, and all the brake levers they have are seriously inferior in one way or another.
I guess I'll just have to grind out 1.5 mm from the inner section to make it fit.
Videre non videri
The bike is an MTB but it will never be used as one.
It will only see use on normal roads.
And in my case comfort does equal drop bars, as I am almost forced to use the bar ends when I ride, to avoid my wrists and palms hurting.
See, this is a constant battle I'm fighting.
The stupid attitude so prevalent in society that just because something was made for one thing, then it should never be used in any other way.
There's simply no reason why such brakes should NOT be possible to use on any bike, regardless of "type".
In my opinion, parts are NOT standardised if they're not 100% interchangeable.
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
Of course given your penchant for making things excessively difficult for your self this latest problem doesn't surprise me
Originally Posted by Expatriate
You're the expert here. Go wreck the levers, making them unsafe and use them in a way they were not intended to be used. Just don't ask for advice here, and then get all *****ty because you don't like what you hear. Your idea is an accident waiting to happen.
I'm not surprised he'd try something like this
When you ride with drop bars, you position your hands quite differently than the way you do with mountain bike handlebars. One advantage of aero brake levers is that the hood provides a comfortable position to hook your thumb into.
It sounds like you may not have ever ridden with drop bars before. I would suggest trying them out before converting your bike to them. Everything is a little bit different: the way you support your weight, the way you steer, the way you brake, the way you shift. Maybe you'll like them better, but maybe not. Find out now, so that you don't waste time modifying your bike in a way you won't like.
What specific feature do your current levers have that you want to keep? There are road brake levers designed to work with all types of brakes these days, so that you can use V-brakes or disc brakes on a bike with a drop bar.
Still kicking.
Appreciate the old bikes more than the new.
Videre non videri
Well, if these clamps had been 25.4 mm, I'd be happy, but they're only 22.5!
The bar itself is 24 mm, so with 1.4 mm to spare, things would've been just fine...
I'm not trying to make things difficult for myself, I just don't understand why I should be so extremely limited in my choice of brake levers just because I want to use drop bars. There's just no reason.
Manufacturers are stupid and narrow-minded. I'll just have to accept that in this case, I guess, and make the best of the situation.
And Raiyn, there's nothing WRONG with trying new things once in a while.
If everyone only did what people before them always had done, we'd be eating ants off of straws and digging up edible roots with our bare fingers...
You obviously have some serious problems if you call that a fiasco.
I can't help that you're too narrow-minded to see the benefits of my proposed set-up. At least TRY to accept that other people might have a bit more vision than you have yourself.
Just because you think certain parts "should" be interchangeable doesn't mean they are. Perhaps on some abstract level it would be great to be able to swap parts with reckless abandon. However there are many good reasons why some parts don't work with other parts. A number of people have already pointed out reasons why MTB brakes are designed differently from road brakes. I'll add one: mountain bikes generally have V-brakes, which have a greater mechanical advantage than caliper road brakes, which produces a greater stopping power per unit cable travel. These require correspondingly different levers.
You're right it wasn't a fiasco it was a complete ********************
You don't have more vision, you have serious delusions.
Videre non videri
Ah well, this is like trying to talk to a brick wall.
I'm sorry that you can't see past your noses.
I'll give the grinding a go unless I can talk the company I bought them from into taking them back. But I doubt that since it's been four months now...
I paid something like $50 for them, so I don't intend to just throw them in the bin, you can be sure of that!
