Hilly Crit Race Strategy?
I'm doing my 3rd crit so I'm very new to this, got yanked in the first two so bear with me...
it's at the Formula 1 Circuit of the Americas track outside Austin. This track is 3.4 miles and contains a couple considerable hills, the largest is at the start. Other than adding in a lot of hill repeats to my training, what's a good strategy during the race? Same as a flat course or would you racing vets recommend anything different? Im thinking it's more probable that this course is going to break the field up pretty quickly so staying towards the front at the start would be even more crucial? I'll be riding in the cat 4/5 group.
Any tips appreciated and sorry if this subject has been covered already, didn't see any threads. Course is at the top of link below:
https://www.tourdeaustin.com/2013Race...4/Default.aspx
Thanks!
Thanks!
**** that
Quoted: 1099 Post(s)
Liked 104 Times
Strategy only comes after not being dropped.. so focus on not being dropped.
But yeah I think staying up front is definitely a good idea. Start up front so you don't have to do a lot of work to get there.
pan y agua
Quoted: 1441 Post(s)
Liked 710 Times
Actually the race on the F 1 course is a circuit race,not a crit. ( a distinction that matters with regard to free laps).
As for strategy, if you're gravity challenged, get to the front of the group at the start of each climb, then ride your own pace, to the extent possible, filtering back through the group, with the goal being to stay in contact with the back end of the main group by the top, or at least close enough to roll them up on the descent.
This tactic works pretty well on relatively short climbs, and can allow you to hang with people that are better climbers, and avoid burning matches.
In lower category races, I found a number of times, I ended up being the first over smaller climbs when I went to the front to start this tactic because no one was willing to come around and drive the pace to shed the fat guys like me.
You could get lost and die.
You could hit a tree and die.
No matches
Bikes: two wheeled ones
Quoted: 1398 Post(s)
Liked 444 Times
Like Merlin said, circuit race, not crit.
Best strategy for hilly races is to be lighter and stronger than everyone else. Sag climbing like merlin recommends will also be helpful.
Thanks for the help!
Circuit race, eh? See I told you I was green. I'm not the most prolific climber so thanks for the tip, I appreciate it.
I did a similar race: Sea Otter circuit at Laguna Seca. There's a pretty gnarly hill about a half-mile from the start.
I do ok on hills but my strategy was essentially the same as what Merlin said. I'd stay toward the front of the group (not in the wind) until the start of the hill. Once the hill started, I'd make sure I stayed top ten. That way, if I started to flag, I could drop back 10-15 wheels and still be in the main group at the top. Make up places on the downhill/flat spots. Rinse, repeat.
If you get shelled on the hill and you're already near the back, it will be hard to make up spots/close a gap once the main group crests the hill in front of you (unless you're some kind of downhill/TT wizard).
Good luck!
Good luck!
No matches
Liked 444 Times
There's not a ton of difference, you can read the rulebook for the details. A couple major differences: crits you get a free lap(s) for mechanical or flat tire issues before a certain point in the race, circuit race you're probably just screwed unless the pack is going slow and you get some help from a friendly wheel truck to pace you in. Circuit races are done by number of laps, crits are generally done by time, or time + some number of laps. You also get more upgrade points for circuit races than you do for crits. The dividing line is 5 km, which is 3.1 miles. Shorter is a crit, longer is a circuit (road) race. There really isn't a distinction in the rule book between circuit races and road races. Road races can either by out and back, one way, or around a circuit longer than 5km.
Crits also have to be closed course, road races can be rolling enclosures and have yellow line rules. Crits you can only have one field at a time racing.
Having said all that, it looks like they're mixing the two a bit looking at the flyer. They show it as 40 minutes, but they have multiple fields racing at the same time with different start times. So I have no idea if they'll give a free lap or not, or whether they'll report it as a crit or road race.
Making a kilometer blurry
Yep, sag climbing is going to be your best bet. If your goal is not to get dropped, then fight as hard as you can to stay up in the top 15, but probably not the top 5. In races like this, when I'm on the offensive, I'm maintaining on the climbs, then sprinting hard over the top to stretch the accordion as much as possible. Everyone on the climb behind me now has to try to deal with my flatland acceleration while they're on a steep grade. Death by a thousand accelerations. Be on the lookout for this and remember the front of the accordion is less acceleration.
Wow, thanks for all the info and tips! Much appreciated! They're billing it as Criterium Americas so I'm not sure how the rules will break down, we'll see I guess.
In the Pain Cave
Much agreed. If you have been getting dropped just make sure you burn every single match you can to stay with the pack before getting dropped. hold that wheel with your life
Wheelsuck
Re: crit vs circuit, the biggest thing is that if you flat or crash on a circuit you don't get a free lap. Basically it's more like a road race in that sense - if you come off the back You're On Your Own (aka "YOYO").
For any loop that has a hill you're going to be dealing with zero elevation change every lap, meaning you end up exactly where you started, and within a few minutes of racing. This means that the hills aren't as crazy as in a RR (no 35 minute climbs) and there's a pretty long downward slope somewhere (because most courses with a hill will put the steep grade as an uphill, not as a downhill, and the shallow grade will therefore be a downhill).
This means it's a classic sprint-recover type of effort. You go hard up the hill and over the top, you soft pedal and try to recover, then you do it again. If you can recover quick enough then you can do this for a while. It's a harmonic rhythm type thing. If recovering takes you 30 seconds and the next effort hits you at 25 seconds then you'll get shelled. If the effort hits you at 35 seconds then you'll be uncomfortable but able to hang on. 60 seconds and you'll be golden.
If you find yourself on the good side of the effort-recovery cycle then you should try to improve your position by extending your effort a bit longer. Usually it's more beneficial to keep going over the top of a hill (climb "through the top" of a climb) rather than starting your effort just before the hill. The delta in effort versus the benefit is usually better if you push after the climb, not before it.
To make this work you have to be able to draft well. You can't drift back into the very back if the racers back there are letting gaps go because you may be at your limit and then the guy in front of you gets gapped.
burp
I thought for a brief moment about doing this exact race (4/5). I have a dozen or so races (crits, RRs, TTs) under my belt, so I wasn't thrown off by the large hill near the start. What really made me scratch my head about doing this race was the fact that it's at 1 pm, in central Texas, in August/September, on raceway asphalt (tarmac?). Me thinks the heat will be tough enough of a challenge. At least the Driveway course has shaded areas. And FFS, I have no idea why the first race of the day at the COTA is noon. Blah.
zero elevation change, SAG-recover on descent, don't drift back too much on climb, stay in first 15, hold that wheel with your life.
Good advice all, I'll be using all of this.
One other thing: as in any race, being careful about staying sheltered (do a forum search on "wind management" for more CDR goodness) as much as possible will help save your matches for the climbs. If you're spending energy moving up or even just hanging out in the wind, you're going to have less in the tank for the climbs. You can think of yourself as having a kind of energy gauge or health bar, like in a video game. Whenever you're cruising easily in the pack, it's going up, when you're on the hill or in the wind, it's going down, more quickly the harder you work. If it runs out, you get dropped. Over the course of the race, it will go down and up again as you hit the hills each lap and them recover, but the overall trend is that it will deplete throughout the race. Your goal is to keep it from running out until the end of the race, where you'll use whatever is left, if anything for your final sprint. Or just to finish with the pack, depending on your fitness and how well you've managed your energy through the race. Good luck, and have fun out there!
Bikes: Orbea Onix TLT
Its going to be well over a hundred over the pavement tomorrow. Good luck man. Make sure you drink a ton of water the night before, morning of, and during or you're toast.
Race/track preview for the COTA race if anyone is interested, 14% grade, good grief. https://supersquadra.net/?p=4297
Full lap: https://app.strava.com/segments/2735078
The big hill: https://app.strava.com/segments/2675130
