Building a Cyclocross bike with a MTB Frame...
human
Bikes: 2005 Litespeed Teramo, 2000 Marinoni Leggero, 2001 Kona Major Jake (with Campy Centaur), 1997 Specialized S-Works M2, 1992 Specialized Rockhopper
you can run 26" wheels. i've seen frankenbikes like this at the races, particularly for maller riders -- women and youths.
when walking, just walk. when sitting, just sit. when riding, just ride. above all, don't wobble.
The Irregular Cycling Club of Montreal
Cycling irregularly since 2002
I couldn't car less.
Bikes: Ritchey P-series prototype, Diamondback, Nishiki Triathelon Pro.
I just tried a 700 Mavic with IRC XC tires on my rigid mtb.
5mm clearance under the bridge. I have a Shimano 600 bridge mount brake, maybe I'll see how off it'll be.
Are you going to cut off the canti mounts?
How about moving them up?? Impossible? no..hard yes.
The brake mounted with the pads perfect >inline with the rim! I dislike skinny rims, but LOVE light bikes.
I'm horrified and delighted!
Now the rear brake is different, where are the frame braces? The top one probably wont be drilled horizontal, it will be vertical, one side.
Maybe..if the rear strut is the right distance to mount the tire..and in the right position to mount the brake.
You might drill the frame brace horizontal and tap screw a mount holes for the brake.
Maybe this is a bad idea....stress on the brace. If you did some brazing you could fill the one hole.
