Which of the well known bike lubes are the least unpleasant, smell-wise?
Among the popular bike lubes, which ones have less odor and are the least unpleasant? I've read reviews that say ProLink, Dumonde have strong awful smells. What about Pedro's GO! lube? And other good quality lubes? (Comparisons to Finishline Wet Chain lube and Tri-Flow will be helpful to me as I've used them.)
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
I've been using Rock 'n' Roll Gold and haven't noticed any smell. But with that said, I lube outside, keep the bikes in the garage, and don't have a particularly keen sense of smell.
Quoted: 2952 Post(s)
Liked 3,106 Times
Hmm, I have always thought Pro-link was fairly pleasant smelling. It isn't particularly strong.
Well I care. I have to keep the bike inside an apartment and I do everything inside (still looking for a good bike stand). On top of that, I have a keen sense of smell. Thanks for the informative replies.
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
"Smelling pretty" is at the bottom of my list of priorities when it comes to bike/car lubes. I use chainsaw oil (soon to be switching to Chain-L) on the bikes, Rotella 15W40 in the cars.
Quoted: 77 Post(s)
Liked 19 Times
We use the hot wax (parafin ) method.
NO smell. You will never get a chain tattoo either.
Quoted: 3355 Post(s)
Liked 5,432 Times
"Smell that? You smell that? Chain lube, son. Nothing else in the world smells like that. I love the smell of chain lube in the morning."
Certified Bike Brat
Quoted: 5 Post(s)
Liked 6 Times
I personally don't find the Finish Line WET lube offensive, but if you're looking for a wet lube with less odor - Finish Line CERAMIC WET also has a very light odor.
You would probably hate BIONETXC lubes, as well as CHAIN-L, even though some of those addatives that make them smell strongly also make them more effective lubricants.
Purple Extreme is a synthetic and doesn't smell like oil, but the odor level will still be on a par with Finish Line Wet.
Dry lubes in general are almost oderless once set up after 24 hours, but since the carrier has to evaporate in the meantime - the smell can be worse indoors. White Lightning products are all low odor, but most of their products require very frequent applications and wiping down afterwards - which IMO requires more effort than most other lubes. They also make a wet lube WET RIDE, which would offer no advantages over the FinishLine you've already used.
Maybe an alternative might be to try a different strategy: Lube and wipe down the bike outside in a park someplace. That'll result in as little odor in the apartment as possible.
KY ?
Some guys prefer the smell of Diesel , to overdoing a strong perfume.. just sayin'
Quoted: 234 Post(s)
Liked 444 Times
Must be a slow news day...
sheesh...
What lube smells better? wait a minute...hey honey what lube smells better? Troj...what??? I don't have no Troj...oh never mind hehehe...
sheesh...
The only lubes I have used are: Triflow - no detectable smell on ordinary riding or in the garage Chain-L No.5 - strong auto engine oil smell, but pleasant. Can smell it when standing a few feet from bike while in garage. Boeshield - no detectable smell in garage or while riding, or standing near bike.
Pedro's Go! and Pedro's Chain-j both smell of castor oil. The Pedro's SYN LUBE has a completely different odor - very light, and the Pedro's ICE WAX has a very similar, but stronger smell.
Actually anything no more smelly than Finishline Wet Lube and Tri-Flow are fine for me. (Since I always used these two at the same time, I'm not sure which one gives stronger smell.)
By the way how do you like the function of "Pedro's GO!" lube? Comparing to Finishline Cross Country Wet Chain Lube?
Certified Bike Brat
Quoted: 5 Post(s)
Liked 6 Times
We're using Finish Line Wet and Dry in the shop largely because they're some of the few high end lubes that are available in shop-sized quantities so I obviously like what you're already using.
Personally I'm currently doing a season on Purple Extreme because it's extremely low viscosity makes it easy to apply in warm or cold weather. And it handles rain pretty well. There are about 20 applications in a bottle which works out to about $1.25 per lube.
Have to point out that I lube about every 150kms though - more often if there's lots of rain involved. That means at least twice a week. Much heavier viscosity oils like SAE 90 hypoid gear oils do last longer in the rain, but not significantly enough to make up for the extra dirt they attract. An issue since I'm running alloy chainrings -and not steel ones.
Both that Finish Line Wet and Trifloware good products. No reason to look around unless its just curiosity.
Burton, thanks. I like the Tri-Flow straw . I hope Finishline improves the nozzle, making it longer and more tipped. I'd like to try Pedro's Oranj Peelz Citrus degreaser, which is supposed to smell like orange .
Bikes: 1992 Trek 800 Antelope, 1971 Triumph
If you use a lube enough then you can't really smell it. You get used to iit and don't even notice it. I agre with Mr. Beanz; you should be riding your bike, not sniffing the chain or hubs.
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
But OK Mr Life's Lessons () Knowing that we are all different means asking a forum consisting of thousands of poster which is most unpleasant makes this topic even that much more silly doesn't it?
Certified Bike Brat
Quoted: 5 Post(s)
Liked 6 Times
Well I have no objections if you would like to sniff my chain too. Have at it!
