Stress on rear wheel - spokes
Quoted: 44 Post(s)
I have an Aerostream GT Cruiser bike with a kit I installed from e-bikekit.com. It's a front geared 350watt motor and I drive it with a 10ah 48V LiFePO4 pack mounted on the rear rack. The bike also has internal 3-speed gears in the rear hub. The 700C wheels on the bike have 14 gauge stainless steel spokes on the rear, and the replaced front wheel with the motor came from e-bikekit.com with beefier 12 gauge spokes.
I'm finding I'm breaking spokes on the rear wheel more often than I would like. Could be because of: more weight on rear wheel (battery); generally driving faster and braking more; other? I myself am no lightweight at 240 as well.
Trying to figure out likely cause and possible solutions:
- just replace spokes as they break?
- re-lace whole wheel with thicker gauge spokes like are on front wheel (not sure how practical this is)?
- re-lace whole wheel with butted 14 gauge spokes?
I broke spokes twice first 500 miles, then after making sure i tightened them @ proper interval havent broken any in 4200 miles.
Spend a hour watching youtube videos on truing wheels, I replaced the spokes myself & trued them if I can do it anyone can. After they are re-tightened & trued up rim the bike finds it's groove. I rarely even check mine now I'm over 200 lbs & my bike uses thin gauge spokes..The re-tightening after inital 50 { some people go 100 ** miles is the important step, like re torquing heads just milled & installed on an engine , has to be done.
Bikes: Bicycles
Quoted: 8 Post(s)
I'm 6' @ 220# and have always been rough on rear spokes, so I carry zip-ties to hold broken spokes inplace and a nipple wrench to true the plot just to get home.
(after a second spoke breaks... I'd respoke the wheel... just me, YMMV)
Having built many sets of wheels over the years for self use only and having just bought a powerful ebike this rear spoke issue is on the brain.
For spokes, consider Sapim Strong. They are 2.3mm at the head. The hub holes might have to be opened up just a tad.
Shop well as prices vary... wheelbuilder offers single spoke in DT & Sapim.
If your rear wheel has alot of dish, consider a rim with O/C holes. DT and Velocity offer such.
Or consider a rim that can take high spoke tension. The Velocity Synergy O/C seems to not be strong enough for high tension.
Good luck Chubby!
I was 270# with 42" waist 4 years ago.
Fact: Fat people do not age well, by this time next year my goal is 195#.
Good luck Chubby!
Yes, Re-tighten all the spokes after 50 - 100 miles... I also over tighten mine "just a little bit" and that seems to have stopped my spoke breakage for almost 1,000 miles now...
Bikes: Bicycles
Quoted: 8 Post(s)
Spokes and hubs can take a lot of tension, it is the rim hole that will bend & crack.
Search for rim issues with your type of rim OP.
I've tensioned good double butted spokes to cracking a light Mavic rim.
Then I loosened all the front spokes 1.5 turn and ran that front on a pedal only bike.
Bikes: Various "modded" eZips and multiple econversions
I got tired of spokes breaking, so I went "whole hog" on a solution.
I felt the spoke flange was too thin.
Which stressed the elbow.
First I added 12g spokes. (redrilled flange with 1/8" bit)
Flange still appeared too thin.
So, I added #4 sae washers that pulled the elbows tight to the flange.
With the spoke "enarmored" as best as I could devise, I felt the wheel might not measure up.
So I drilled wheel at 3/16" wrapped it with a couple layers of duct tape and reinforced with #10 sae washers.
Quoted: 44 Post(s)
Thanks again!
Stainless steel washers recommended.
12ga spokes do not flex.
After bending while trying to "lace" them.
I found it best to pre-position all spokes before inserting into rim, I laced and positioned using scotch tape at every crossing.
Pre-laced and taped 14g model.
Better picture showing washer advantage.
See original article - eZip Broken Spoke - Solution
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Interesting solution.
Keep in mind that those spokes are always in tension, never in compression. So, I don’t see any advantage to the work you did on the wheel. Did you have problems on that side of the spoke? You don’t have them pull through do you?
Dilkes – you didn’t say how your spokes broke? Mine usually break at the elbows at the hub, as a result of abuse or improper maintenance. How many spokes do you have on your wheel? If the spokes are kept properly tensioned, they shouldn’t flex that much at the elbow. 36 strong spokes is a good way to go though.
Once you have 2-3 spokes break, the odds are that the wear is on all of them and relacing is a good option. However if your wheel doesn’t get too out of true with a broken spoke, you can just replace them one by one if you want. That works better if you have 36 spokes vs 24 spokes (where breaking one spoke is going to but a major warp in the wheel.
Spokes break at elbow.
No support near the elbow places a leveraged stress at the elbow.
Quoted: 44 Post(s)
Liked 415 Times
Yeah, if you have several that have broken, it sounds to me that they are all probably pretty worn due to age, wear, load, maintenance, etc.
With 36 spokes, you can probably ride fine with one missing. Its fairly easy to do one at a time (as long as there are not a lot of torque arms and stuff in the way), its just the ones behind the cog/freewheel that can be more of a pain.
I have 36 spokes and they break at the elbow. I am going to replace the current 2 broken and then check tension more frequently going forward. If I still have problems, then I will look at re-lacing, perhaps with butted spokes or thicker gauge. Thanks for all the guidance. Comforting? (or something like that) to know I'm not alone with this type of problem.
Like when I built my own studded tires ... "go big or go home".
The HedgeHog
See - Making Your Own Studded Tyres
All my spokes broke @ the nipple, so that tells me many variables for each case including wheel design, weight of rider, materials etc...
TallRider
Bicycle Mechanics
29
03-21-18 07:52 PM
