Clydesdales/Athenas (200+ lb / 91+ kg) Looking to lose that spare tire? Ideal weight 200+? Frustrated being a large cyclist in a sport geared for the ultra-light? Learn about the bikes and parts that can take the abuse of a heavier cyclist, how to keep your body going while losing the weight, and get support from others who've been successful.
New tire
Old 08-21-13, 10:01 AM
Big Boned Biker
IAMAMRA's Avatar
Bikes: Raleigh Detour 4.5, Trek Crossrip Elite '14
Quoted: 19 Post(s)
New tire
So I wore out my back tire, and need to replace it. Couple of questions, should I replace both of them? Any suggestions from fellow Clyde's, I can run anywhere from a 700cx28-38 the front has 700x35 currently. I ride almost completely on roads but do sometime go on gravel roads(but rarely).
Thanks,
Micah
IAMAMRA is offline
Old 08-21-13, 10:08 AM
skilsaw's Avatar
Bikes: Cannondale t1, Koga-Miyata World Traveller
Liked 3 Times in 3 Posts
Your front tire is fine. Back tires wear out 4 times faster than front tires.
No need to replace the front unless you have money to throw down the drain in order to have everything match up. Unless you are unhappy with it, go with the same width tire you wore out.
skilsaw is offline
Old 08-21-13, 10:20 AM
ill.clyde's Avatar
Bikes: 2009 Trek 1.2
Quoted: 239 Post(s)
Liked 3 Times in 1 Post
Echo ... really only absolutely must replace the back, but you could replace both if you're up to it and want things to match
As for type/brand/etc ... check out the Cyclocross section of BikeTiresDirect.com ...
ill.clyde is offline
Old 08-21-13, 12:27 PM
Big Boned Biker
IAMAMRA's Avatar
Quoted: 19 Post(s)
https://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER Was thinking of this in 700x28 and replacing the font with the same size as well.
IAMAMRA is offline
Old 08-21-13, 12:34 PM
ill.clyde's Avatar
Quoted: 239 Post(s)
good choice
Old 08-21-13, 12:58 PM
SuperGimp
TrojanHorse's Avatar
Bikes: Specialized Roubaix
Quoted: 1107 Post(s)
Liked 64 Times in 47 Posts
Put the front on the back and put the new tire on the front. (unless they're different sizes)
It's better to have your best tire up front.
TrojanHorse is offline
Old 08-21-13, 07:06 PM
mprelaw's Avatar
^^^ This. Front blow-outs are no fun at all. If your rear blows, you still have some steering control.
mprelaw is offline
Old 08-21-13, 09:53 PM
Bikes: More than 1, but, less than S-1
Quoted: 5 Post(s)
Another vote for moving the chunkier front to the rear and putting the new, narrower tire on the front.
Birth Certificate, Passport, Marriage License Driver's License and Residency Permit all say I'm a Fred. I guess there's no denying it.
bigfred is offline
Quoted: 5 Post(s)
Or, two new tires.
bigfred is offline
Old 08-21-13, 10:15 PM
Big Boned Biker
IAMAMRA's Avatar
Quoted: 19 Post(s)
Went with two new tires in 700x28
IAMAMRA is offline
Old 08-23-13, 09:32 PM
Big Boned Biker
IAMAMRA's Avatar
Quoted: 19 Post(s)
New tires came in today, installed them both. The front tire went on easy the back was b!t$# to get on. Rode them around the block and they feel great so far.
IAMAMRA is offline
Old 08-23-13, 10:59 PM
Quoted: 5 Post(s)
Excellent.
bigfred is offline
kenshireen
General Cycling Discussion
30
09-22-18 11:59 PM
jonjmorris
Touring
12
09-21-17 11:15 AM
GlennR
Road Cycling
18
05-29-17 05:57 PM
bomski99
Road Cycling
18
06-19-11 04:14 PM
Daytrip
Road Cycling
20
06-21-10 08:07 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
