older litespeed
Bikes: Trek mountain bike, Centurion road bike, Trek single speed
older litespeed
I am looking at buying an older litespeed, any suggestions on checking the frame before buying. I don't want to get something that's not repairable if there is a problem.
Bikes: Litespeed, O'Brien, Specialized, Fuji
Quoted: 18 Post(s)
Liked 15 Times
My feeling is that you need to do a very careful inspection just like with any other used bike. You can't easily have the frame inspected for alignment, so you have to visually check everything. Is everything straight and true? Any scuff marks anywhere, dents, scratches, scrapes? How does it ride? That said, I would check around all welds very carefully for cracks, especially the bottom bracket, and look for any evidence of a frontal hit, such as wrinkled top/down tubes or fork damage. The bike should be clean so you can see, and use good lighting.
As to repairability, it probably depends on whether anyone in your area can do ti repairs. Even something seemingly simple might be difficult if no one around knows how to do it and has the equipment. Otherwise, I have no idea how hard it is to repair ti problems.
Bikes: Litespeed Ti Mtb, BikeE Recumbent, Cannondale H600 Hybrid,
If you are looking for a Litespeed Mtn bike, do note that the first generation Litespeed Mtn bike uses 1" headset. The suspension forks is hard to come by. Later generations uses 1 1/8 headset. It is easier to get forks in this size.
Porschefan
17
04-14-15 03:32 PM
