Sore hands, advice please.
Old 05-21-02, 09:15 AM
山馬鹿
Spire's Avatar
Bikes: Nakagawa
Hi everybody,
It seems that when I get out on my new roadbike, the palms of my hands (esp the left one) are really hurting from the position of up by the brakes on shifters from the top. The other positions are pretty ok. I even have gloves (the $12 MEC variety). Is there a proper way to hold the bike, and I am not doing it? What is the proper way?
Any advice would be very much appreciated!
S
Spire is offline
Old 05-21-02, 10:07 AM
The way to avoid sore hands is to move them around the bars frequently. Leaving them in one place doesn't allow proper circulation. You could also try adding more padding to the bar. Sometimes one layer just isn't enough. But in any case, move your hands more.
ljbike
ljbike is offline
Old 05-21-02, 10:31 AM
Quoted: 19 Post(s)
Liked 7 Times in 7 Posts
I cant the levers inboard a few degrees, and reshape the rubber grip by stuffing strips of inner tube under the rubber hoods. This ensured that the pressure is on the palm on my hand, not the outside edge.
Keep all your fingers on the outside of the bars. I used to hook my 2 smallest fingers behind the drops, but this makes them numb.
MichaelW is offline
Old 05-21-02, 10:40 AM
human
velocipedio's Avatar
Bikes: 2005 Litespeed Teramo, 2000 Marinoni Leggero, 2001 Kona Major Jake (with Campy Centaur), 1997 Specialized S-Works M2, 1992 Specialized Rockhopper
Spire...
It depends on the kind of pain, but I find that sore hands on a road bike are usually cause by one or more of three factors:
1. Holding the bars/hoods too tightly. You don't need a white-knuckle deathgrip. One thing I do on long rides, when I have my hands on the tops of the bars, is hold my thumbs over top of the bars so I'm not inclined to clench.
2. Bar rotation/brake hood position. Most road bikes come out of the store set up essentially for criterium races, with the bars and the brake/shift levers rotated down. This can put a lot of pressure on the heel of your hand, particularly on the median nerve. This thread talks a bit about that.
3. Seat angle. If your saddle is angled too far forward, you may be putting pressure on your hands. You might try rotating the tilt of your saddle back 0.5-2 degrees.
when walking, just walk. when sitting, just sit. when riding, just ride. above all, don't wobble.
The Irregular Cycling Club of Montreal
Cycling irregularly since 2002
velocipedio is offline
Old 05-21-02, 01:24 PM
Greg's Avatar
Move your hands around a lot and avoid locking your elbows.
There are a lot of different types of gloves on the market. Find one with lots of padding in the right spot.
What ever you do, do not stop riding. If you do, your a$$ and mid section will swell turning the pain into shame.
Greg is offline
Old 05-21-02, 01:28 PM
山馬鹿
Spire's Avatar
Bikes: Nakagawa
Not bloody likely. If I were to stop riding it would take a while to "swell" at 6"1 and 155lbs, I would need to gain alot ......
Spire is offline
Old 05-21-02, 01:32 PM
Greg's Avatar
Sounds like we could be long lost brothers.
Do you have side burns?
Greg is offline
Old 05-21-02, 01:39 PM
山馬鹿
Spire's Avatar
Bikes: Nakagawa
Not quite, just down to about the bottom of the ear level, but I have glasses (I will be trying contacts soon)....
Spire is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
