CREE XM-L XML T6 LED Headlamp
Bikes: Ridgeback Steel Tourer,Recumbent SWB,Steel Road,,Raleigh Twenty,Elephant Bike,Pashley Pronto TNT.
Quoted: 21 Post(s)
Liked 5 Times
Hello,I have a CREE XM-L XML T6 LED Headlamp thats runs from two 18650 rechargabe batteries.Can I also run it from a 6volt lead acid sealed battery?
thanks.
thanks.
Mad bike riding scientist
Quoted: 6212 Post(s)
Liked 4,210 Times
Probably not. The Li ion batteries produce 7.4 V and the circuitry in the light may have a protection circuit that won't let it operate at that low a voltage. But replacement Li-ion battery packs are dirt cheap.
Stuart Black
Stuart Black
Quoted: 21 Post(s)
Liked 5 Times
OK,thanks mate.i just have an old lead acid on a belt pack that i wanted to use up..
Bikes: This list got too long: several ‘bents, an urban utility e-bike, and a dahon D7 that my daughter has absconded with.
Quoted: 363 Post(s)
Liked 66 Times
??? if you have all the parts lying about then give it a try, let us know how it works out. . .
Quoted: 7348 Post(s)
Liked 2,460 Times
Why do you want to do this? LiIon batteries are better in almost every way.
Quoted: 21 Post(s)
Liked 5 Times
I`ll just have to wear the belt with no battery.
Bikes: Bacchetta Giro, Strada
That said, the 6v Pb battery probably starts at 6.5 volts or so, and is nearly dead at 6.0 volts.
I imagine the Pb battery will work when fully charged, but the protection circuit will probably kick in before it's fully discharged (though it might go all the way down to 6.0 volts -- that's the lowest you can safely discharge two li-ion cells, but even that's pushing it further than is ideal.)
Quoted: 21 Post(s)
Liked 5 Times
But it runs on one,thats 3.7 volts?
Bikes: 2012 Giant ATX Pro Hybrid Mountain Bike; 2012 Jamis Xenith T Time Trial Bike
It depends of the driver of your bike light. Many drivers for XM-Ls have operating voltage from 3 volts to 4.5 volts. You can however swap a buck driver, the ones used for two cell in series flashlights. Its operating voltage is 6 volts to 9 volts.
Spld cyclist
5
02-06-18 01:55 PM
rapattack
28
05-17-15 11:38 PM
newleefixed
15
06-08-13 12:13 AM
trekker pete
3
01-17-12 07:45 PM
