Pulling up the star nut
Old 03-08-05 | 07:11 PM
genericbikedude's Avatar
如果你能讀了這個你講中文
Hi,
I've got a persistently loose headset, and when I went to look into it, I find the star fangled nut flush to the top cap. It seems that all of the roadside adjustments that I've made have merely pulled up the star nut.
Why did this happen, and what can I do to fix it? I'd rather keep the same star nut if possible, as I want to get this bike ridable tonight.
It's an Aheadset with a Salsa topcap.
Thanks much
genericbikedude is offline
Reply
Old 03-08-05 | 07:28 PM
sydney's Avatar
20 Anniversary
Originally Posted by genericbikedude
Hi,
Thanks much
Starnut may have been installed upside down.
sydney is offline
Reply
Old 03-08-05 | 07:33 PM
如果你能讀了這個你講中文
I wish it was that simple. Just to be clear, the star nut was installed with the edges higher than the center, for lack of better terminology.
Also, I just whacked it back down, then attempted to re-adjust, but got the same problem as soon as I tested the front brakes.
I'm not using a star-nut setting tool, as I don't have one. While this could theoretically be the source of problems, could it be the source of THIS problem?
Reply
Old 03-08-05 | 07:38 PM
sydney's Avatar
20 Anniversary
Doubt it. I'd get another star nut.
sydney is offline
Reply
Old 03-08-05 | 07:41 PM
如果你能讀了這個你講中文
Thanks
Reply
Old 03-08-05 | 07:44 PM
phantomcow2's Avatar
la vache fantôme
I agree with syndey. I have never used a star nut setting tool, and ive never had a problem. I use a wooden dowel.
C://dos
C://dos.run
run.dos.run
phantomcow2 is offline
Reply
Old 03-08-05 | 07:47 PM
Rev.Chuck's Avatar
The Red Lantern
Sheldon Brown Memorial - Donating
20 Anniversary
First, are you loosening the stem before you make an adjustment? if you don't loosen the stem you cannot make an adjustment.
Second, is there a couple of mm clearance between the top of the stem and the top of the steerer? The cap may be contacting the steerer.
Third, does the cap look flared at all on the part that fits into the stem/steerer. Sometimes this will get hung up on the steerer and cause an issue.
Are you a registered member? Why not? click here to register. Its free, and only takes 27 seconds!
Help out the forums, abide by our community guidelines.
I am in the woods and I have gone crazy.
Rev.Chuck is offline
Reply
Old 03-08-05 | 08:29 PM
Bike Junkie
20 Anniversary
1. Pull out the star nut and press it upside down against a flat surface to spread out the arms.
2. Clean the inside of the steerer with alcohol
3. Re-insert the star nut.
4. Install the stem making sure to check the steerer clearance as Rev.Chuck suggests.
5. Tighten the top cap until there is no play in the front end and no further
6. Tighten the stem bolts.
7. Loosen the top cap bolt a quarter turn to take pressure off of the star nut.
-s
slider is offline
Reply
Old 03-09-05 | 12:57 AM
Videre non videri
Bikes: 1 road bike (simple, light), 1 TT bike (could be more aero, could be lighter), 1 all-weather commuter and winter bike, 1 Monark 828E ergometer indoor bike
Should you really re-use a star nut?
They're dirt cheap, so I'd get a new one...
CdCf is offline
Reply
Old 03-09-05 | 01:59 AM
Bike Junkie
20 Anniversary
From the original post
"I'd rather keep the same star nut if possible, as I want to get this bike ridable tonight."
slider is offline
Reply
Old 03-09-05 | 04:35 AM
Brian's Avatar
Bikes: 8 bikes - one for each day of the week!
I guess we all missed that part. Your choice to make your bike unsafe. I suggest a Headlock by Azonic, or similar item. I don't use star nuts anymore.
Brian is offline
Reply
Old 03-09-05 | 06:20 AM
capwater's Avatar
Bikes: Giant TCR Comps, Cdale R5000, Klein Q-Pro, Litespeed Siena, Piasano 105, Redline Conquest Pro, Voodoo Bizango, Fuji Aloha
Never used a setting tool, made one for about a buck at Home Depot and pounded it to the correct depth with a socket. If you totally hosed up the orientattion to the steerer tube you wouldn't be able to screw in the bolt anywhere near straight. Anyone who has ever installed the star nut will realized there is no way in hell that thing should back out, it's strictly a one way road. Bizarro thought, not sure if all these parts came together, but could you possibly have a 1" nut in a 1 1/8 steerer? Bottom line, get a new star nut and end your frustration.
capwater is offline
Reply
Old 03-10-05 | 01:31 AM
Bike Junkie
20 Anniversary
Starnuts serve no purpose beside tightening the headset. Once the stem bolts are tight it just sits there. In no way would re-using a star nut be unsafe.
-s
slider is offline
Reply
Old 03-10-05 | 04:17 AM
Dannihilator's Avatar
Still kicking.
Sheldon Brown Memorial - Registered
20 Anniversary
Bikes: Bike Count: Rising.
If pressed back in numerous times, the starnut will wear out; but that is numerous times though.
Appreciate the old bikes more than the new.
Dannihilator is offline
Reply
Old 03-10-05 | 12:52 PM
如果你能讀了這個你講中文
I just got a new star nut and solved my problem. Message here: aheadset parts all suck. This is the second aheadset star nut that I've replaced in my year-long tenure as a bike pseudo-mechanic. Next bike I build up is getting a chris king.
Reply
Old 03-10-05 | 02:26 PM
Back in the Sooner State
20 Anniversary
You're still going to have to use a star nut with a King headset. I've never had to replace one unless I got it started so screwy that I had to pound it out the bottom of the steerer and break it out. But a King headset will probably outlive you, so it's a good way to go.
Edit: My aheadset still works great, and it's from 1996. They aren't King, but they don't suck.
ImprezaDrvr is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
