Yet Another Compact Crank Question
Old 03-08-05 | 07:28 PM
20 Anniversary
I did a search on this but didn't find anything.
I want to convert my Dura Ace triple to an FSA compact. What does this entail? Can I use my current front deraillerur and front shifter, or do I need to replace one or the other, or both? Can I use my Dura Ace bottom bracket?
Thanks much.
ltspd is offline
Reply
Old 03-08-05 | 07:30 PM
sydney's Avatar
20 Anniversary
Thanks much.
The shifter will shift a double.The FD will probably work. The BB spindle is the wrong length for a double.
sydney is offline
Reply
Old 03-08-05 | 07:48 PM
ggg300's Avatar
Burnin' and Lootin'
like he said...but some like to use a longer bb with the compact b/c they want to use the small ring on the higer gears....most likely a bad idea.
I'd stay with the DA triple myself and I run a compact.
ggg300 is offline
Reply
Old 03-08-05 | 08:59 PM
John E's Avatar
feros ferio
25 Anniversary
Your current full-size crankset is a superior technology. Reducing the tooth count front and/or rear merely accelerates driveline wear and makes it harder to set up a good gear ratio progression. Compact drive systems are yet another useless fad, like indexed front shifters, which appears to have caught on.
John E is offline
Reply
Old 03-08-05 | 09:47 PM
sydney's Avatar
20 Anniversary
Lighten up John. It's 2005,and resistance is futile.
sydney is offline
Reply
Old 03-09-05 | 01:15 AM
ggg300's Avatar
Burnin' and Lootin'
with a 5 speed or even a 7 speed system I'd agree. But the fad is 9 or ten speed...easy to get progression. Friction is the way to go up front, but what are ya gonna do...copy some guy who won the TDF?
ggg300 is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
