Is lithium grease OK for chainring bolts?
Hi,
I just have a basic question: Is lithium grease OK for chainring bolts? I wanted to get anti-seize compound, but nobody at Home Depot knew what it was, and neither do I. So, I just grabbed the lithium grease, hoping it was the same thing.
Since I don't have a car, getting to stores is a pain in the ass, so if the lithium will do the trick, then that's what I'll use.
Thanks,
Micah
P.S. My first post
Thanks,
Micah
P.S. My first post
Originally Posted by MicahWedemeyer
Hi,
Thanks,
Micah
P.S. My first post
Thanks,
Micah
P.S. My first post
Older Than Dirt
You'll be fine with the grease. If you want an anti-seize compound, most any auto parts store will have it.
Doc
Doc
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
Originally Posted by sydney
Yeah, it works. And HC, we get to have another grease thread....Ooh lala!!
la vache fantôme
Originally Posted by Rowan
So, is it advisable to place grease on the thread of everything that screws in? How much?
C://dos
C://dos.run
run.dos.run
C://dos
C://dos.run
run.dos.run
Bikes: 2 many
Liked 323 Times
just the right amount. no more. no less.
Retrogrouch in Training
Lithium = good (syd will tell you that there are better greases these days and that's no lie but there's also nothing wrong with plain lithium so long as it doesn't use a soap base)
As for amount...Well think about the actual contact area between threads and think about a layer of grease a few microns thick... that's how much. Basically a little dab'll do ya.
slower than you
Bikes: Gunnar Road Sport, peugeot UO-10
Don't forget your seatpost. That also can get stuck permanently.
Originally Posted by 2manybikes
You're old enough to remember Brylcream (spelling?) commercials?
Bikes: 2 many
Liked 323 Times
Originally Posted by bostontrevor
Nah, but I think it's safe to say that it's entered into the vernacular.
I may have watched that saying on a commercial in the 1960's.
One of us is old............
Bikes: All 70s and 80s, only steel.
...but do youse guys remember the 80s attempt at reprising the song for some short-lived Brylcream mousse: 'a little dollop'll do ya?'
Bikes: 2 many
Liked 323 Times
powers2b Is lithium OK for chaingangs?
Yes, especially if they run out of Prozac.
dangerous with tools
Bikes: fat, long, single & fast
Regarding never-seize, its overkill for the application you're talking about. Plus its a horrid mess to work with. Unless you like having little silver fingerprints and smears all over your bike, tools and self.
Originally Posted by halfbiked
FYI, Home Depot ain't the place to go for mechanical stuff. You'll have much better luck going to either a local hardware store or automotive place when you need things like grease and tools. Sears is good for tools, but won't have as much in terms of 'consumables' like grease.
Bikes: Puch Luzern, Puch Mistral SLE, Bianchi Pista, Motobecane Grand Touring, Austro-Daimler Ultima, Legnano, Raleigh MountainTour, Cannondale SM600
any grease is better than no grease IMO
You might be surprised at what sears and HD really has.Wallymart or The Blue Light Special place may beat em both. There is always LBS for the big spenders,that buy the bike specific grease angle.
Bikes: EPX 303 (You probably never heard of it)
I have a carbon seat post. Sorry, no grease on carbon components please.
Pardon my redundency, but we are advising peope to grease their threads on this grease thread. Does that mean that we have to use thread grease (on the grease thread, that is)?
Bikes: 2 many
Liked 323 Times
Well you don't really use thread grease on the grease thread. You really use thread grease on threads that need grease. Although there are thread greasers on this grease thread that do use thread grease to grease threads.
And if you find a grease you like from reading the grease thread, you may technically refer to it as
"Grease thread, thread grease"
Hopefully I did not repeat your redundancy repeatedly.
Geez, 2manybikes, do you bet your horses each way like that?! And, hey, metro, at least you're thinking.
It was a trick question. In my humble (very, very humble) experience, there are places where I would NOT put grease, because the OEM has said so. For example:
-- Brake posts on suspension forks (use Loctite).
-- The itsy-bitsy screws on V-brakes and cantis that adjust the spring tension.
Funny, when I see blue on the thread of a screw or bolt applied by the OEM, that's a pretty good clue that neither a clean thread nor a greased thread should be used.
Then there are spoke nipples. Grease them? Nah. Maybe the old raw linseed oil trick, or none at all (my preference). But grease? Hmmmm.
Do you grease the ends of your quick-release skewers? What about the seat clamp bolt? Atop your threaded headset and lock-nut? Even the clamp bolts on the brake and shifter set?
And I've read some Shimano specs that have said no grease. I think around the BB. But I might be wrong there. Also the flats of BB spindles.
More seriously (or very seriously, actually) one of the things I was supposed to learn in dealing with motor mechanics was that ALL threads should be absolutely clean of grease. It all had to do with torquing of bolts and stuff to ACCURATE specifications.
So it was initially a bit of an problem when everyone said... hey grease those threads on bikes... but I learned it had more to do with corrosion and seizing of parts together.
Oh well... we are in the hands of experts...
