Handel bar extension needed
All the bar end extensions I can find are offset at an angle. I'm looking for a simple "inline" extension - a bar end that slips over (or into) the end of my handlebars and simply extends the length of the handlebar. I imagine it would look like a Dimension Steerer Extender if it fit over the bar. Does anyone know of such a product?
Handel? https://en.wikipedia.org/wiki/George_Frideric_Handel the composer ?.
Length? you talking bar ends , Willis?
Humvee of bikes =Worksman
Quoted: 10 Post(s)
Liked 6 Times
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
EDIT: It just occurred to me that maybe, just maybe, that you've got a 'bent with USS...
Community guidelines
pro in someone's theory
Bikes: FTP
Quoted: 72 Post(s)
edit: Oh, is the steering off of each side? In that case I don't know.
only one I can think of https://www.sjscycles.co.uk/humpert-a...amp-prod24408/
this is done to remove the curved end , add the brake lever , slip a grip-shifter onto the center ,
and the grips , then put the curved bar ends on and tighten the wedge clamps.
German company
German company
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Are you riding a Sun Adult Trike or a Sun Recumbent Trike? (That's how Sun classifies them on their website.)
Thunder Whisperer
Quoted: 275 Post(s)
Liked 6 Times
1. You want to extend the bars but not make them wider? And you're wanting to run the bar extensions straight instead of the normal perpendicular style (of varying degrees). Not possible with a flat or riser bar, as your extensions will make the bar wider overall.
2. On the other hand, if you have something like either a moustache or drop bar, you could conceivably add those extensions without affecting the width. Can't imagine doing that to a drop bar, but I can for a moustache bar- and this leads me to think that you are trying to get the controls closer. If so, you should be looking at a shorter stem.
I still think you'll get better help if you post a pic of either your bike or the type of bars on your bike so that everyone has the same concept to work with.
Quoted: 629 Post(s)
Liked 1,257 Times
I "think" I understand what you want to do. A redneck way to do it if you can't change the bar would be to find a cheap (used) handlebar the same size with straight sections the length you need and cut those pieces off. Take your handlebars and pieces from the donor bars to a good weld shop. Have them put a piece of round stock inside the ends of your current bars a couple inches with a couple inches sticking out, tack them in place and then slip the new pieces over the round stock with a slight gap between them and the other bars, weld it all to the round stock, grind smooth, paint it and then cover the ugliness with hand grips or bar tape. You could also drill and pin the pieces together but welding would be a lot better. Ugly but effective.
Bikes: FTP
Quoted: 72 Post(s)
Did you actually measure the interior diameter of your bars? The steerer converter could work if the interior diameter is close to 1 inch. The other possibility is you could use two barends on each side so that you get back to the original angle. It would look kind of fredly but that shouldn't bother someone who is already on a trike.
The Recumbent Quant
I'll point out for the record that people who ride the trike below, for example, probably wouldn't want to "Fred it out":
don't try this at home.
Quoted: 972 Post(s)
Liked 509 Times
If you are out of options, a woodworking shop with a lathe could turn a solid wood bar end, with the outside section the same diameter as the bars, and a narrower plug section to glue into the existing handlebar.
Bikes: FTP
Quoted: 72 Post(s)
Another option I thought of if you only need a couple centimeters of extension: you could just use a lock-on grip and not put it on all the way.
The Recumbent Quant
You're not going to find an in-line extension commercially, because the resulting bar would be unsafe to put any weight on. Which Sun trike are you working with? Pic? I'm still not clear if you're trying to make some side-stick bars taller, ape-hanger bars with more extension, or something else entirely.
buy as long a piece of 7/8" steel tubing as you desire .
for shipping I think they make it in 40 foot lengths..
the length of a typical semi-trailer ..
mnr102
Bicycle Mechanics
2
07-04-11 10:49 AM
