Loose crank
Loose crank
I just had work done on my mountain bike (Trek 4500, about 3 yrs old) because the chainrings were coming loose from the crank. I think it was a loose spider ring maybe? Anyway, they tightened it up for me and charged 10 bucks and everything was good. 12 miles of riding later (after a few weeks) my right side crank comes loose. The hex bolt holdin on the crank (I assume that's what it does) is really loose. So I'm thinking that it's the LBS's fault because I've ridden the bike for years w/ no trouble, then they do some work (assuming they took the crank off to tighten the lockring) and it almost falls off 12 miles later. So I guess I'm kinda complaining, but I also want to know what to do. I'd take it to the shop, but that's a hassle and I guess it might not be their fault, so what do I need to do to fix it myself. Can I just tighten it back, or do I need to worry about sand/dirt having gotten inside somewhere, and then take it all apart, clean it, and put it back together? I pretty much stopped riding when I realized something was wrong, but it was a pretty sandy trail. And, can I just tighten the bolt down real tight, or does it really need to be a specific torque? Thanks, and sorry for the long message.
-Will
-Will
Reckless Rider
Bikes: 2 Konas, 1 Santa Cruz, 1 Surly, 1 Cannondale, 1 Schwinn
Tighten the bolt down with wrist-not arm. If it comes loose again tighten it a little more than the last time.
Listen to me
Go back to the shop and ask for your $10 back.
They are liable for work that they do to your bike and would rather give your money back than face a bad image and/or lawsuit.
Enjoy
Enjoy
-Will
-Will
Bikes: All 70s and 80s, only steel.
Originally Posted by sydney
I'd take it back.You can retighten it. Problem is that having it loosen up while riding could have damaged the crank.When that happens, it will often never stay tight.
Bikes: 2004 Raliegh Retro Glide 7(green of course), 2005 Stingray Pea Picker 2005 Specialized Hardrock 2014 Trek Crossfit
Definately take it back to the shop. If you try to tighten it your self, and have to do this numerous times, with the same outcome, and then you take it back to the shop . They will not stand behind it. Riding a loose crank will round out the crank and possibly the the BB spindle. Then you'll have to replace both. Crank bolts should be tightened with a torque wrench, to insure that the arm is on all the way, and that it will stay there. IMO
We're gonna have the hap, hap, happiest Christmas since Bing Crosby tap-danced with Danny ****ing Kaye.~Clark Griswold
Well, I took it by the shop today and talked to the mechanics. They said that it isn't uncommon for crank bolts to come loose once you've loosened them the first time. Doesn't make a whole lot of sense to me, but they were nice about it and tightened it up for me (for free). I asked if it could have gotten messed up riding w/ it loose, but they said the splines on mine (don't know what type of cranks I have) are really hard to mess up and it should be fine. I took his word for it, and I rode it a little and it seemed fine, so I'm happy. I guess time will tell if I've been screwed though... Thanks everyone for the help.
-Will
-Will
