Modifying the weight of a folding bike (Dahon MU Uno)
Bikes: Fully customized 11-spd MTB built on 2014 Santa Cruz 5010 frame; Brompton S2E-X 2014; Brompton M3E 2014
Quoted: 17 Post(s)
Just wondering where is a good place to start when considering bringing down the weight of my MU Uno.
I guess switching to a carbon seatpost and handlebars are obvious considerations, but what other options would there be?
Thanks in advance.
Thanks in advance.
LET'S ROLL
Lighter tires, carbon/titanium pedals/seat/crank/skewers, lighter wheel.
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
Quoted: 113 Post(s)
Liked 8 Times
Certainly the post pump could go .. the kickstand away .. biggest weight loss will be wheels and tires.. the Shimano coaster hub is heavy.. you could lose that and run a track hub and cob up a rear caliper brake adapter at the kickstand mount .. I still run a Rolf paired spoke up front , but negated the weight loss by putting a SRAM 2 speed in the rear .. offset the rear wheel weight by lacing 24 to a 24h Velocity rim.. but then I pulled the carbon seatpost out and the post pump back in for convenience as well as the kickstand.. so yea, you can lose a couple of pounds pretty easily, but you have to ask yourself how worthwhile in the long run..
Bikes: to many
Quoted: 213 Post(s)
oh soo true .....
Quoted: 5 Post(s)
Hi, I just pulled almost 400 grams by replacing the crankset !! I've got a double now !! I started lightening my Tern Link D8 by replacing the seat post and seat, almost a pound savings !, Of course, you should replace the wheels, I have kinetix Pros and about to try Schwalbe Ultreno ZX's, and lighter tubes to save another 300 grams from Kojaks !, Replacing v brakes with KCNC...carbon handle bars, all Dura Ace 10 speed drive train , KMC sl chain.....Lighter pedals...it's going to be cool !!!
Bikes: Dahon Mu Sport & Mu Ex
I single speeded my Dahon Mu XL and gave it some lighter parts. Brought it down to 8kg:
https://www.faltradforum.de/download/...1047&mode=view
It is not about beeing worthwhile. Its just a hobby to do it. And plain fun to ride it.
Quoted: 5 Post(s)
Quoted: 17 Post(s)
Hi I wanna revive this thread as I am also interested in weight-saving options for a MU UNO on a buget.
If your contribution to this thread is "buy another bike" I would like you to reflect if that could be deemed a contribution at all.
For the MU Uno owners who have been the same path I intend to go, please chip in with ideas and the tried and tested.
I want the lightest MU Uno possible. I will not go carbon, but I will replace things that can make the bike lighter and will buy the parts exclusively on ebay. I also will sell the parts I no longer need, in order to fund this project.
My total budget is $200. I bought my Mu Uno secondhand so I am not overspending and buying another bike is not an option.
The reason for saving weight is a no-brainer: transport.
This is my job list:
1. Get rid of the seatpost with the built in pump. I do not need this I can carry a small pump and use petrol stations.
I will sell the seatpost on ebay and buy a lighter one for the same price.
2. Got rid of the centrestand and sold it. That is 320 grams and it was rattling all along.
3. Ditch the Shimano CB E100 coaster hub. I really dislike coaster brakes. I know it is a 28 hole hub, flange diameter is approx. 48.5mm center to center spoke holes, 3/8x24 axle.
I want to find a straight out replacement that allows me to utilize the same spokes.
4. Will source the Eiosix rear brake caliper adaptor and a tektro R365 to match the front, or will buy a rear tektro R556 long reach and try to attach to the upper brigge.
5. Wanna change the cranks and axle for hollowtech, perhaps FSA Gosamer as it was supplied with the Speed Pro TT.
Will sell the originals.
6. Would love to fit Gates carbon drive system but I do not think I can get the right ratios to match what I have today which is 53T front and 14T rear.
7. Since my used bike came with a sparrow handlebar, may resort to original flat bar plus a riser similar to the Speed Pro TT.
I need advise on the following issues:
A. anyone has tried a straight out replacement hub that does not cost an arm and a leg?
B. Any source for the eiosix brake adapter that is not asia-bound? These are not found on ebay only on asian sites and I am not geared to purchase from them.
C. It has been said that the curved cross frame tube on the rear is to fit a fender not a brake. Still looks ok to me. Anyone could technically argue for or against it? At the moment I only saw armchair expert comments, still looks ok to me to fit a brake there.
D. Anyone knows details about the crankset I need, in this case a shimano hollowtech type, also I do not understand why the cranks are stamped 170mm but I compared them with some 175mm I have and look exactly the same.
E. Anyone has experience with a workable Gates setup?
F. Anything else? Please bear in mind that changing the wheels is not an option, I am quite happy with them and when the tires wear I will look for sleeks.
Thanks all and look forward to the comments!!!
Bests
Bests
The important measurement is from center-of-crank to pedal hole.
I have tried several times to open an account in faltradforum to view your link but my email gets rejected. I tried a few emails, maybe only accepts german emails I have no idea, or it is an oversight from the administrators.
In any case I would much like to know what you have done to yours so I can get inspired.
Would you be able to post it here?
Danke!
You add nothing to the thread. Do not assume people are idiots.
To get the support, inspiration and knowledge from people who know their stuff better than I do.
Not to read mediocre comments from people who have nothing else to do and assume I cannot tell the difference between a slotted and a phillips screwdriver.
If this is wrong then I have an attitude.
Nothing worse than posting a long thread or a specific question, and get some one minute cheap responses and then I suppose to thank people for that.
Look at the first post, then the first response. Do you think "buy another bike" helps the original poster? I regard that more as an insult to his intelligence.
Still, those levels of response are the ones that prevail on forums everywhere.
And I tell you why I post in forums:
Bikes: 2015 Windsor Oxford; 2012 Trek T900; 2008 Iron Horse Commuter; 1999 Specialized Stumpjumper M2 Pro; 1999 Kona Lava Dome; 1992 Trek 520 Tour; 1980 Fuji Grand Tour SE; 1973 Raleigh LTD-3; 1956 Robin Hood; 198x Worksman Industrial Trike
Quoted: 5 Post(s)
WOW, just WOW.
ok I am done with this forum and will direct my energy somewhere else.
