Snapped my chain!!! Less than 100 miles...
Bikes: Salsa Ti Warbird- 2014/ November RAIL52s
Quoted: 67 Post(s)
I'd like to be down to 190 by April...I've signed up for a charity Century and I'd like to run my own 100 miler solo prior...
I'm probably going to swap out the crank for a Sugino Compact+ OX901D. I need more low gears. There are some steep inclines around here at certain points. Highbridge Park has a good one and coming back up through Inwood has a goodie, going up the Hudson Valley things get more hilly as well, so I'm pretty sure I'll need it. I nearly spun out the 46x11 on a slope on the West Side as well...So, I may go with the 48x32. right now the 46x30 or 46x32 are the contenders. I'm wondering in my mind what the impact upon shifting is going to be...it seems going to 46x30 would make the drop equivalent to 3 RD shifts versus 2 right now...
Quoted: 67 Post(s)
Ya think? I'm scratching my head here... Maybe it's the picture. The chain pretty much looked okay... The LBS guys were very confident that it was a manufacturers defect after inspecting the pin-head.
just pedal
will work fine... I've got one of them on a chain... I prefer the sram as I can get them apart without tools... but I think the 10 speed stuff is all supposed to be a single use/disposable item *rollseyes* i'm a cheapo and will stick to my 9spd stuff for a while longer lol
just pedal
https://forums.roadbikereview.com/com...ck-269672.html
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
:facepalm, shaking head, inhaling through nose and exhaling through puffed cheeks:
Birth Certificate, Passport, Marriage License Driver's License and Residency Permit all say I'm a Fred. I guess there's no denying it.
Quoted: 67 Post(s)
edit-
Ahhhh...Well, I was rolling nude that day (no multi-tool)...seems that I coulda popped the effected links and rejoined them with the chain breaker...
What's the purpose of the quick links if you need a chain breaker to begin with? Seems like a quick link isn't necessary at all as long as you have the chain breaker...
Kinda useless without a quick/missing link? Facts, they're your friend. (Besides...I rode...the subway!!! )
edit-
edit-
I haven't got time right now for the full history lesson.
But, the chain tools predate quick links.
Used to be. Back in the olden days. In the before time. Link pins extended beyond the side plate and could be pressed in and out, more or less at will. Using one of those tools, like you have.
But, as the number of gears in the back incresed, the chains had to grow narrower. Rather than reduce the internal width, the external width was minimized. Resulting in less and less pin protrusion and ultimately pins that are peened in place. These pins can not be revomed and replaced without significant loss in link strength. They create little fissures in the sideplate when they are extracted.
To allow for the assembly of such chains two systems have been employed, quick links, and in the case of Shimano special hardened and slightly oversized "connecting pins".
So, the purpose of the chain tool in this day and age is to either break a link for the purposes of shortening a chain upon initial installation, insert a Shimano "connecting pin" into a chain that is being rejoined or in your case extract the remaining half link.
Whether you would be able to successfully remove a full link and temporarily rejoin the chain with one of the original peened pins I am not sure of. I suspect it would be very difficult to get the mushroomed end back into the opposite outerplate. Like wise, unlike the old style pins that would simply slide out of the inner half link, the peened pins sometimes (but not always) need to be extracted through the inner link. Hence my earlier comments about the use of whatever road side debris I could find to assit with this, in preparation for use of quick link. Fact is, I think the sideplate of my Rap6 multitool has a little slot in it that would probably provide adequate leverage. But, a nail and a reasonable rock would work just as well.
Keep at it, you learn and figure this stuff out. I've got a lot of years of true back country mountain biking and secondary road riding behind me.
Quoted: 67 Post(s)
Thanks again Big...that made a lot of sense. Chain design has been compromised structurally in order to accommodate more cogs it seems...I'll just add a quick link to the kit (along with the multi-tool) to cover this kind of contingency.
Quoted: 305 Post(s)
Liked 2,038 Times
That guy from the Chi
Bikes: 88 Trek 800 - gone to new cheeks; '14 Trek 1.2 - aka The X1 Advanced; '13 Trek 3500 Disc
Quoted: 13 Post(s)
You, my good sir, have my adoration and respect.
I had a belt in my tire shift on my old Roadie, Gertie. I had to carry my bike as I walked because the tire wouldn't clear the brakes. Sadly old Gertie got smashed a few hours later, but that last "ride" was her enjoying the view from my shoulders. Definitely no shame as I walked in lycra, bike hoisted on my shoulder, in broad daylight, and as it started to rain.
And also surprised they didn't arrest you for riding around with those loaded guns on you....
Elduderino2412
Road Cycling
16
09-01-12 01:24 PM
