Internal cable maintenance
Senior Member (Retired)
Bikes: Vittorio, Centaur triple; Casati Laser Piu, Chorus Triple.
When my new bike arrives, it will have internal cables. Does anyone have any ideas about any special maintenance or lubrication issues with these?
Thanks...Gary
Thanks...Gary
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
Thanks...Gary
Thanks...Gary
Great looking, but not my cup of tea
Bikes: 8 bikes - one for each day of the week!
Raiyn's more of a beer guy. I just don't think he drinks tea at all.
I have a Klein...It looks great..When I bought it, never thought about maintenance...The solution, let your trusted wrench change it out at least every two years...I just went through this at my LBS...The mechanic is now expereinced with this problem..Really , quite simple...Just attach the new cable to the old as you pull the old one out...Cable stretch..Won't last more than two years anyway.
Before he realized what is the correct way to change out the cable, he even used a vacuum machine to suck it out...Didn't work..It was a Saturday and when the wrench called Klein , they were closed for customer service calls.
Your mechanic sucks. Sorry.
Si Senior
Bikes: Too Numerous (not)
Quoted: 23 Post(s)
Liked 10 Times
Thanks...Gary
Thanks...Gary
Or maybe you mean inside the tubes. I actually sought out a frame with the rear brake cable routed inside the top tube for a my most recent touring bike build. That makes it impervious to all the different racks it gets thrown onto.
It is a Casati Laser - the cables run inside the frame tubes.
Given the cost differential from outside cables, I assume that they do it the way it was done in the old days. That is, small diameter tubing run inside the frame tubing to carry the cables.
I really don't see much of an issue, but wondered about peoples' experiences.
Cheers...Gary
Cheers...Gary
Si Senior
Quoted: 23 Post(s)
Liked 10 Times
Cheers...Gary
Cheers...Gary
My top-tube internal routed cable (Raleigh Technium frame) just has holes and guides for running standard housings through the tube. I don't know the recommended procedure for change, but I left the old cable threaded through the tube, pulled the old housing, then ran the new housing over the old cable to guide it into and out of the tube openings. Then I replaced the cable.
Originally Posted by dbg
So is cable housing integrated into the tubes, or can you thread new housing through the tubes when you need to replace them?
