headset bolt
headset bolt
having read that a small amount of play in the front fork is not good, and that the appropriate action was to check and tighten the headset bolt, i grabbed m'allens and gave it a slow turn and it sheered clean off in my hand! its a decent, 05 hope headset and im only a little chap so could it be and flaw in the bolt or am i a heavy handed fool?!? and how do i get the sheered off end out the fork?
The Red Lantern
You need to loosen the stem first.
Remove the cap and get it out with a pair of needlenose pliers if you are lucky or drive out the starnut and replace it with a new one if the bolt was sheared off flush.
Are you a registered member? Why not? click here to register. Its free, and only takes 27 seconds!
Help out the forums, abide by our community guidelines.
I am in the woods and I have gone crazy.
