How do I remove a 3 speed rear wheel
Bike Recycler
Bikes: Huffy Cruiser
I have an old Supercycle that I need to remove the rear wheel on it but I have never attempted to do this before and not sure how to. Last thing I want is to mess it up. Here is a picture of it. Any help would be greatly appreciated.
Quoted: 1074 Post(s)
Liked 295 Times
You see that angled thingy that the wire hooks up to?
In 2nd gear, there should be a symbol in the angled thingy that lines up nicely with a cutout in the housing that holds the angled thingy.
If you can identify the marking and its reference you know what to shoot for when reinstalling the wheel. Now, unhook the wire by holding the locknut(closest to the angled thingy) firm and turning the sleeve. Then back out the axle nuts a few turns and pop the wheel out. Doesn't seem to be any coaster brake reaction arm to worry about.
"When you remove and re-install a rear wheel with an internal-gear hub, pay particular attention to the axle washers." etc.
https://sheldonbrown.com/sturmey-archer_tech.html
-Bandera
Duh. Putting one's contact lenses in does wonders for clarity, thanks.
2nd try, Sheldon Brown on Shimano:
https://sheldonbrown.com/shimano333.html
-Bandera
-Bandera
wrench, on the axle nuts , loosen them . remove wheel .. the shift thing on the end unscrews too .
another bike left in the Barn for 20 years.
Bike Recycler
Greg
Mechanic/Tourist
All my trigger shifter says on it is 1, 2 and 3. There are no symbols on it. So do I still put it in number 2 position then loosen the nut near the wire, to get the assembly off. I read the article from Sheldon Brown but it doesn't say how to take the rear wheel off the bike so I can change the tube and tire.
Greg
Greg
looks (peering into the darkness) like the cable is rusted , if the barrel adjuster will not unscrew.
cut the cable.. you will need a new one anyhow.
Bike Recycler
Thanks to everyone for the help. I get a little nervous about touching anything if I'm not familar with it. Has I don't want to mess it up so it doesn't work anymore. Even though these are low end bikes I still like to fix them up and give them to people in need.
Liked 295 Times
I was referring to the the angled metal thingy attached to the rear axle, in your pic. That has to be in a certain position whent he shift lever is at it's 2 position. If you take a look at this while the bike is working you know what to shoot for when putting the wheel back.
Bike Recycler
Quoted: 5781 Post(s)
Liked 2,577 Times
Just to add something not yet mentioned. When you reinstall the wheel you have o center it in the frame, and pull it back so there's the proper chain slack (not tension).
Pull the wheel back, so the chain is just slightly slack and sags in the center about 1/4" or so. Test with your fingers, then tighten the wheel just enough so i won't move, but don't tighten full yet. Now turn the cranks and you'll see the sag change slightly because the chaining isn't perfectly round. Find the tightest place, and test with your finger that there's still some free vertical play at the center. If so, tighten the wheel, connect the cable and adjust the gears. Otherwise correct the wheel position.
Once you've done this once or twice, you'll have a good feel for the job wan will be able to center the wheel and get the right chain slack without thinking.
FB
Chain-L site
FB
Chain-L site
Bike Recycler
Force
Classic & Vintage
2
08-17-12 11:22 PM
